    MMM-AssistantMk2
    421 Posts 61 Posters 797.0k Views 57 Watching
      juantata
        juantata
        Good. I have a problem, it has started happening today.
        magicmirror@2.8.0 start /home/pi/MagicMirror
        sh run-start.sh
        Starting MagicMirror: v2.8.0
        Loading config …
        Loading module helpers …
        Module helper loaded: MMM-GoogleMapsTraffic
        No helper found for module: MMM-YouTube.
        No helper found for module: MMM-connection-status.
        Module helper loaded: MMM-Remote-Control
        Module helper loaded: MMM-Hotword
        Module helper loaded: MMM-AssistantMk2
        Module helper loaded: MMM-Spotify
        All module helpers loaded.
        Starting server on port 8080 …
        You’re using a full whitelist configuration to allow for all IPs
        Server started …
        Connecting socket for: MMM-GoogleMapsTraffic
        Starting node_helper for module: MMM-GoogleMapsTraffic
        Starting module: newsfeed
        Connecting socket for: MMM-Remote-Control
        Starting node helper for: MMM-Remote-Control
        Connecting socket for: MMM-Hotword
        [HOTWORD] MMM-Hotword starts
        Connecting socket for: MMM-AssistantMk2
        Connecting socket for: MMM-Spotify
        [SPOTIFY_AUTH] Token is fresh.
        Sockets connected & modules started …
        Launching application.
        ERROR! Could not find main module js file for pir
        Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/juanan+++ioiglesias21%40gmail.com/private-225241cce3b9ecf***011ef3193f0934/basic.ics - Interval: 300000
        Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
        Create new news fetcher for url: https://okdiario.com/feed - Interval: 300000
        [AMK2] Recipe is loaded: hide_and_show_all_modules.js
        [AMK2] Recipe is loaded: reboot.js
        [AMK2] Recipe is loaded: recipe.template.js
        [AMK2] Recipe is loaded: screen_onoff.js
        [AMK2] Recipe is loaded: shutdown.js
        [AMK2] Recipe is loaded: spotify.js
        [AMK2] Temporal storage directory is clearing.
        [HOTWORD] begins.
        [HOTWORD] Detector starts listening.
        [HOTWORD] stops.
        [HOTWORD] Final Result: { detected: false }
        [AMK2] assistant ready
        [AMK2] Conversation starts.
        [AMK2] Started with text query: brief today
        { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
        [AMK2] Device Action: { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ }
        [AMK2] Assistant Text Response:
        [AMK2] Conversation Completed
        [HOTWORD] begins.
        [AMK2] Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
        at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:91:15)
        at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:233:26)
        at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:211:8)
        at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1306:15)
        at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:568:42)
        at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:618:8)
        at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1123:18
        code: 14,
        metadata:
        Metadata { _internal_repr: { ‘content-disposition’: [Array] }, flags: 0 },
        details: ‘Service unavailable.’ }
        [HOTWORD] begins.
        code: 14,
        metadata:
        [HOTWORD] begins.
        ^C
          juantata @Guest
          @Sean
          Today’s summary works perfectly, but then the microphone does not listen and therefore there is no conversation.
          sh run-start.sh
          Loading config …
          Server started …
          [HOTWORD] begins.
          [HOTWORD] stops.
          [HOTWORD] begins.
          code: 14,
          metadata:
          [HOTWORD] begins.
          code: 14,
          metadata:
          [HOTWORD] begins.
          ^C
          ? 1 Reply Last reply
            A Former User @juantata
            @juantata
            Just remove useWelcomeMessage. That feature needs more configuration when using together MMM-Hotword. Not difficult but if you don’t understand what’s going on, just remove it.
            J 1 Reply Last reply
              juantata @Guest
              @Sean
              Thanks for the reply. But one question, if there has never been a problem with the daily summary, why now?
                @juantata
                Just random.
                When using useWelcomMessage, MMM-Hotword’s Mic should be closed. But by physical limitation, Sometimes MMM-Hotword’s mic was not completely closed when MMM-AssistantMk2 activation started. It’s not unpredictable. On the next version, it will be solved.
                J 2 Replies Last reply
                  juantata @Guest
                  @Sean
                  Hi. Thanks for the reply, but I still have the same error
                    juantata @Guest
                    @Sean
                    Hi. Sorry for the insistence. I also show you the MMM-Hotword
                      @juantata
                      What are you using as Mic? That error happens when your mic is not working properly.
                      Show me the result of arecord -l. Did you something on ALSA setup?
                        juantata @Guest
                        @Sean
                        Hi. Thank you for your interest in solving my problem. I realized that what didn’t work was the usb extension cable. Now what goes wrong is the connection between the MMM-Hotword keyword and the questions that can be asked.
                        I send you an image, so you can see it. I have to click with the mouse to put the microphone image
                          @juantata
                          I need log when it is executed. To make things simple, remove all other modules from config.js except MMM-Hotword, MMM-AssistantMk2 and clock. Then try again and show me the logs.
                            juantata @Guest
                            @Sean
                            Hi. Fifthing all the modules except the ones you have said works perfectly.
                            I send you picture
                            sh run-start.sh
                            Loading config …
                            Server started …
                            [HOTWORD] begins.
                            [HOTWORD] stops.
                            { requestId: ‘5de8e91f-0000-248c-a774-089e08231078’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                            [AMK2] Device Action: { requestId: ‘5de8e91f-0000-248c-a774-089e08231078’ }
                            [HOTWORD] begins.
                            [HOTWORD] Detected: asistente
                            [HOTWORD] stops.
                            [HOTWORD] Final Result: { detected: true, hotword: ‘asistente’, file: null }
                            [AMK2] Transcription: qué hora — Done: false
                            [AMK2] Transcription: qué hora es — Done: false
                            [AMK2] end-of-utterance
                            [AMK2] Transcription: qué hora es — Done: true
                            { requestId: ‘5deca769-0000-2b87-a3c0-089e08277c74’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                            [AMK2] Device Action: { requestId: ‘5deca769-0000-2b87-a3c0-089e08277c74’ }
                            [HOTWORD] begins.
                            [HOTWORD] begins.
                            [HOTWORD] stops.
                            [AMK2] Transcription: cómo — Done: false
                            [AMK2] Transcription: cómo va — Done: false
                            [AMK2] Transcription: cómo va a — Done: false
                            [AMK2] Transcription: cómo va a hacer — Done: false
                            [AMK2] Transcription: cómo va a hacer mañana — Done: false
                            [AMK2] Transcription: cómo va a hacer mañana — Done: true
                            { requestId: ‘5dee51e6-0000-2a94-900a-f403043e4840’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                            [AMK2] Device Action: { requestId: ‘5dee51e6-0000-2a94-900a-f403043e4840’ }
                            [HOTWORD] begins.
                            [HOTWORD] stops.
                            [AMK2] Transcription: tiempo — Done: false
                            [AMK2] Transcription: tiempo para — Done: false
                            [AMK2] Transcription: tiempo para mañana — Done: false
                            [AMK2] Transcription: tiempo para mañana — Done: true
                            { requestId: ‘5dee4ec1-0000-2199-8106-f403043e4994’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                            [AMK2] Device Action: { requestId: ‘5dee4ec1-0000-2199-8106-f403043e4994’ }
                            [HOTWORD] begins.
                              @juantata
                              It means some of your other modules might have some errors to prevent the working of AssistantMk2.
                                juantata @Guest
                                @Sean
                                So, I have to try one by one to see which one fails?
                                  @juantata
                                  Maybe.
                                  Or you can use npm start dev to investigate front-end logs on dev-console of MM screen. Anyway, that is out of range which I can help.
                                    juantata @Guest
                                    @Sean
                                    Thank you very much for the help and time you have dedicated to me.
                                      juantata @Guest
                                      @Sean
                                      Hi. Sorry for the inconvenience again. It tells me to update MMM-AssistantMk2, and when I update it it doesn’t stop.
                                        @juantata
                                        If you have no unsatisfying or any issue with current version, You don’t need to update. Not for only this module, but for all modules of MagicMirror, and forMagicMirror itself. This is my personal recommendation.
                                        The error means you’d modified the source (Why?) Usually, a user doesn’t need to (SHOULDN’T) do modifying the source itself.
                                        Don’t do what you don’t understand.
                                        However you want to update anyway, just remove those files then git pull again. (If not work, try git stash)
                                          berne
                                          @Sean said in MMM-AssistantMk2:
                                          -Multi profile and language demo
                                          mmm so i can use google assistant and speak Swedish to it in the new mk2?
                                          if so… im going to make a new build
                                            A Former User @berne
                                            @berne
                                            Swedish is not supported by Google officially yet.
                                            https://developers.google.com/assistant/sdk/reference/rpc/languages
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 20 / 22
