    MM not starting after update
    20 Posts 3 Posters 7.7k Views 4 Watching
      sdetweil @jani.karna
      @jani-karna thanks, can u tell me where u got the update instructions?
        jani.karna @sdetweil
        from here:
        https://github.com/MichMich/MagicMirror#updating-you-magicmirror
        and followed the instructions in “updating”-section. I first did the “test” update and then after no problems used the “apply” as instructed there.
        It didn’t mention “npm install” there.
          @jani-karna ok, the script WOULD have done the update, but it failed…
          can u send me the MagicMirror/installers/upgrade.log?
          same id as here on gmail…
          thanks
            @sdetweil should be on its way now.
              @sdetweil is there any easy way of backing up any modified files, configs or .css files. The upgrade messed up a lot and even when I thought I had everything backed up as files there were a lot of changes I had to manually fix afterwards.
              The upgrade process mentioned custom.css to be saved and restored after but it didn’t.
                @jani-karna hm… there is only one file saved/restored, cause all the other files aren’t touched…
                were u on 2.9 before? the log says 2.10, so there was a git put or something before
                  @sdetweil no that I remember, I actually used instruction from this forum before and used “git pull” in MagicMirror directory first. After that I found the instructions I told you in the earlier post when my MM wouldn’t start. Then I tried that and when it still didn’t start I posted here.
                    @jani-karna ok, git pull yanked u up to 2.10.0 i expect
                      @jani-karna said in MM not starting after update:
                      there were two parts to the command
                      git pull & npm install
                        @sdetweil well actually 3 parts, as apparently I didn’t know what I was doing.
                        1. git pull
                        2. bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)” apply
                        3. npm install (after finding out it is needed)
                          @jani-karna yeh, the initial instructions should have been either of these, but not both
                          1. git pull & npm install
                          2. use the update_script (which does all of 1 plus more)
                            @sdetweil yeah… the instructions should be updated so that others won’t make same mistake as I did.
                              @jani-karna thanks for your info…
                                @jani-karna Mich has released new doc now
                                see
                                https://forum.magicmirror.builders/topic/11987/dedicated-documentation-site
