    Which Editor do you get for windows
    17 Posts 4 Posters 5.2k Views 4 Watching
    • kusselinK Offline
      kusselin
      Hello all,
      can you sy me what bzw. which editor do you get to edit the config?
        [[global:former-user]] @kusselin
        @kusselin
        on RPI terminal, nano or vi.
        But usually, I prefer to connect remotely via SSH. So atom on my dev machine.
        • kusselinK Offline
          kusselin
          Ok thanks, i have Windows and notepad++ bunt its not good working. Do you mean i have to work with Atom on windows?
            @kusselin
            There is no "have to" thing.
            Well, there would be many good IDEs besides atom. For example; Microsoft Visual Studio Code.
            But some ppl hate to use heavy IDE, so they could prefer more simpler like notepad++. Even someone might prefer to use just notepad or wordpad.
            Just for me, I like atom.
            • BKeyportB Offline
              BKeyport Module Developer
              I use Geany. https://www.geany.org/
                sdetweil @Guest
                @Sean said in Which Editor do you get for windows:
                @kusselin
                I use notepad++ on windows, and the free bitvise ssh client. https://bitvise.com/ssh-client
                the bitvise client opens both an SSH terminal window and a windows like file navigation window
                notepad++ can save files with windows or linux line ends (and decide automatically if u want)
                I have 5 system connections open at once, with multiple commandlines on one (run stuff, debug from another window, monitor cpu use in another)
                to my pi 4 system
                • kusselinK Offline
                  kusselin
                  Ok, because now i have Problem with copy and Paste with notepad ++. Which Settings do you have in notepad under options? Can you Post it please?
                  When i User Herr in the Forum Post me a Script like this Here:
                  module: ‘MMM-Tankerkoenig’,
                  header: ‘Super (E10)’,
                  position: ‘top_right’,
                  updateInterval: 600,
                  maxWidth: “300px”,// die angegeben 200px verursachen unschöne Zeilenumbrüche
                  api_key: “Xxxxx”,
                  lat: 49.398750, // das sind die Koordinaten von Heidelberg/Mitte, siehe https://www.latlong.net
                  lng: 8.672434,
                  type: “e10”, // alternativ “e5” oder “diesel”
                  radius: 1, // Suche in 1km Umkreis (in 5km Umkreis passt die Liste nicht mehr auf den Bildschirm)
                  And i Paste this code in my config, and restart the mirror a Text is Commonwealth on screen with config file and no mirror.
                  Best regards
                  ? S 2 Replies Last reply Reply Quote 0
                  • kusselinK Offline
                    kusselin
                    Is this right with the ˋ´ behause in someone configs you Can See ““ between tankerkönig
                      @kusselin
                      I think the error might be caused by ’ and ”. Those are not allowed as quotation marks of javascript language.
                      should be
                      module: 'MMM-Tankerkoenig',
                      Others are same.
                      You can find&replace in your notepad++
                        sdetweil @kusselin
                        @kusselin sorry, I do not understand…
                        cut/paste is builtin and not special.
                        as per Sean’s post, those appear to be quotes from MS word type documents,.
                        MagicMirror needs text quotes, " and ’
                        • kusselinK Offline
                          kusselin
                          @sdetweil: you Wrote that magic mirror Need " …Sean Said i Must take ’
                          What is now right? Sorry For my questions
                            sdetweil @kusselin
                            @kusselin either will work, as long as both ends of the quote use the same type
                            this is ok
                            "testing"
                            'testing'
                            this is not
                            "testing'
                            • kusselinK Offline
                              kusselin
                              Ah ok i Unterstand.
                              Ok the this is Not ok right:
                              api_key: “xxxxxxx”,
                              lat: 49.506240, // das sind die Koordinaten von Heidelberg/Mitte, siehe https://www.latlong.net
                              lng: 8.656140,
                              It Must be " or ’ … right?
                                sdetweil @kusselin
                                @kusselin correct, like this using using
                                " or '
                                (note that these do not lean in any direction and do not have little tails)
                                ’ this one leans to the right
                                	header: 'Super (E10)',
                                	position: 'top_right',
                                		maxWidth: "300px",// die angegeben 200px verursachen unschöne Zeilenumbrüche
                                		api_key: "xxxxxxxx",
                                		lng: 8.656140,
                                		type: "e10", // alternativ "e5" oder "diesel"
                                • kusselinK Offline
                                  kusselin
                                  Ok thanks… Can you please Cancel the api key thanks
                                  • kusselinK Offline
                                    kusselin
                                    Ok and when i copy it than is the String Not straight on… Rather Little tails
                                    • kusselinK Offline
                                      kusselin
                                      Thanks all 👍
                                      difficult birth 🙈
