    Obj.constructor is not a function
    3 Posts 2 Posters 850 Views 2 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      Hi all,
      I have programmed a new module and get this error message in the browser:
      class.js:79 Uncaught TypeError: obj.constructor is not a function
          at cloneObject (class.js:79)
          at cloneObject (class.js:81)
          at Function.Module.create (module.js:435)
          at afterLoad (loader.js:122)
          at loader.js:137
          at HTMLScriptElement.script.onload (loader.js:184)
      This comes up directly after
      Module registered: MMM-testmodule
      The mirror then does not start.
      When I disable the module in the config, the message vanishes and the mirror starts properly.
      Never seen that before. Does anybody know where this comes from?
      Config entry:
              //disabled: true,
              module: "MMM-testmodule",
              position: 'top_left',
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        sdetweil @lavolp3
        @lavolp3 no… can u post your module on gh so I can download it?
        I created a small sample, using same names… it loaded ok…
        but the js file has no useful content…
        • lavolp3L Offline
          @sdetweil I have found the problem.
          I had implemented an emtpy Object in the main module:
          Module.register("MMM-testmodule", {
            defaults: {
            loading: true,
            fetchedData: Object.create(null),
          It didn’t like the Object for some reason.
          But thanks Sam for offering help! You’re a real lighthouse around here!
