    MMM-BackgroundSlideshow
    30 Posts 4 Posters 13.8k Views 4 Watching
    • H Offline
      hootzter
      I’m new to magic mirror. Since two weeks I try to get MMM-ImagesPhotos or MMM-BackgroundSlideshow to work with the photos of my camera (all pictures are JPEG with 5 to 10 meg).
      Like @CyruS1337 the whole mirror goes black, if I use my photos but works if I use the example-pictures.
      @sdetweil :
      How did you get this to work with your pictures?
      Could you post your config (including tweeks you did) and tell us which pi you are using?
      I was so desperate that I looked for alternatives. I found pi3d but couldn’t integrate it into magic mirror.
      I would really appreciate your help.
      Best regards
      hootzter
        sdetweil @hootzter
        @hootzter said in MMM-BackgroundSlideshow:
        MMM-ImagesPhotos
        usually black screen means some missing library…
        if u npm start from the terminal window you will see runtime messages
        also from the developers window , ctrl-shift-i on the mirror keyboard, select the console tab, and scroll up.
        you can try my MMM-ImagesPhotos
        https://github.com/sdetweil/MMM-ImagesPhotos
        my config
        			module: "MMM-ImagesPhotos",
        			disabled: false,
        			position: "fullscreen",  // < --- this is the div location NOT screen covered with image
        				opacity: 0.9,
        				animationSpeed: 0,
        				updateInterval: 30000,  // how often to change pic
        				backgroundColor: "#808080", // color around pic (if u want something other than black)
        I have run this on pi0 thru pi4, mac, and two non-pi SBCs, odroid Xu4, and nano jetson.
        where did u put your pictures? the module is looking in the folder
        ~/MagicMirror/modules/MMm_ImagesPhotos/uploads
        I linked that to a mounted server volume
        now, my tweaks were to display the images without distortion… same aspect ratio as taken.
        I did NOT want the screen completely filled… (image stretched or clipped)
        to use mine, just rename the old MMM-ImagesPhotos folder out of the way, and then git clone my version of the module.
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor @sdetweil
          @sdetweil Hi, is it possible to cover the whole screen with mmm images photos?
            sdetweil @Stoffbeuteluwe
            @Stoffbeuteluwe not with my code, no
            the original code does fill the screen if u set the max height and width to the screen size
            img.style.maxWidth = this.config.maxWidth;
            img.style.maxHeight = this.config.maxHeight;
            StoffbeuteluweS 2 Replies Last reply Reply Quote 0
              @sdetweil Thank you Sam 😀🙏
                @sdetweil hi Sam can you help me again I have tried a lot but no luck…my screensize is
                width: 1080
                high: 1920
                I don’t know how to set it the right way
                Thanks 🙏
                  @Stoffbeuteluwe are u portrait, not landscape? original or mine?
                  it should work, but ugly
                    @sdetweil Portrait
                      @Stoffbeuteluwe oops. the width/height is from the imagesSlideshow
                      this module only supports
                      backgroundSize	The sizing of the background image. Values can be:
                      cover: Resize the background image to cover the entire container, even if it has to stretch the image or cut a little bit off one of the edges.
                      contain: Resize the background image to make sure the image is fully visible
                      Example: 'contain'
                      Default value: 'cover'
                      This value is OPTIONAL
                        also, how are you rotated? physical or CSS?
                        module does
                        			div1.style.transform="rotate(0deg)";
                        then adjusts if different
                        var Orientation = EXIF.getTag(this, "Orientation");
                        				if (Orientation != null) {
                          @sdetweil I rotate with settings on my Mac
                          Settings , Monitor , Rotation 90
                            @Stoffbeuteluwe hm… on my virtual mac, landscape it looks ok… (backgroundsize: ‘contain’)
                            i don’t see that monitor settings option on my catalina mac vm…
                            • H Offline
                              hootzter
                              @sdetweil thank you very much. I got I working with MMM-ImagesPhotos (took your config + enhanced swap size). My pictures are displayed now :).
                              Is there a chance to auto-rotate to landscape if picture orientation is portrait? Or should I use another module to do this (which one)?
                              Best regards
                              hootzter
