    Which Editor do you get for windows
    17 Posts 4 Posters 4.6k Views 4 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      I use Geany. https://www.geany.org/
        sdetweil @Guest
        @Sean said in Which Editor do you get for windows:
        @kusselin
        There is no "have to" thing.
        Well, there would be many good IDEs besides atom. For example; Microsoft Visual Studio Code.
        But some ppl hate to use heavy IDE, so they could prefer more simpler like notepad++. Even someone might prefer to use just notepad or wordpad.
        Just for me, I like atom.
        I use notepad++ on windows, and the free bitvise ssh client. https://bitvise.com/ssh-client
        the bitvise client opens both an SSH terminal window and a windows like file navigation window
        notepad++ can save files with windows or linux line ends (and decide automatically if u want)
        I have 5 system connections open at once, with multiple commandlines on one (run stuff, debug from another window, monitor cpu use in another)
        to my pi 4 system
        • kusselinK Offline
          kusselin
          Ok, because now i have Problem with copy and Paste with notepad ++. Which Settings do you have in notepad under options? Can you Post it please?
          When i User Herr in the Forum Post me a Script like this Here:
          module: ‘MMM-Tankerkoenig’,
          header: ‘Super (E10)’,
          position: ‘top_right’,
          updateInterval: 600,
          maxWidth: “300px”,// die angegeben 200px verursachen unschöne Zeilenumbrüche
          api_key: “Xxxxx”,
          lat: 49.398750, // das sind die Koordinaten von Heidelberg/Mitte, siehe https://www.latlong.net
          lng: 8.672434,
          type: “e10”, // alternativ “e5” oder “diesel”
          radius: 1, // Suche in 1km Umkreis (in 5km Umkreis passt die Liste nicht mehr auf den Bildschirm)
          And i Paste this code in my config, and restart the mirror a Text is Commonwealth on screen with config file and no mirror.
          Best regards
          ? S 2 Replies Last reply Reply Quote 0
          • kusselinK Offline
            kusselin
            Is this right with the ˋ´ behause in someone configs you Can See ““ between tankerkönig
              A Former User @kusselin
              @kusselin
              I think the error might be caused by ’ and ”. Those are not allowed as quotation marks of javascript language.
              should be
              module: 'MMM-Tankerkoenig',
              Others are same.
              You can find&replace in your notepad++
                sdetweil @kusselin
                @kusselin sorry, I do not understand…
                cut/paste is builtin and not special.
                as per Sean’s post, those appear to be quotes from MS word type documents,.
                MagicMirror needs text quotes, " and ’
                • kusselinK Offline
                  kusselin
                  @sdetweil: you Wrote that magic mirror Need " …Sean Said i Must take ’
                  What is now right? Sorry For my questions
                    sdetweil @kusselin
                    @kusselin either will work, as long as both ends of the quote use the same type
                    this is ok
                    "testing"
                    'testing'
                    this is not
                    "testing'
                    • kusselinK Offline
                      kusselin
                      Ah ok i Unterstand.
                      Ok the this is Not ok right:
                      api_key: “xxxxxxx”,
                      lat: 49.506240, // das sind die Koordinaten von Heidelberg/Mitte, siehe https://www.latlong.net
                      lng: 8.656140,
                      It Must be " or ’ … right?
                        sdetweil @kusselin
                        @kusselin correct, like this using using
                        " or '
                        (note that these do not lean in any direction and do not have little tails)
                        ’ this one leans to the right
                        	header: 'Super (E10)',
                        	position: 'top_right',
                        		maxWidth: "300px",// die angegeben 200px verursachen unschöne Zeilenumbrüche
                        		api_key: "xxxxxxxx",
                        		lng: 8.656140,
                        		type: "e10", // alternativ "e5" oder "diesel"
