    Unable to update to latest version of Node.js and npm
    11 Posts 4 Posters 11.0k Views 4 Watching
      sdetweil @bminer1
      @bminer1 yes, they split the npm install off from the node install… so you have to do two now
      sudo apt-get install npm
      then sudo npm i -g npm ( as it updated the usr/lib folder)
        sdetweil @EdO
        @EdO he doesn’t have npm yet… see my post above
          bminer1
          This website was exactly what i needed to get the latest version and it worked.
          https://www.instructables.com/id/Install-Nodejs-and-Npm-on-Raspberry-Pi/
            sdetweil @bminer1
            @bminer1 in the future if you use the installer, it will handle this
              bminer1
              I went through all of the avenues and this was the only way it stuck.
              I am creating a second MM Pi so ill try it again on this Pi.
                sdetweil @bminer1
                @bminer1 use the new installer script
                see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
