    MMM-AssistantMk2
    421 Posts 61 Posters 744.2k Views 57 Watching
      juantata @Guest
      @Sean
      Hi. Fifthing all the modules except the ones you have said works perfectly.
      I send you picture
      magicmirror@2.8.0 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.8.0
      Loading config …
      Loading module helpers …
      Module helper loaded: MMM-Hotword
      Module helper loaded: MMM-AssistantMk2
      All module helpers loaded.
      Starting server on port 8080 …
      You’re using a full whitelist configuration to allow for all IPs
      Server started …
      Connecting socket for: MMM-Hotword
      [HOTWORD] MMM-Hotword starts
      Connecting socket for: MMM-AssistantMk2
      Sockets connected & modules started …
      Launching application.
      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
      [AMK2] Recipe is loaded: reboot.js
      [AMK2] Recipe is loaded: recipe.template.js
      [AMK2] Recipe is loaded: screen_onoff.js
      [AMK2] Recipe is loaded: shutdown.js
      [AMK2] Recipe is loaded: spotify.js
      [HOTWORD] begins.
      [HOTWORD] Detector starts listening.
      [AMK2] Temporal storage directory is clearing.
      [HOTWORD] stops.
      [AMK2] assistant ready
      [AMK2] Conversation starts.
      [AMK2] Started with text query: brief today
      { requestId: ‘5de8e91f-0000-248c-a774-089e08231078’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
      [AMK2] Device Action: { requestId: ‘5de8e91f-0000-248c-a774-089e08231078’ }
      [AMK2] Assistant Text Response:
      [AMK2] Conversation Completed
      [HOTWORD] begins.
      [HOTWORD] Detected: asistente
      [HOTWORD] stops.
      [HOTWORD] Final Result: { detected: true, hotword: ‘asistente’, file: null }
      [AMK2] Transcription: qué hora — Done: false
      [AMK2] Transcription: qué hora es — Done: false
      [AMK2] end-of-utterance
      [AMK2] Transcription: qué hora es — Done: true
      { requestId: ‘5deca769-0000-2b87-a3c0-089e08277c74’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
      [AMK2] Device Action: { requestId: ‘5deca769-0000-2b87-a3c0-089e08277c74’ }
      [HOTWORD] begins.
      [HOTWORD] Final Result: { detected: false }
      [HOTWORD] begins.
      [HOTWORD] stops.
      [AMK2] Transcription: cómo — Done: false
      [AMK2] Transcription: cómo va — Done: false
      [AMK2] Transcription: cómo va a — Done: false
      [AMK2] Transcription: cómo va a hacer — Done: false
      [AMK2] Transcription: cómo va a hacer mañana — Done: false
      [AMK2] Transcription: cómo va a hacer mañana — Done: true
      { requestId: ‘5dee51e6-0000-2a94-900a-f403043e4840’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
      [AMK2] Device Action: { requestId: ‘5dee51e6-0000-2a94-900a-f403043e4840’ }
      [HOTWORD] begins.
      [HOTWORD] stops.
      [AMK2] Transcription: tiempo — Done: false
      [AMK2] Transcription: tiempo para — Done: false
      [AMK2] Transcription: tiempo para mañana — Done: false
      [AMK2] Transcription: tiempo para mañana — Done: true
      { requestId: ‘5dee4ec1-0000-2199-8106-f403043e4994’ } { profileFile: ‘default.json’, lang: ‘es-ES’ }
      [AMK2] Device Action: { requestId: ‘5dee4ec1-0000-2199-8106-f403043e4994’ }
      [HOTWORD] begins.
        [[global:former-user]] @juantata
        @juantata
        It means some of your other modules might have some errors to prevent the working of AssistantMk2.
          juantata @Guest
          @Sean
          So, I have to try one by one to see which one fails?
            @juantata
            Maybe.
            Or you can use npm start dev to investigate front-end logs on dev-console of MM screen. Anyway, that is out of range which I can help.
              juantata @Guest
              @Sean
              Thank you very much for the help and time you have dedicated to me.
                juantata @Guest
                @Sean
                Hi. Sorry for the inconvenience again. It tells me to update MMM-AssistantMk2, and when I update it it doesn’t stop.
                  @juantata
                  If you have no unsatisfying or any issue with current version, You don’t need to update. Not for only this module, but for all modules of MagicMirror, and forMagicMirror itself. This is my personal recommendation.
                  The error means you’d modified the source (Why?) Usually, a user doesn’t need to (SHOULDN’T) do modifying the source itself.
                  Don’t do what you don’t understand.
                  However you want to update anyway, just remove those files then git pull again. (If not work, try git stash)
                    berne
                    @Sean said in MMM-AssistantMk2:
                    -Multi profile and language demo
                    mmm so i can use google assistant and speak Swedish to it in the new mk2?
                    if so… im going to make a new build
                      [[global:former-user]] @berne
                      @berne
                      Swedish is not supported by Google officially yet.
                      https://developers.google.com/assistant/sdk/reference/rpc/languages
                      • T Offline
                        tontonchow
                        Hi
                        This module is fine but I I can’t get it to work in French. When I call “jarvis”, mk2 assistant don’t undertand french, only english. Someone have the same issue ?
                          [[global:former-user]] @tontonchow
                          @tontonchow
                          simply, adjust your account setting on your google assistant app of your smartphone.
                          • T Offline
                            tontonchow @Guest
                            @Sean my app is correctly configure for me. If he don’t understand histoire reply is in french but if i speak french he don’t understand.
                            Étrange
                              @tontonchow
                              Weird. Transcription on the log is returned as French as expected?
                              • T Offline
                                tontonchow @Guest
                                @Sean Yes
                                I don’t know why but it seems to work after adjust config.js and reboot
                                add , after lang line
                                profiles: {
                                         "default" : {
                                                    profileFile: "default.json",
                                                    lang: "fr-FR",
                                  @tontonchow
                                  Can you show me the log of transcription part when you said some phrases as French? To see whether transcription was recognized as French or not.
                                    MisterT
                                    Hi Sean,
                                    Nice works for MK2 update but i have a problem to install it. I launched the auto installation but a packet is not found. gcc-7 is missing. when a try to install manually the answer is (in french):
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ sudo apt-get install gcc-7
                                    Lecture des listes de paquets... Fait
                                    Construction de l'arbre des dépendances
                                    Lecture des informations d'état... Fait
                                    E: Impossible de trouver le paquet gcc-7
                                    when i write gcc -v the result is:
                                    gcc version 6.3.0 20170516 (Raspbian 6.3.0-18+rpi1+deb9u1)
                                    And without this my Magic mirror turn into a black screen
                                    How i can install gcc-7 ?
                                    Do i need an update of raspbian to install gcc-7. I’m on last version of raspbian Stretch
                                    Thanks for your support and your next answers
                                      [[global:former-user]] @MisterT
                                      @MisterT
                                      first, try to install without gcc7. usually gcc8 on buster was a reason of problem, so gcc6 on stretch might be ok(not tested currently but it worked a year ago)
                                        MisterT
                                        hi @Sean thanks for your reply. So retry auto installation with gc6 and rebuild electron. Then finish the config with my audio and mic. Great
                                        After these, i download my credentials then make my default profile.
                                        So everithing seem to bo good. that’t why i start MM and:
                                        MK2v3 logo is on my Magic mirror with animation but when i say a simple sentence, nothing happen.
                                        I changed hotword word to Jarvis and html5 to mpg321 but it’s the same thing.
                                        See below my config js for hotword and MK2
                                        	module: "MMM-Hotword",
                                        	useDisplay: false,
                                        	chimeOnFinish: null,
                                        	recipes: ["with-AMk2v3_Jarvis.js"],
                                        	mic: {
                                        		recordProgram: "arecord",
                                        		device: "plughw:1",
                                          	module: "MMM-AssistantMk2",
                                        	debug: true,
                                        	 ui: "Classic",
                                        	assistantConfig: {
                                        	latitude: 43.64074, // -90.0 - +90.0
                                        	longitude: 5.09545, // -180.0 - +180.0
                                        	responseConfig: {
                                        	useHTML5: false, // sound render by HTML5
                                        	playProgram: "mpg321",
                                        	micConfig: {
                                        	recorder: "arecord",
                                        	device: "plughw:1",
                                        	recipes: [
                                        	"with-MMM-Hotword.js"
                                        	profiles: {
                                        	"default": {
                                        			lang: "fr-FR"
                                        have you an idea ?
                                          @MisterT
                                          Need a log to know what happens.
                                            MisterT @Guest
                                            @Sean after uninstall, re install, rebuilt electron from MK2 and from Hotword, it was always the same.
                                            So i decided to start a simple config.js with only default modules and Mk2 and hotword. Finaly…Tada !!! it works.
                                            The guilty module is MMM-GooglemapsTraffic. So I hid it in my config.js
                                            I have no console log about Mk2 if MMM-GooglemapsTraffic is on.
                                            Have you an idea?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 20 / 22
