    MMM-Fuel doesn't work
    6 Posts 3 Posters 1.5k Views 3 Watching
    • O Offline
      oli1204
      i hope anyone can help me.
      I want to use the modul “MMM-Fuel”.
      It doesn’t work. it is not displayed.
      here is my entry in the config-file:
      module: “MMM-Fuel”,
      position: “botton_left”,
      api_key: “*************************”,
      lat: 49.9556351,
      lng: 9.772477,
      types: [“diesel”],
      following message is generated:
      request to https://creativecommons.tankerkoenig.de/json/list.php?lat=49.9556351&lng=9.772477&rad=5&type=all&apikey=*mykey&sort=dist failed, reason: getaddrinfo EAI_AGAIN creativecommons.tankerkoenig.de creativecommons.tankerkoenig.de:443’
      thanks for your help
      best regards
      Oliver
        sdetweil @oli1204
        @oli1204 said in MMM-Fuel doesn't work:
        this says that your system cannot find that entry via name resolution
        nslookup from a terminal window
        nslookup creativecommons.tankerkoenig.de
        on my system it looks like this
        Server:  dns9.quad9.net
        Address:  9.9.9.9  // < --- my name server
        Non-authoritative answer:
        Address:  188.68.35.147
        • O Offline
          oli1204
          @sdetweil said in MMM-Fuel doesn't work:
          thanks for your help…but i don 't know what to do…
          sorry this is my first Magicmirror…
          • FoziF Offline
            Fozi Project Sponsor @oli1204
            @oli1204 There seems to be a problem with the DNS resolution. Just for curiosity… Could you try the MMM-Tankerkoenig Module? It basically does the same as MMM-Fuel.
            Is the same error thrown?
            BTW: The position is misspelled…it must be “bottom_left”
            • O Offline
              oli1204
              @Fozi said in MMM-Fuel doesn't work:
              hello,
              its so embarassing. the mistake was really botton instead of bottom.
              very much thanks for your help.
              best regards
              Olivr
              • FoziF Offline
                @oli1204 glad that it works now!
