    Unable to update to latest version of Node.js and npm
    11 Posts 4 Posters 11.8k Views 4 Watching
    • E Offline
      ernenr1
      Hi! This is my first time installing Magic Mirror and I have been attempting to install it through a manual install. I currently have Raspbian Desktop installed on an old Thinkpad x41. The specs are as listed:
      Architecture:          i686
      CPU op-mode(s):        32-bit
      Byte Order:            Little Endian
      CPU(s):                1
      On-line CPU(s) list:   0
      Thread(s) per core:    1
      Core(s) per socket:    1
      Socket(s):             1
      Vendor ID:             GenuineIntel
      CPU family:            6
      Model:                 13
      Model name:            Intel(R) Pentium(R) M processor 1.50GHz
      Stepping:              8
      CPU MHz:               600.000
      CPU max MHz:           1500.0000
      CPU min MHz:           600.0000
      BogoMIPS:              1197.04
      Flags:                 fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov clflush dts acpi mmx fxsr sse sse2 ss tm pbe nx bts est tm2
      Now the issue is that when I reach to the npm install step of the installation, I am returned with this error.
      pi@raspberry:~/MagicMirror $ npm install && npm start
      -bash: npm: command not found
      I have a feeling the issue is due to the version of Node.js. and the inability to install npm. The latest version I have installed 8.11.1. and then when I check the version of npm installed its missing.
      pi@raspberry:~/MagicMirror $ sudo apt-get install -y nodejs
      Reading package lists... Done
      Building dependency tree
      nodejs is already the newest version (8.11.1~dfsg-2~bpo9+1).
      0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
      pi@raspberry:~ $ npm -v
      If I try to install npm, I get this error.
      pi@raspberry:~ $ sudo apt-get install npm
      Note, selecting 'nodejs:amd64' instead of 'npm:amd64'
      Some packages could not be installed. This may mean that you have
      requested an impossible situation or if you are using the unstable
      distribution that some required packages have not yet been created
      or been moved out of Incoming.
      The following information may help to resolve the situation:
      The following packages have unmet dependencies:
       nodejs:amd64 : Depends: python-minimal:amd64 but it is not going to be installed
      E: Unable to correct problems, you have held broken packages.
      Is the reason as to why I am running into both of these issues due to the hardware limitation of my Thinkpad being a 32-bit machine? If so, is there any way to update to the 10.x version of Node.js with a 32-bit machine?
        sdetweil @ernenr1
        @ernenr1 try this
        https://www.battlehillmedia.com/installing-node-js-and-npm-on-raspberry-pi-3/
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          ernenr1 @sdetweil
          @sdetweil Thank you very much! This actually worked!
            bminer1
            I am not having much luck with this. Been searching and trying everything…
            i@raspberrypi:~ $ node -v
            v10.15.2
            pi@raspberrypi:~ $ npm -v
            • E Offline
              EdO
              I’ve used this to update npm:
              npm install npm@latest -g
                sdetweil @bminer1
                @bminer1 yes, they split the npm install off from the node install… so you have to do two now
                then sudo npm i -g npm ( as it updated the usr/lib folder)
                  sdetweil @EdO
                  @EdO he doesn’t have npm yet… see my post above
                    bminer1
                    This website was exactly what i needed to get the latest version and it worked.
                    https://www.instructables.com/id/Install-Nodejs-and-Npm-on-Raspberry-Pi/
                      sdetweil @bminer1
                      @bminer1 in the future if you use the installer, it will handle this
                        bminer1
                        I went through all of the avenues and this was the only way it stuck.
                        I am creating a second MM Pi so ill try it again on this Pi.
                          sdetweil @bminer1
                          @bminer1 use the new installer script
                          see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
