    (electron:2910): Gtk-WARNING **: 14:16:40.324: cannot open display: :0
    23 Posts 2 Posters 10.8k Views 2 Watching
      sdetweil @bachoo786
      @bachoo786 install script does it for you…
        sdetweil @bachoo786
        @bachoo786 could you do me a favor before u plug in a monitor,
        can you do
        pgrep Xorg
        from the ssh terminal…
        I’m guessing it should return nothing…
        my new run-start.sh script in next release, will detect text mode and start your installation in serveronly automagically.,! (pm2 just starts the script)
        B 1 Reply Last reply
          bachoo786 @sdetweil
          @sdetweil yeah it returned nothing.
          so shall I follow your script i.e. https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
          and reinstall MagicMirror?
          Do I have to worry about installing pm2? will Magic Mirror run automatically if I was to reboot my raspberry? etc?
          to be fair I want to install and run Magic Mirror on my raspberry. I suppose that is server mode? and not client mode? whats the difference sorry ?
          S 3 Replies Last reply
            sdetweil @bachoo786
            @bachoo786 you don’t need to reinstall… you are ok… just need a display on the 4 or run server only…
            the new code isn’t used on my install except for pi0, which won’t work anymore without some changes
              sdetweil @bachoo786
              @bachoo786 said in (electron:2910): Gtk-WARNING **: 14:16:40.324: cannot open display: :0:
              awesome! thanks
                bachoo786 @sdetweil
                @sdetweil what is server mode and client mode? I dont understand the difference. Can you please explain? thanks.
                  sdetweil @bachoo786
                  the current installation only tries to run on the real display… YOU have to figure it out otherwise…
                  (which we are doing here in this topic)
                    bachoo786 @sdetweil
                    @sdetweil I am really confused buddy.
                    lets start again please. I install mm using the script, what do I do next? do I need to worry about pm2? I suppose installing using the script installs MM as the server on the raspberry pi?
                      sdetweil @bachoo786
                      @bachoo786 sure…
                      MagicMirror is a web application.
                      it can be run in two different models
                      1. the browser and ‘web server’ are the same app, on the same machine
                        other machines can access the ‘web server’ part too
                      2. the mirror is run without a display (server only), and some browser somewhere is used to
                      you might do 2 where u want to provide Mirror access to multiple systems but don’t need it where the pi is installed…
                        bachoo786 @sdetweil
                        @sdetweil said in (electron:2910): Gtk-WARNING **: 14:16:40.324: cannot open display: :0:
                        ok makes sense. I normally access the mirror by port forwarding my raspberry pi on port 8080 and thats how I can access it on different machines or at work. And I like it that way to be fair. Because eventually my raspberry pi 4 will be inside the 2 way mirror running the Magic Mirror software.
                          sdetweil @bachoo786
                          @bachoo786 there is only one install…
                          but two ways to run…
                          but if u don’t have a display, then u are forced into serveronly mode
                          from the readme
                          https://github.com/MichMich/MagicMirror#server-only
                          from manual installation
                          https://github.com/MichMich/MagicMirror#manual-installation
                          Manual Installation
                          Download and install the latest Node.js version:
                          curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                          sudo apt install -y nodejs
                          Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
                          Enter the repository: cd MagicMirror/
                          Install and run the app with: npm install && npm start
                          For Server Only use: npm install && node serveronly .   // < -------
                            sdetweil @bachoo786
                            well, in that model, typically, u have both server and browser running on same machine (pi 4) inside the actual mirror enclosure on the wall), so NOT serveronly mode
                            see the forum section https://forum.magicmirror.builders/category/12/show-your-mirror
                            where people are showing their implementations, with the whole setup
                              bachoo786 @sdetweil
                              @sdetweil ok so I will install like everyone else i.e. server and browser on the same machine. Thanks for sorting my head on that.
                              Now with regards to the install script I do not need to follow this link (https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror) to autostart magicmirror? as you said thats all taken care in the install script? Am i correct? or?
                                sdetweil @bachoo786
                                @bachoo786 no… u have pm2 which does it all… (oops, the default run-start.sh script ONLY starts in both mode, YOU have to change it to do serveronly like below)
                                u have already installed both… again there is only ONE install process, but two ways to run
                                today
                                issue the following commands (either set)
                                run both
                                npm start
                                or
                                run serveronly
                                node serveronly
                                B 2 Replies Last reply
                                  bachoo786 @sdetweil
                                  @sdetweil ok I will try it when I get home mate. Thanks.
                                    bachoo786 @sdetweil
                                    @sdetweil hi quick question… so i connected my raspberry pi 4 4gb to hdmi o but there is no display ? do i need to do some settings? my raspberry pi doesnt display anything? is that normal for raspberry pi 4?
                                      sdetweil @bachoo786
                                      @bachoo786 i don’t know what you need to do to enable the display after booting into text mode…
                                      maybe run raspiconfig. and select boot to desktop?
                                        bachoo786 @sdetweil
                                        @sdetweil I had to add the following in my config.txt and it works now.
                                        hdmi_force_hotplug=1
                                        hdmi_ignore_edid=0xa5000080
                                        hdmi_group=2
                                        hdmi_mode=81
                                        do you mind sharing your /boot/config.txt please?
                                        Also after doing these settings the raspberry pi doesnt connect to wifi.
                                        Its a disaster this rpi 4 tbh
