    Which controller board for display / Welches Controller Board für display
    11 Posts 4 Posters 5.0k Views 4 Watching
      MadScientist
      You can find universal LCD controller boards for cheap on eBay or AliExpress. Try to find the datasheet and if the LCD has a LVDS interface I’ll help finding the best controller board. A quick Google search didn’t show anything useful. Maybe post pictures of the LCD panel with all labels visible.
        sw76 @Stoffbeuteluwe
        @Stoffbeuteluwe the screen is ok only the picture is a bit bluish and before it lands on the garbage i thought it would be suitable
          sw76 @MadScientist
          @MadScientist thanks for the help and I hope dropbox is ok too
          https://www.dropbox.com/sh/m8cybyrzaog6z0k/AAC6phVGbtX1AaGRuPobRs7fa?dl=0
            MadScientist @sw76
            @sw76 I am sorry, I couldn’t find a datasheet for that screen. It’s generally tough to find datasheets for TV displays. Had the same problem when I build my mirror. In the end I found a free broken computer screen with a working LCD panel. Maybe that’s a better option for you.
            Also, I assume the blue tint is a problem with the panel itself and not a problem with the controller board. Maybe it’s just the cable, though. Check both end for continuity.
            Good luck with your project!
              sw76 @MadScientist
              @MadScientist Then it shouldn’t be :pensive_face: ,maybe I’ll find another way. I still thank you for your effort.
                acimail01
                Yes this is a real problem with the display and controller.
                Try to contact a controller seller on eBay (e.g. https://www.ebay.de/usr/csmqshop) and give them your display number. With luck, he could help you.
