    Who is home? Presence tracking
    17 Posts 7 Posters 7.9k Views 8 Watching
    • T
      tc60045
      And this is what I was thinking about for layout:
      ? 1 Reply Last reply
        A Former User @tc60045
        @tc60045
        Like this?
        After more tests, will be released.
        ADDED
        Now I’m adding additional feature - command executing when Someone entered or exited. (e.g: Play Spotify when Dad entered Home)
        T 1 Reply Last reply
        • T
          tc60045 @Guest
          @Sean – yes! But please tell me you are using geo location and not MAC address / ARP results snippet from iOS security guide discussed here?
          I want to create many locations based on geofencing. How can I / we help you with this?
            @tc60045 I didn’t use MAC Address. I just put who: "dad", location:"Home" in body of IFTTT recipe. I think each recipe should be created per people and location, so hardcoded is enough.
            • T
              tc60045 @Guest
              @Sean PERFECT – thank you. Can’t wait to test!
                @tc60045 Here is midnight, so I’ll go to sleep at this moment. Tomorrow I’ll release it after some tests. You can help me to test, and to make a manual (English is not my mother tongue, so… :D)
                  A Former User
                  [card:eouia/MMM-Whereis]
                  alt text
                  • Static IP/Domain or DDNS or Dataplicity portforwarding REQUIRED
                  • Your IFTTT app of smartphone is needed.
                  • You should allow your location service of app on phone as always
                  • T
                    tc60045
                    OK, some solid testing this afternoon. First off: Love the icons. Love the configurability. You’ve done great work here. I think the key is just testing out the problem with IFTTT.
                    1. Using curl to post the data on local network works for “entered,”
                      {“who”:“user”, “location”:“Church”, “EnteredOrExited”:“Entered”} – will be reflected immediately
                    2. Doing same for “exited” doesn’t show anything different.
                      {“who”:“user”, “location”:“Church”, “EnteredOrExited”:“Exited”} – nothing new gets posted. Suggest you say “Left Church” (x min ago) as an action description after trapping the condition.
                    3. Trying to post the data via IFTTTT body isn’t working with the Ingredient
                    4. When I hard code all the BODY, it works perfectly – /whereis is trapping the data when it comes through.
                    5. Problem is with the {{EnteredOrExited}} ingredient.
                    6. I’m trying using different escaping to see if it that helps. But my team of IFTTT testers are off with their friends and I won’t get a chance to test locations more until tomorrow. I’ll report back.
                    7. Last thing: You have https – emphasis on s – in your IFTTT recipe. I’m not opening up 443 and dealing with certs and stuff, so I’m only using http on a custom port. YMMV.
                      @tc60045
                      • I think “EnteredOrExited” should have “entered” or “exited” (not uppercase) : need to confirm.
                      • I used https but http could also work. (I used dataplicity and nginx for wormhole of fixed domain and port 80 using). Usually ppl would use ddns, http would be enough.
                      • G
                        Gurdt
                        Nice peace of work guys!!
                        Only if got an question, is it possible to save the data into a file or on a server?
                        And of course after writing a file or put it on a server get the last location?
                          shiitbiird
                          Hey guys- are you still maintaining this?
                          Y 1 Reply Last reply
                          • Y
                            yedidia @shiitbiird
                            @shiitbiird and All
                            I started a new project that has more or less the same functionality.
                            It’s based on tracking cellular devices on home wifi/lan.
                            see : https://github.com/yedidiaklein/MMM-whoshome
                            it looks like this:
                            who is home
                            (and I even added recently “last seen” info)
                            Your suggestions will be appreciated.
                            –Yedidia
