    MMM-CalendarExt2
    486 Posts 83 Posters 1.1m Views 83 Watching
      cskenney @Guest
      @Sean I have the rotateInterval set to 0 and the updateInterval set to (5 minutes).
      I will post my code below but I will need to removed the URL to my calendars.
      		{	/*MMM-CalendardExt2*/
      			module: 'MMM-CalendarExt2',
      				rotateInterval: 0,	//rotate between scenes default = 60*1000; 0 disables
      				updateInterval: 5*60*1000,	//If not auto-rotated
      				firstDrawingDelay: 10*1000,	//delay to allow calendar parsing
      				locale: "en",
      				defaultSet: {
      						calendars: {
      							maxItems: 500,
      							scanInterval: 1000*60*5,
      							beforeDays: 5,
      							afterDays: 60,
      							maxIterations: 100,
      						view: {
      							timeFormat: "h:mm A",
      							transform: function(event) {
      								if (event.title.search("Panic") > -1) {
      								event.icon = "noto-softball";
      								event.className = "view_panic";
      								} else if (event.title.search("Arin") > -1) {
      								} else if (event.title.search("Violin") > -1) {
      								event.icon = "emojione-monotone:violin";
      								return event;
      						scene: {}
      						url: "https://calendar.google.com/calendar/ical...basic.ics",
      						className: "cal_chris",
      						icon: "twemoji-medical-symbol",
      						className: "cal_kim",
      						className: "cal_lauren",
      						className: "cal_ryan",
      						name: "MHS Softball",
      						url: "https://calendar.google.com/calendar/ical/...basic.ics",
      						icon: "noto:softball",
      						className: "cal_mhs_softball",
      						name: "Softball Badgers",
      						icon: "noto-badger",
      						className: "cal_badgersoftball",
      						icon: "emojione-musical-score",
      						className: "cal_bopa",
      				views:[
      						mode: "daily",
      						calendars: ["Chris","Kim","Lauren","Ryan","MHS Softball","Softball Badgers","BOPA"],
      						hideOverflow: false,
      						filterPassedEvent: false,
      						slotCount: 2,
      						maxItems: 500,
      						mode: "upcoming",
      						slotTitle: "UPCOMING",
      						position: "top_center",
      						maxItems:10,
      						maxDays: 3,
      						filterPassedEvent: true,
      						className: "views_upcoming",
      						title: "CALENDAR",
      						mode: "daily",
      						type: "row",
      						position: "bottom_bar",
      						maxItems: 500,
      						slotCount: 5,
      				scenes:[
      						views: ["View_Daily","View_5D_Overview"],
      						className: "Scene_Default",
      		},//end of calendarext2 module
      ? 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer
        hey, Sean -
        three minor issues and I got my install perfect:
        1. I’m trying to set up a wider slot for the calendar - I’ve got the region expanded and adjusted, but how do I get the item slots to match?:
        .region.top.center {
          left: 40%;
          -moz-transform: translateX(-40%);
          -o-transform: translateX(-40%);
          -webkit-transform: translateX(-40%);
          -ms-transform: translateX(-40%);
          min-width: 750px;
        1. I’d like to get rid of the refresh fade. I find it annoying - how to do so?
        2. When I have the “Seahawks” calendar enabled, only the trash calendar loads initially, and after first refresh, the others come in. Can you help with why?
        					calendars : [
        							url: "https://calendar.google.com/calendar/ical/PRIVATE",
        							name: "Main Calendar", // Optional, Recommended
        							maxItems: 100,
        							scanInterval: 1000*60*1, // every minute, Appt Book, needs this speed
        							beforeDays: 0,
        							afterDays: 999,
        							maxIterations: 999,
        							forceLocalTZ: false,
        							url: "https://calendar.google.com/calendar/ical/PRIVATE2",
        							name: "Trash Calendar", // Optional, Recommended
        							maxItems: 100,
        							scanInterval: 24*60*60*1000, // Once a day
        							beforeDays: 0,
        							afterDays: 999,
        							maxIterations: 999,
        							url: "http://www.trumba.com/calendars/seattle-seahawks-schedule.ics",
        							name: "Seahawks Calendar",
        							maxItems: 100,
        							scanInterval: 24*60*60*1000, // Once a day (Is once a week acceptable???)
        							beforeDays: 0,
        							afterDays: 999,
        							maxIterations: 999,
        					views: [
        							mode: "daily",
        							slotCount: 99,
        							timeFormat:"h:mm A",
        							className: "remove_empty_slot",
        							calendars: ["Main Calendar","Trash Calendar","Seahawks Calendar"],
        								if (event.title.search("Recycle") > -1) {
        									event.icon = "mdi:recycle";
        								if (event.title.search("Yard Waste") > -1) {
        									event.icon = "entypo-leaf";
        								if (event.title.search("Seahawks") > -1) {
        									event.icon = "fa-solid:football-ball";
        								return event;
        					scenes: [
        Edit: I guess I have a fourth - I’d like to adjust anything to do with Seahawks (the transform above) to have the inverse color like an all day event. Possible?
          A Former User @cskenney
          @cskenney
          That will take 5 minutes to refresh displaying. However, That’s not synced to scanInterval(Those are individual for each other), so, at most 10 minutes could be taken to show modified events in unlucky case.
          C 1 Reply Last reply
            A Former User @BKeyport
            @BKeyport
            Overwrite these values in your css/custom.css
            1. Adjust default size: (If you want to modifying on specific view, choose a proper CSS Selectors)
              https://github.com/eouia/MMM-CalendarExt2/wiki/4.-Styling
            .CX2 { /* default values which are used frequently or dependently */
              --row-min-width: 100px;
              --row-max-width: 1000px;
              --column-min-width: 300px;
              --column-max-width: 400px;
              --font-size: 16px;
            1. Adjust css animation duration; Or change animation-name to any other improper name.
            .CX2.hidden {
              opacity:0;
              animation-name: fadeOutOpacity;
              animation-iteration-count: 1;
              animation-timing-function: ease-in;
              animation-duration: 0.5s;
            .CX2.shown {
              display:block;
              opacity: 1;
              animation-name: fadeInOpacity;
            1. That is because just parsing of other calendars is not finished before the first drawing of current loaded events. Just wait, in the next turn remains will be displayed.
              Or set enough time of firstDrawingDelay to wait for all the parsing be completed.
              https://github.com/eouia/MMM-CalendarExt2/wiki/2e.-Configuration:Others
            2. Give the className to your targetted events like what you do with icon. Define CSS styles with that className.
            BKeyportB 1 Reply Last reply
              cskenney @Guest
              @Sean I understand that they are not synced. I can run a test where I set both values to 1 minute (each). I can then make a change in my calendar then come back to the MM 10 minutes later and nothing has changed.
              Last night I added an item to my calendar and waited for a couple of hours and it never appeared. Today it is added to the MM calendar. It is like it finally refreshed at midnight when it had to adjust the days.
              I am now left wondering if the scanInterval in the default section is actually only used at startup and at midnight.
              Edit: I added the scanInterval into the section for a specific calendar and it solved the problem. It looks like when the scanInterval is in the default section that it must not be applied to each calendar. The result is that each calendar is only scanned once per day (or so it seems).
                @cskenney
                Not at all.
                I tested this; I gave 20seconds for updateInterval and scanInterval
                At start there was no event to show;
                In a minute, I added a test event on my google calendar;
                log says There happend 1 event added at that time. (See Scanned and Selected)
                And the screen was changed.(See the time of the clock.)
                  cskenney @Guest
                  @Sean where is this log file located? I will take a look at it and see what I can find.
                    @cskenney
                    If you want to see the log on real time;
                    first stop your pm2 (if you are using), then npm start dev on your MagicMirror directory.
                    C BKeyportB 2 Replies Last reply
                    • BKeyportB
                      BKeyport Module Developer @Guest
                      @Sean said in MMM-CalendarExt2:
                      is there a way to set priority of loading? If the trumba calendar referenced (Seahawks) is causing issues, I’d rather my main calendar loads first (Hold display until loaded), then the “trash” calendar, then the Trumba calendar. If not, feature request.
                      Thanks again, Love being able to make this exactly the way I want.
                        @BKeyport
                        It would be over spec I think. Because;
                        • This symptom would be improved by delayFirstDrawing to some degree. I think a few seconds would be enough to complete all parsing. If some calendar would take over 10 seconds, it would be the connection issue not parsing issue.
                        • This symptom would be issued on short time only when MM starts. Usually, after the first cycle of refreshing, this issue would be gone away.
                        • None the less assigning priority, there would be no guarantee for the specific calendar completing to parse first. The main reason for this delay lays in the network connection quality between your RPI and the calendar server.
                        Anyway thanks for the suggestion. I’ll research more.
                          cskenney @Guest
                          @Sean I think I have it figured out now. If looks like putting the calendar scanInterval in the default section (look at the code I posted above) doesn’t apply it to all the calendars. Instead it looks like they are using a default value of 30 minutes. Does that make sense?
                          ? 3 Replies Last reply
                            @cskenney
                            Hmmm. without real ical data, I can’t say anything about your case. Configuration itself seems nothing wrong.
                            When I changed your updateInterval to 1000*30, it refreshes per 30 seconds.
                            If you don’t mind, send me your configuration with real ical URL. my email is eouia0819@gmail.com
                              @cskenney
                              Wait a sec. I think found something.
                                @cskenney
                                You have a mistyping in defaultSet. Not calendars, Fix it to calendar
                                • BKeyportB
                                  @Sean You can also do it through PM2 directly.
                                  In a second session run “pm2 logs” – it’ll live update the logs on that session’s screen.
                                    cskenney @Guest
                                    @Sean That did the trick. You used Calendars (with an S) for the main code section but the default section only used calendar (without the s). I didn’t notice the syntax difference. Thanks for the help.
                                      @cskenney
                                      Because calendar of defaultSet would be applied to each calendar of calendars:[]. But anyway, my English is not so good so there could be confusing.
                                        cskenney @Guest
                                        @Sean No, it’s fine. I just didn’t notice the syntax difference when I created the default section.
                                        Thanks again for your help.
                                        • LordyL
                                          Lordy
                                          The two things were only added after the installation of “MMM-Page-Selector”.
                                          Do you know how I remove the “module name (red)” and the “module counter blue”?
                                          It is somehow related to the module.
                                          I hope Sean, can you help me?
                                            A Former User @Lordy
                                            @Lordy
                                            Remove postion of module. This module doesn’t need it.
                                            LordyL 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 24
                                            • 25
                                            • 10 / 25
