    creating a logger to capture module console.log/Log.log output
    5 Posts 2 Posters 950 Views 2 Watching
      I have been fighting some crashes for a while, but using the dev window doesn’t help. it dies when Electron dies…
      I found this logger, and it has helped a LOT…
      thought others would be interested…
      you put the javascript in a file (I used js/logger.js)
      and then add the two lines to the index.html file (change the path/name of the logger.js file to match what you do)
      https://stackoverflow.com/questions/55032227/tips-on-solving-devtools-was-disconnected-from-the-page-and-electron-helper-di/56111557#56111557
      the log file will be in ~/.config/Electron/logs
      (note the leading dot on config)
      • lavolp3L Offline
        lavolp3 Module Developer
        So can we implement it into the code for all to use? What do you think?
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          sdetweil @lavolp3
          @lavolp3 one could submit a PR to include it… wouldn’t want it on all the time, as it will eat up disk space…
          MMM-Logging does similar , but always failed for me when the debugger failed…
          • lavolp3L Offline
            @sdetweil Well, there should be a way to clear the log output once in a while!?
            I’ll test it as well…
              sdetweil @lavolp3
              @lavolp3 one could just erase the files… its just a lot to learn for the newer folks, who are already swamped…
