    MMM-BackgroundSlideshow
    30 Posts 4 Posters 14.0k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      Yes, that’s really interesting. But since I let the pictures play with max 1-2 MB, the mirror was never black anymore. Although I did the elevation of SWAP.
      • H Offline
        hootzter
        I’m new to magic mirror. Since two weeks I try to get MMM-ImagesPhotos or MMM-BackgroundSlideshow to work with the photos of my camera (all pictures are JPEG with 5 to 10 meg).
        Like @CyruS1337 the whole mirror goes black, if I use my photos but works if I use the example-pictures.
        @sdetweil :
        How did you get this to work with your pictures?
        Could you post your config (including tweeks you did) and tell us which pi you are using?
        I was so desperate that I looked for alternatives. I found pi3d but couldn’t integrate it into magic mirror.
        I would really appreciate your help.
        Best regards
        hootzter
          sdetweil @hootzter
          @hootzter said in MMM-BackgroundSlideshow:
          MMM-ImagesPhotos
          usually black screen means some missing library…
          if u npm start from the terminal window you will see runtime messages
          also from the developers window , ctrl-shift-i on the mirror keyboard, select the console tab, and scroll up.
          you can try my MMM-ImagesPhotos
          https://github.com/sdetweil/MMM-ImagesPhotos
          my config
          			module: "MMM-ImagesPhotos",
          			disabled: false,
          			position: "fullscreen",  // < --- this is the div location NOT screen covered with image
          				opacity: 0.9,
          				animationSpeed: 0,
          				updateInterval: 30000,  // how often to change pic
          				backgroundColor: "#808080", // color around pic (if u want something other than black)
          I have run this on pi0 thru pi4, mac, and two non-pi SBCs, odroid Xu4, and nano jetson.
          where did u put your pictures? the module is looking in the folder
          ~/MagicMirror/modules/MMm_ImagesPhotos/uploads
          I linked that to a mounted server volume
          now, my tweaks were to display the images without distortion… same aspect ratio as taken.
          I did NOT want the screen completely filled… (image stretched or clipped)
          to use mine, just rename the old MMM-ImagesPhotos folder out of the way, and then git clone my version of the module.
          • StoffbeuteluweS Offline
            Stoffbeuteluwe Project Sponsor @sdetweil
            @sdetweil Hi, is it possible to cover the whole screen with mmm images photos?
              sdetweil @Stoffbeuteluwe
              @Stoffbeuteluwe not with my code, no
              the original code does fill the screen if u set the max height and width to the screen size
              img.style.maxWidth = this.config.maxWidth;
              img.style.maxHeight = this.config.maxHeight;
              StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                @sdetweil Thank you Sam 😀🙏
                  @sdetweil hi Sam can you help me again I have tried a lot but no luck…my screensize is
                  width: 1080
                  high: 1920
                  I don’t know how to set it the right way
                  Thanks 🙏
                    @Stoffbeuteluwe are u portrait, not landscape? original or mine?
                    it should work, but ugly
                      @sdetweil Portrait
                        @Stoffbeuteluwe oops. the width/height is from the imagesSlideshow
                        this module only supports
                        backgroundSize	The sizing of the background image. Values can be:
                        cover: Resize the background image to cover the entire container, even if it has to stretch the image or cut a little bit off one of the edges.
                        contain: Resize the background image to make sure the image is fully visible
                        Example: 'contain'
                        Default value: 'cover'
                        This value is OPTIONAL
                          also, how are you rotated? physical or CSS?
                          module does
                          			div1.style.transform="rotate(0deg)";
                          then adjusts if different
                          var Orientation = EXIF.getTag(this, "Orientation");
                          				if (Orientation != null) {
                            @sdetweil I rotate with settings on my Mac
                            Settings , Monitor , Rotation 90
                              @Stoffbeuteluwe hm… on my virtual mac, landscape it looks ok… (backgroundsize: ‘contain’)
                              i don’t see that monitor settings option on my catalina mac vm…
                              • H Offline
                                hootzter
                                @sdetweil thank you very much. I got I working with MMM-ImagesPhotos (took your config + enhanced swap size). My pictures are displayed now :).
                                Is there a chance to auto-rotate to landscape if picture orientation is portrait? Or should I use another module to do this (which one)?
                                Best regards
                                hootzter
