    Raspberry Pi 3 and Chromium
    10 Posts 4 Posters 8.6k Views 3 Watching
    • F Offline
      Flo-lapin
      Hi guys!
      I am following Xonay Labs tutorial to setup my MagicMirror and I got a problem; I tried to solve it but did not workout…
      In fact in Part V, it shows how to get Chromium automatically start on boot. And so, I have Chromium downloaded, but I can not get it to launch on boot. I copied in the following code into autostart but nothing happens when I save and reboot.
      @xset s off
      @xset -dpms
      @xset s noblank
      @chromium --kiosk --incognito http://localhost
      Am I missing something?
      Thank you!
      • W Offline
        Wilco89
        When you are using the MM2 on github you Can skip that. The New Magic Mirror doesn’t use chromium etc anymore:
        https://github.com/MichMich/MagicMirror
        Look at the readme.
        Succes!!
        • F Offline
          Flo-lapin
          Oh! Thank you :)
            paviro @Flo-lapin
            @MichMich maybe add a note that the tutorial is outdated?
            – The Doctor
            MichMichM 1 Reply Last reply Reply Quote 0
            • W Offline
              Wilco89 @Flo-lapin
              @Flo-lapin best is to start with a clean install of Raspbian Jessy, and follow the instuctions.
              Within An hour you can Have it Running.
              • F Offline
                Flo-lapin
                I’ve just installed the whole bundle with the Automatic Installer (much easier indeed)!
                I am having another problem running the MagicMirror, apparently the problem is with electro js/electron.js… I will look around on the forum…
                Thank you so much for your fast answers :)
                • W Offline
                  Wilco89
                  What is the problem?
                  • F Offline
                    Flo-lapin
                    @Wilco89 I am having exactly the same problem as @benjee (see Starting MagicMirror v2 beta [solved]). I am following the thread recommandations by updating the electron. It works now!
                    • W Offline
                      Wilco89 @Flo-lapin
                      @Flo-lapin Nice to Hear! Succes with setting up the Mirror!
                      • MichMichM Offline
                        MichMich @paviro
                        @paviro that message is already there. OP must have missed it.
