    Third-Party Module - how to get help?
    64 Posts 3 Posters 40.4k Views 4 Watching
      sdetweil @ember1205
      @ember1205 i am not aware of any debugging tools or strategy that can get to the type of issue being encountered. I have been chasing these for the last 4 years…
      i also think the error reported is bogus, caused by the mishandling of some other error.
      the ‘problem’ is that the browser thinks IT is in control of the content update cycle, but with all these modules running separate timer event handlers, it is not.
      I have debugged a lot of ‘electron is single threaded’ problems down to , ‘you might THINK its single threaded, but it is NOT’… when the timer fires, SOMETHING is getting interrupted… in gosh knows what state…
      one way you might prove this, is to turn off every other module, so only ONE does any content updating (it is a web page after all)
      One of my modules has 2-10 images loaded over the top of the web page, on independent timing cycles. i traced failures to attempting to load an image, while an image load was already in progress. I added code to my module to prevent this behavior, and my failures went away.
      I added a background image thing, and they returned when my module is running…
      they are both loading images at the same time sometimes… and electron crashes… in various ways.
      I have been trying (last 6 months) to find a mechanism to serialize this across multiple modules, without changing the modules, but have failed so far.
      we are also running on an age old electron (3.x), which the most recent version that will run for MM is 6.x) (7.x will not run)
        sdetweil @ember1205
        @ember1205 said in Third-Party Module - how to get help?:
        :8080/MMM-ImagesPhotos/photos:1
        yeh, the code attempts to load the folder… once… I haven’t debugged it cause it doesn’t matter
        • E Offline
          ember1205 @sdetweil
          @sdetweil said in Third-Party Module - how to get help?:
          Thanks.
          What about second error I mentioned? Or, is that essentially part of the overall error?
            sdetweil @ember1205
            @ember1205 part of the same… looking at it now
              @ember1205
              ok, fixed the error message… a startup timing error…
              module tried to get images from node_helper, before node_helper had established the linkage…
              (if u are using my repo)
              go to your MMM-ImagesPhotos folder and do
              git pull
              then restart mirror app
              • E Offline
                ember1205
                I don’t seem to be seeing that error any more, but now it’s crying about not using HTTPS (warning, not error, and specifically for Electron). For whatever reason, that warning wasn’t showing up in the console prior although I’m sure that it was there in some capacity.
                I -do- see an indication of an error but can’t seem to find any error in the console.
                  sdetweil @ember1205
                  @ember1205 that big pile of warning is just that warning… a couple years ago, the networking community decide that EVEY website should move away from http, to https, to reduce hacking the clear text content as it went by…
                  so, electron is warning that u didn’t use https
                  • E Offline
                    ember1205 @sdetweil
                    Oh, I’m well aware. This sort of stuff is “what I do” every day. I just find it interesting that I didn’t see it before, see it now, and can’t seem to find the error that is being indicated is present.
                    Switching to an external browser allows me to find the error - it’s actually related to one of the weather modules. The specific complaint is that I don’t have permission to load the weather map.
                    Failed to load resource: the server responded with a status of 401 (Unauthorized)
                    https://api.openweathermap.org/data/2.5/forecast/daily?id=< removed>&units=imperial&lang=en&APPID=< removed>
                    I’ll have to look and see if I can turn off the attempt to load that map.
                      sdetweil @ember1205
                      cool…
                      i can’t explain why it wasn’t shown before… I see it all the time (assuming I don’t have some filter enabled to select just messages for specific modules…)…
                      oh I did a dummy routine to replace the MM provided one that echos notifications received,
                      cause the darned clock module sends an annoying notice every second.
                      • lavolp3L Offline
                        hasn’t this been resolved with a recent update? If not it should be.
                        With the update to 2.10.0 I don’t get any notifications by the clock anymore.
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                          sdetweil @lavolp3
                          @lavolp3 not different
                          if (self.config.displaySeconds) if u have seconds displayed on your time, u still get notices
                          this is the default setting (was on 2.9, is on 2.10)
                            @ember1205 you need to do another git pull…
                            i found a case where it doesn’t update the image anymore…
                            • E Offline
                              ember1205 @sdetweil
                              Will do.
                              As an aside… I directly witnessed an odd scenario the other day when I had it refreshing every five minutes… one of the images only loaded the upper half on the screen (the bottom half of the screen had no image and was blank). I could not tell what image it was as I have quite a few in rotation and the frame continued on cleanly from there with the next image.
                              Is that in any way related to what you found?
                                sdetweil @ember1205
                                @ember1205 no… I have seen the slow paint issue myself many times…
                                electron is having some painting problem… again we are on 3.0.13, no longer supported since way back…
                                I had tried to get us to 6.0.12 this release, but the test system failed, and they removed this change from the 2.10 release
                                (but I have seen paint problems on 6.0.12 too)
                                u can try this manually
                                npm install electron@6.0.12
                                • E Offline
                                  ember1205 @sdetweil
                                  What I saw seemed to be different from a “slow paint” issue - it painted the top half and stopped. It sat there for a few seconds and then the image switched to the next one.
                                  While upgrading manually would certainly get me to something newer for Electron, it puts me in the position of not having a “standard install” for future troubleshooting and such. It’s a double-edged sword…
                                    sdetweil @ember1205
                                    yep…
                                    yes, interrupted paint… could be same issue, or … (the ‘not quite single threaded’ problem again
                                    got interrupted, never came back)
                                      sdetweil @ember1205
                                      from our text messages, I think this was caused by the bug u found on image update scheduling…
                                      I have fixed that now (thanks by the way, been looking for it for over a year now)
                                      • E Offline
                                        ember1205 @sdetweil
                                        I don’t know that I deserve any credit here as I just passed along an observation after you modified your code based on a question I had about whether it was possible to do something. Glad you found and corrected something you had been chasing, though.
                                          sdetweil @ember1205
                                          @ember1205 passing on observations is what it’s all about! Many eyes looking see different things. All contribute to the whole view.
                                          • 3 / 4
