    Unable to update to latest version of Node.js and npm
    11 Posts 4 Posters 12.2k Views 4 Watching
      sdetweil @ernenr1
      @ernenr1 try this
      https://www.battlehillmedia.com/installing-node-js-and-npm-on-raspberry-pi-3/
      E 1 Reply Last reply
      • E
        ernenr1 @sdetweil
        @sdetweil Thank you very much! This actually worked!
          bminer1
          I am not having much luck with this. Been searching and trying everything…
          i@raspberrypi:~ $ node -v
          v10.15.2
          pi@raspberrypi:~ $ npm -v
          bash: npm: command not found
          • E
            EdO
            I’ve used this to update npm:
            npm install npm@latest -g
              sdetweil @bminer1
              @bminer1 yes, they split the npm install off from the node install… so you have to do two now
              sudo apt-get install npm
              then sudo npm i -g npm ( as it updated the usr/lib folder)
                sdetweil @EdO
                @EdO he doesn’t have npm yet… see my post above
                  bminer1
                  This website was exactly what i needed to get the latest version and it worked.
                  https://www.instructables.com/id/Install-Nodejs-and-Npm-on-Raspberry-Pi/
                    sdetweil @bminer1
                    @bminer1 in the future if you use the installer, it will handle this
                      bminer1
                      I went through all of the avenues and this was the only way it stuck.
                      I am creating a second MM Pi so ill try it again on this Pi.
                        sdetweil @bminer1
                        @bminer1 use the new installer script
                        see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
