Solved magic mirror 2 config.js file
@sdetweil i think so? it’ll open in electron
@elaineezhu how did you do the install? manually or one of the scripts?
@elaineezhu pm2 starts the same scripts as manually (~/MagicMirror/installers/mm.sh)
@sdetweil i believe manually, using the instructions here: https://forum.magicmirror.builders/topic/810/total-beginner-mm2-with-macmini/3
@elaineezhu hm… shouldn’t matter… but won’t take long… try my new updated installer (part of next
release)see the instruction here
https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
rename the current MagicMirror folder out of the way
@sdetweil this is what happens when i try to use your code
@elaineezhu ok, I think i fixed the greadlink problem…
but you MUST rename the MagicMirror folder 1st… this is INSTALL, assumes first time…
later there will be a new update script (to move to next version)
just fyi, I added the compliment config to my MM on Mac catalina and it works as expected
@sdetweil do i rename the folder to anything i want?
@elaineezhu yes, as long as it is not MagicMirror
MagicMirror.save, .old, .previous, junk… whatever
@sdetweil i tried using the bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)” command again, but it still doesn’t work. it shows the same feedback as before. i’ve also renamed the magic mirror folder
