IR touch frame Calibration help
6 Posts 4 Posters 1.2k Views 4 Watching
    Raz
    Hello im new to this forum i really need some advice I have a magic mirror and im trying to Calibrate it to work on landscape however this dont work how do i rotate the setting for it to work on landscape currently its working on portrait.
      cyberphox
      xinput-calibrator if using a Rasp Pi
        Raz
        @cyberphox said in IR touch frame Calibration help:
        xinput-calibrator
        Thank you for your reply All i know is im using a TV and IR sensors what is Rasp pi?
          cyberphox
          You said you have a Magic Mirror. What are you running it on?
          • S Online
            Rasp Pi is Raspberry Pi
              How to rotate a display on Rasp Pi… Unless you’re not using a Rasp Pi
              https://www.raspberrypi-spy.co.uk/2017/11/how-to-rotate-the-raspberry-pi-display-output/
              As for calibration you should check with manufacturer… I am using a 32" TV with an IR frame so it covers 100% and no calibration was needed.
