    MM not starting after update
    20 Posts 3 Posters 7.8k Views 4 Watching
      sdetweil @jani.karna
      @jani-karna ok, the script WOULD have done the update, but it failed…
      can u send me the MagicMirror/installers/upgrade.log?
      same id as here on gmail…
      thanks
      J 2 Replies Last reply
        jani.karna @sdetweil
        @sdetweil should be on its way now.
          @sdetweil is there any easy way of backing up any modified files, configs or .css files. The upgrade messed up a lot and even when I thought I had everything backed up as files there were a lot of changes I had to manually fix afterwards.
          The upgrade process mentioned custom.css to be saved and restored after but it didn’t.
            @jani-karna hm… there is only one file saved/restored, cause all the other files aren’t touched…
            were u on 2.9 before? the log says 2.10, so there was a git put or something before
            J 1 Reply Last reply
              @sdetweil no that I remember, I actually used instruction from this forum before and used “git pull” in MagicMirror directory first. After that I found the instructions I told you in the earlier post when my MM wouldn’t start. Then I tried that and when it still didn’t start I posted here.
              S 2 Replies Last reply
                @jani-karna ok, git pull yanked u up to 2.10.0 i expect
                  @jani-karna said in MM not starting after update:
                  there were two parts to the command
                  git pull & npm install
                    @sdetweil well actually 3 parts, as apparently I didn’t know what I was doing.
                    1. git pull
                    2. bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)” apply
                    3. npm install (after finding out it is needed)
                      @jani-karna yeh, the initial instructions should have been either of these, but not both
                      1. git pull & npm install
                      2. use the update_script (which does all of 1 plus more)
                        @sdetweil yeah… the instructions should be updated so that others won’t make same mistake as I did.
                          @jani-karna thanks for your info…
                            @jani-karna Mich has released new doc now
                            see
                            https://forum.magicmirror.builders/topic/11987/dedicated-documentation-site
