    How to disable auto update from MMM-GooglePhotos
    13 Posts 5 Posters 3.3k Views 5 Watching
      JohnDelta
      Hey guys,
      I’m having some difficulties with MMM-GooglePhotos. I created an album where there is always just one file inside (each day/week a new one).
      Now my problem that I have is that every now and then the picture fades out and in (Pic - Black - Pic) which is kinda annoying.
      So now I’m looking for a solution, that the Module only downloads the file once when the MagicMirror ist being started and then doesn’t fade around.
      			module: "MMM-GooglePhotos",
      			position: "middle_center",
      albumId: ["ALBUM_ID"], // your album id(s) from result of `auth_and_test.js`
      				// refreshInterval: 1000*60,
      				// ! scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
      				sort: "time", //'time', 'reverse', 'random'
      				showWidth: "50%",
      				showHeight: "650px",
      				originalWidthPx: 2339,
      				originalHeightPx: 1653,
      				mode: "hybrid", // "cover" or "contain"
      Thank you guys for your support and some ideas.
      S ? 2 Replies Last reply Reply Quote 0
        sdetweil @JohnDelta
        @JohnDelta said in How to disable auto update from MMM-GooglePhotos:
        MMM-GooglePhotos
        sorry, let me feed that back…
        u want to force download all the files (at module startup) and then load them from the local disk?
        • E Offline
          ember1205 @sdetweil
          I got the sense that there is only one file and that it gets updated once per week. So, there is no need to cycle through a batch of photos because there is only one. I don’t see a way of changing the behavior without modifying the underlying code because it’s built to cycle through a collection of photos, not just display a single one.
            sdetweil @ember1205
            @ember1205 i was being general… 1 file or more, its the same problem.
            • E Offline
              ember1205 @sdetweil
              @sdetweil said in How to disable auto update from MMM-GooglePhotos:
              Yes, true.
              To me, the solution here seems to be a combination of a cron tool to download an image when it gets updated, a trigger to either restart MM or send a notification to the module to re-read the image, and the ability to simplistically display that singular image as the background for MM.
                sdetweil @ember1205
                @ember1205 if you used a cron job, then you could use a different module to display the images
                • E Offline
                  ember1205 @sdetweil
                  @sdetweil Agreed. And, if it were me, I would do it that way.
                  Cron job to check for updates and determine if the file gets updated
                  If the file was updated, either send notification to load new image in the module, or just restart MM
                  Use something along the lines of MMM-EasyBack as a module to load the background image
                    sdetweil @ember1205
                    @ember1205 or MMM-ImagesPhotos (which updates its list)
                      A Former User @JohnDelta
                      @JohnDelta
                      Well, if only one photo be used, why do u use cloud?
                      Anyway, in that case, you can give very enough time for scanning and refreshing, maybe 24 hour(1000 * 60 * 60 * 24).
                      But the only problem is, public opened url of photo which is served by google photos, has not permanent or long-lived lifetime. url would be invalid usually after 1-2hours from its serving
                      I made this module for whom has hundreds, thousands photos and is managing them with cloud service, so has trouble with storing whole pictures locally (That’s why it is handling only one picture at once)
                      Just this module is not for your purpose. Try different approach.
                        JohnDelta
                        Thank you guys for all the responses.
                        So the reason I was thinking on doing it by cloud was that I can manage the files remotely on an easy user interface and also i could just share the folder with the Person in charge of updating it.
                        @Sean you wrote “But the only problem is, public opened url of photo which is served by google photos, has not permanent or long-lived lifetime. url would be invalid usually after 1-2hours from its serving”
                        But does the URL of the Pictures matter? I mean since its working via the Album_Id. Or what does the Album Id stand for?
                        @sdetweil can you help me out what a cron tool is? Haven’t heard about it yet.
                        Merry Christmas everybody ;)
                        E S 2 Replies Last reply Reply Quote 0
