Solved MM not starting after update
@sdetweil no that I remember, I actually used instruction from this forum before and used “git pull” in MagicMirror directory first. After that I found the instructions I told you in the earlier post when my MM wouldn’t start. Then I tried that and when it still didn’t start I posted here.
@jani-karna ok, git pull yanked u up to 2.10.0 i expect
@jani-karna said in MM not starting after update:
there were two parts to the command
git pull & npm install
@sdetweil well actually 3 parts, as apparently I didn’t know what I was doing.
- git pull
- bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)” apply
- npm install (after finding out it is needed)
@jani-karna yeh, the initial instructions should have been either of these, but not both
use the update_script (which does all of 1 plus more)
@sdetweil yeah… the instructions should be updated so that others won’t make same mistake as I did.
@jani-karna thanks for your info…
@jani-karna Mich has released new doc now
see
https://forum.magicmirror.builders/topic/11987/dedicated-documentation-site
