    MMM-AssistantMk2
    421 Posts 61 Posters 691.1k Views 57 Watching
      juantata @Guest
      @Sean
      Good. I have a problem, it has started happening today.
      Today’s summary works perfectly, but then the microphone does not listen and therefore there is no conversation.
      magicmirror@2.8.0 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.8.0
      Loading config …
      Loading module helpers …
      Module helper loaded: MMM-GoogleMapsTraffic
      No helper found for module: MMM-YouTube.
      No helper found for module: MMM-connection-status.
      Module helper loaded: MMM-Remote-Control
      Module helper loaded: MMM-Hotword
      Module helper loaded: MMM-AssistantMk2
      Module helper loaded: MMM-Spotify
      All module helpers loaded.
      Starting server on port 8080 …
      You’re using a full whitelist configuration to allow for all IPs
      Server started …
      Connecting socket for: MMM-GoogleMapsTraffic
      Starting node_helper for module: MMM-GoogleMapsTraffic
      Starting module: newsfeed
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: MMM-Hotword
      [HOTWORD] MMM-Hotword starts
      Connecting socket for: MMM-AssistantMk2
      Connecting socket for: MMM-Spotify
      [SPOTIFY_AUTH] Token is fresh.
      Sockets connected & modules started …
      Launching application.
      ERROR! Could not find main module js file for pir
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/juanan+++ioiglesias21%40gmail.com/private-225241cce3b9ecf***011ef3193f0934/basic.ics - Interval: 300000
      Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
      Create new news fetcher for url: https://okdiario.com/feed - Interval: 300000
      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
      [AMK2] Recipe is loaded: reboot.js
      [AMK2] Recipe is loaded: recipe.template.js
      [AMK2] Recipe is loaded: screen_onoff.js
      [AMK2] Recipe is loaded: shutdown.js
      [AMK2] Recipe is loaded: spotify.js
      [AMK2] Temporal storage directory is clearing.
      [HOTWORD] begins.
      [HOTWORD] Detector starts listening.
      [HOTWORD] stops.
      [HOTWORD] Final Result: { detected: false }
      [AMK2] assistant ready
      [AMK2] Conversation starts.
      [AMK2] Started with text query: brief today
      { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
      [AMK2] Device Action: { requestId: ‘5deab96c-0000-2e12-9cee-f403043d40d8’ }
      [AMK2] Assistant Text Response:
      [AMK2] Conversation Completed
      [HOTWORD] begins.
      [AMK2] Conversation Error: { Error: 14 UNAVAILABLE: Service unavailable.
      at Object.exports.createStatusError (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/common.js:91:15)
      at ClientDuplexStream._emitStatusIfDone (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:233:26)
      at ClientDuplexStream._receiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js:211:8)
      at Object.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1306:15)
      at InterceptingListener._callNext (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:568:42)
      at InterceptingListener.onReceiveStatus (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:618:8)
      at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:1123:18
      code: 14,
      metadata:
      Metadata { _internal_repr: { ‘content-disposition’: [Array] }, flags: 0 },
      details: ‘Service unavailable.’ }
      [HOTWORD] begins.
      code: 14,
      metadata:
      [HOTWORD] begins.
      ^C
        A Former User @juantata
        @juantata
        Just remove useWelcomeMessage. That feature needs more configuration when using together MMM-Hotword. Not difficult but if you don’t understand what’s going on, just remove it.
          juantata @Guest
          @Sean
          Thanks for the reply. But one question, if there has never been a problem with the daily summary, why now?
            @juantata
            Just random.
            When using useWelcomMessage, MMM-Hotword’s Mic should be closed. But by physical limitation, Sometimes MMM-Hotword’s mic was not completely closed when MMM-AssistantMk2 activation started. It’s not unpredictable. On the next version, it will be solved.
              juantata @Guest
              @Sean
              Hi. Thanks for the reply, but I still have the same error
                juantata @Guest
                @Sean
                Hi. Sorry for the insistence. I also show you the MMM-Hotword
                  @juantata
                  What are you using as Mic? That error happens when your mic is not working properly.
                  Show me the result of arecord -l. Did you something on ALSA setup?
                    juantata @Guest
                    @Sean
                    Hi. Thank you for your interest in solving my problem. I realized that what didn’t work was the usb extension cable. Now what goes wrong is the connection between the MMM-Hotword keyword and the questions that can be asked.
                    I send you an image, so you can see it. I have to click with the mouse to put the microphone image
                      @juantata
                      I need log when it is executed. To make things simple, remove all other modules from config.js except MMM-Hotword, MMM-AssistantMk2 and clock. Then try again and show me the logs.
                        juantata @Guest
                        @Sean
                        Hi. Fifthing all the modules except the ones you have said works perfectly.
                        I send you picture
                        sh run-start.sh
                        Loading config …
                        Server started …
                        [HOTWORD] begins.
                        [HOTWORD] stops.
                        { requestId: ‘5de8e91f-0000-248c-a774-089e08231078’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                        [AMK2] Device Action: { requestId: ‘5de8e91f-0000-248c-a774-089e08231078’ }
                        [HOTWORD] begins.
                        [HOTWORD] Detected: asistente
                        [HOTWORD] stops.
                        [HOTWORD] Final Result: { detected: true, hotword: ‘asistente’, file: null }
                        [AMK2] Transcription: qué hora — Done: false
                        [AMK2] Transcription: qué hora es — Done: false
                        [AMK2] end-of-utterance
                        [AMK2] Transcription: qué hora es — Done: true
                        { requestId: ‘5deca769-0000-2b87-a3c0-089e08277c74’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                        [AMK2] Device Action: { requestId: ‘5deca769-0000-2b87-a3c0-089e08277c74’ }
                        [HOTWORD] begins.
                        [HOTWORD] begins.
                        [HOTWORD] stops.
                        [AMK2] Transcription: cómo — Done: false
                        [AMK2] Transcription: cómo va — Done: false
                        [AMK2] Transcription: cómo va a — Done: false
                        [AMK2] Transcription: cómo va a hacer — Done: false
                        [AMK2] Transcription: cómo va a hacer mañana — Done: false
                        [AMK2] Transcription: cómo va a hacer mañana — Done: true
                        { requestId: ‘5dee51e6-0000-2a94-900a-f403043e4840’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                        [AMK2] Device Action: { requestId: ‘5dee51e6-0000-2a94-900a-f403043e4840’ }
                        [HOTWORD] begins.
                        [HOTWORD] stops.
                        [AMK2] Transcription: tiempo — Done: false
                        [AMK2] Transcription: tiempo para — Done: false
                        [AMK2] Transcription: tiempo para mañana — Done: false
                        [AMK2] Transcription: tiempo para mañana — Done: true
                        { requestId: ‘5dee4ec1-0000-2199-8106-f403043e4994’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
                        [AMK2] Device Action: { requestId: ‘5dee4ec1-0000-2199-8106-f403043e4994’ }
                        [HOTWORD] begins.
                          @juantata
                          It means some of your other modules might have some errors to prevent the working of AssistantMk2.
                            juantata @Guest
                            @Sean
                            So, I have to try one by one to see which one fails?
                              @juantata
                              Maybe.
                              Or you can use npm start dev to investigate front-end logs on dev-console of MM screen. Anyway, that is out of range which I can help.
                                juantata @Guest
                                @Sean
                                Thank you very much for the help and time you have dedicated to me.
                                  juantata @Guest
                                  @Sean
                                  Hi. Sorry for the inconvenience again. It tells me to update MMM-AssistantMk2, and when I update it it doesn’t stop.
                                    @juantata
                                    If you have no unsatisfying or any issue with current version, You don’t need to update. Not for only this module, but for all modules of MagicMirror, and forMagicMirror itself. This is my personal recommendation.
                                    The error means you’d modified the source (Why?) Usually, a user doesn’t need to (SHOULDN’T) do modifying the source itself.
                                    Don’t do what you don’t understand.
                                    However you want to update anyway, just remove those files then git pull again. (If not work, try git stash)
                                      berne
                                      @Sean said in MMM-AssistantMk2:
                                      -Multi profile and language demo
                                      mmm so i can use google assistant and speak Swedish to it in the new mk2?
                                      if so… im going to make a new build
                                        A Former User @berne
                                        @berne
                                        Swedish is not supported by Google officially yet.
                                        https://developers.google.com/assistant/sdk/reference/rpc/languages
                                        • T Offline
                                          tontonchow
                                          Hi
                                          This module is fine but I I can’t get it to work in French. When I call “jarvis”, mk2 assistant don’t undertand french, only english. Someone have the same issue ?
                                            A Former User @tontonchow
                                            @tontonchow
                                            simply, adjust your account setting on your google assistant app of your smartphone.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 20 / 22
