My first module
10 Posts 2 Posters 5.5k Views 2 Watching
  • G Offline
    gismo2006
    Hi guys,
    I like to write my first modul. Its a fun modul and didn’t have a reason for anyone. I like to learn to write a module. So I can leaerning a lot I think.
    I have create a folder in modules. Called Sounds I have put it into the config file andy the Mirror stats correctly Juhuuuu! :-) First step reached. :-D But now the Problem… Th module didn’t work. For a first test the only think the modul should do is react on a Message which is send by the Voicecontrolmodul by @alexyak. I have creste for this test a new Hotword calles test. I copy the pmdl file and paste the rigt things into my config file. So far, so good. I think the Problem was the Sounds.js file in my own modul folder Sounds. OHH, before I forget. The Sounds.sh skript is only a shell script and worked fine too. I habe write chmod +x Sounds.sh to create a runable file.
    Here the code, maybe someone can look a this and whre my misstake is :-)
    /* global Module */
    /* Magic Mirror
    • Module: HelloWorld
    • MIT Licensed.
    Module.register(“Sounds”,{
        if (notification === "test"){
            exec("sudo /home/pi/MagicMirror/modules/Sounds/Sounds.sh")
    // Override dom generator.
    getDom: function() {
    	wrapper.innerHTML = this.config.text;
    	return wrapper;
    greets gismo
    S 1 Reply Last reply Oct 21, 2016, 8:47 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @gismo2006
      @gismo2006 you’re missing a { and , (instead of semicolon)
              exec("sudo /home/pi/MagicMirror/modules/Sounds/Sounds.sh");
      • G Offline
        gismo2006
        @strawberry-3-141 Thank you for your help. but it didn’t change anything. The problem is the same. Everythink started fine but they didn’t play the Sounds.sh…
        S 1 Reply Last reply Oct 21, 2016, 8:56 PM Reply Quote 0
          @gismo2006 try to debug where you’re module is getting stuck like this
                  Log.info("test notification received");
          if you don’t see this message in the dev console you propably misconfigured your voice command
          • G Offline
            gismo2006
            Ok I will do what you say.
            Ok I have done
            I have found the Problem. the dev consoles says
            Sounds.js:15 Uncaught ReferenceError: exec is not defined.
            Can i delete the word exec? But I think I have to use it to run the script, right?
            greets gismo
            S 1 Reply Last reply Oct 21, 2016, 9:13 PM Reply Quote 0
              @gismo2006 yeah you have to create a node_helper to run the script and send a socketnotification t the node_helper and there you can run the script
              • G Offline
                gismo2006
                Ok, Thank you for your help. I will try myself to go this next step…
                S 1 Reply Last reply Oct 21, 2016, 9:20 PM Reply Quote 1
                  @gismo2006 https://github.com/fewieden/MMM-voice/blob/f9eb4cd4bde5c64ef894e8625250c4092aa0d4a7/node_helper.js
                  line 10, 23-31, 213 will help you
                  • G Offline
                    gismo2006
                    Thank you I have looked in the notification Node_helper.js code which was posted in the Voicecontrol post from @tyho. And it works now fine. Now I can learning something new. To grow up my modul and finding a really reason for my module :-D
                    But I like to say Thank you. You helped me a lot. :-)
                    greets gismo
                    S 1 Reply Last reply Oct 21, 2016, 9:35 PM Reply Quote 0
                      @gismo2006 no worries, if you come up with more questions don’t hesitate to ask
