MM not starting after update
20 Posts 3 Posters 5.5k Views 4 Watching
    jani.karna
    I updated my MagicMirror to latest version, and now it does not start.
    pm2 logs mm
    shows this:
    0|mm  | A JavaScript error occurred in the main process
    0|mm  | Uncaught Exception:
    0|mm  | Error: Cannot find module 'module-alias/register'
    0|mm  |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
    0|mm  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
    0|mm  |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
    0|mm  |     at Module.require (internal/modules/cjs/loader.js:658:17)
    0|mm  |     at require (internal/modules/cjs/helpers.js:20:18)
    0|mm  |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:1)
    0|mm  |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:283:3)
    0|mm  |     at Module._compile (internal/modules/cjs/loader.js:711:30)
    0|mm  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
    0|mm  |     at Module.load (internal/modules/cjs/loader.js:620:32)
    I had a feeling I shouldn’t do this, but I did anyway. How to fix it?
    S 1 Reply Last reply Jan 5, 2020, 1:02 PM Reply Quote 0
      sdetweil @jani.karna
      @jani-karna how did u update?
        dicker182
        same here, I just did an
        git stash
        git pull
        in the Magicmirrir directory
        S 1 Reply Last reply Jan 5, 2020, 9:46 PM Reply Quote 0
          sdetweil @dicker182
          @dicker182 also need npm install
          D 1 Reply Last reply Jan 6, 2020, 11:37 AM Reply Quote 0
            dicker182 @sdetweil
            @sdetweil thats it. Thank you!
              jani.karna
              npm install helped me also. Thank you!
              S 1 Reply Last reply Jan 6, 2020, 5:07 PM Reply Quote 0
                @jani-karna thanks, can u tell me where u got the update instructions?
                J 1 Reply Last reply Jan 6, 2020, 5:15 PM Reply Quote 0
                  jani.karna @sdetweil
                  from here:
                  https://github.com/MichMich/MagicMirror#updating-you-magicmirror
                  and followed the instructions in “updating”-section. I first did the “test” update and then after no problems used the “apply” as instructed there.
                  It didn’t mention “npm install” there.
                  S 1 Reply Last reply Jan 6, 2020, 5:16 PM Reply Quote 0
                    @jani-karna ok, the script WOULD have done the update, but it failed…
                    can u send me the MagicMirror/installers/upgrade.log?
                    same id as here on gmail…
                    thanks
                    J 2 Replies Last reply Jan 6, 2020, 5:21 PM Reply Quote 0
                      @sdetweil should be on its way now.
