    (electron:2910): Gtk-WARNING **: 14:16:40.324: cannot open display: :0
    23 Posts 2 Posters 9.1k Views 2 Watching
      sdetweil @bachoo786
      @bachoo786 Hm… could be,that would be no display 0 (i hate it when the computers get it right!)
      if u want to see it from some other system, then do
      node serveronly
      it will tell you what IP address to put into the browser on your other system
        bachoo786 @sdetweil
        @sdetweil right ok make sense.
        to be fair the instrcutions on github on installing MagicMirror are little confusing as the installation script asks you if you want to use pm2 and when you say yes it should automatically run magicmirror via pm2.
        however there is this link (https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror) on the github explaining how to auto starting the magic mirror. And when you follow this link you end up having two instances of magic mirror on pm2 i.e. MagicMirror and mm. Thats confusing!
        Do I still have to follow the autostarting magicmirror link? or is the install script sufficient?
          sdetweil @bachoo786
          @bachoo786 install script does it for you…
            sdetweil @bachoo786
            @bachoo786 could you do me a favor before u plug in a monitor,
            can you do
            pgrep Xorg
            from the ssh terminal…
            I’m guessing it should return nothing…
            my new run-start.sh script in next release, will detect text mode and start your installation in serveronly automagically.,! (pm2 just starts the script)
              bachoo786 @sdetweil
              @sdetweil yeah it returned nothing.
              so shall I follow your script i.e. https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
              and reinstall MagicMirror?
              Do I have to worry about installing pm2? will Magic Mirror run automatically if I was to reboot my raspberry? etc?
              to be fair I want to install and run Magic Mirror on my raspberry. I suppose that is server mode? and not client mode? whats the difference sorry ?
              S 3 Replies Last reply Reply Quote 0
                sdetweil @bachoo786
                @bachoo786 you don’t need to reinstall… you are ok… just need a display on the 4 or run server only…
                the new code isn’t used on my install except for pi0, which won’t work anymore without some changes
                  sdetweil @bachoo786
                  @bachoo786 said in (electron:2910): Gtk-WARNING **: 14:16:40.324: cannot open display: :0:
                  awesome! thanks
                    bachoo786 @sdetweil
                    @sdetweil what is server mode and client mode? I dont understand the difference. Can you please explain? thanks.
                      sdetweil @bachoo786
                      the current installation only tries to run on the real display… YOU have to figure it out otherwise…
                      (which we are doing here in this topic)
                        bachoo786 @sdetweil
                        @sdetweil I am really confused buddy.
                        lets start again please. I install mm using the script, what do I do next? do I need to worry about pm2? I suppose installing using the script installs MM as the server on the raspberry pi?
