Unsolved Unable to install dependencies, NPM install not working
1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]
2 info using npm@3.10.8
3 info using node@v6.9.1
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:$
10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]
12 silly lifecycle magicmirror@2.0.0~start: Returned: code: 1 signal: null
13 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
14 verbose stack Error: magicmirror@2.0.0 start:electron js/electron.js
14 verbose stack Exit status 1
14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
14 verbose stack at emitTwo (events.js:106:13)
14 verbose stack at EventEmitter.emit (events.js:191:7)
14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
14 verbose stack at ChildProcess.emit (events.js:191:7)
14 verbose stack at maybeClose (internal/child_process.js:877:16)
14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
15 verbose pkgid magicmirror@2.0.0
16 verbose cwd /home/pi/MagicMirror
17 error Linux 4.4.21-v7+
18 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
19 error node v6.9.1
20 error npm v3.10.8
21 error code ELIFECYCLE
22 error magicmirror@2.0.0 start:electron js/electron.js
22 error Exit status 1
23 error Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
23 error Make sure you have the latest version of node.js and npm installed.
23 error If you do, this is most likely a problem with the magicmirror package,
23 error not with npm itself.
23 error Tell the author that this fails on your system:
23 error electron js/electron.js
23 error You can get information on how to open an issue for this project with:
23 error npm bugs magicmirror
23 error Or if that isn’t available, you can get their info via:
23 error npm owner ls magicmirror
23 error There is likely additional logging output above.
24 verbose exit [ 1, true ] -
next try…
1., installed NOOBS
2., installed JESSIE LITE
3., Setup WLAN, IP, Internalisation, Update, Upgrade
4., Setup MM2:pi@MM:~ $ curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
$$$\ $$$ | _| $$$\ $$$ |_| $$ $$
$$$$\ $$$$ | $$$$$$\ $$$$$$\ $$\ $$$$$$$\ $$$$\ $$$$ |$$\ $$$$$$\ $$$$$$\ $$$$$$\ $$$$$$\ _/ $$ |
$$$$$$ $$ | _$$\ $$ $$\ $$ |$$ |$$$$$$ $$ |$$ |$$ $$\ $$ $$\ $$ $$\ $$ $$\ $$$$$$ |
$$ $$$ $$ | $$$$$$$ |$$ / $$ |$$ |$$ / $$ $$$ $$ |$$ |$$ | _|$$ | _|$$ / $$ |$$ | _|$$ /
$$ |$ /$$ |$$ __$$ |$$ | $$ |$$ |$$ | $$ |$ /$$ |$$ |$$ | $$ | $$ | $$ |$$ | $$ |
$$ | _/ $$ |$$$$$$$ |$$$$$$$ |$$ |$$$$$$$\ $$ | _/ $$ |$$ |$$ | $$ | $$$$$$ |$$ | $$$$$$$$
_| _| _| _$$ |_| _|_| _|_|_| __| _/ _| _______|
_____/Installing helper tools …
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen… Fertig
build-essential ist schon die neueste Version.
curl ist schon die neueste Version.
unzip ist schon die neueste Version.
wget ist schon die neueste Version.
Vorgeschlagene Pakete:
gettext-base git-daemon-run git-daemon-sysvinit git-doc git-el git-email
git-gui gitk gitweb git-arch git-cvs git-mediawiki git-svn
Die folgenden NEUEN Pakete werden installiert:
git git-man libcurl3-gnutls liberror-perl rsync
0 aktualisiert, 5 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 4.613 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 21,5 MB Plattenplatz zusätzlich benutzt.
Holen: 1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3-gnutls armhf 7.38.0-4+deb8u4 [225 kB]
Holen: 2 http://mirrordirector.raspbian.org/raspbian/ jessie/main liberror-perl all 0.17-1.1 [22,4 kB]
Holen: 3 http://mirrordirector.raspbian.org/raspbian/ jessie/main git-man all 1:2.1.4-2.1+deb8u2 [1.267 kB]
Holen: 4 http://mirrordirector.raspbian.org/raspbian/ jessie/main git armhf 1:2.1.4-2.1+deb8u2 [2.725 kB]
Holen: 5 http://mirrordirector.raspbian.org/raspbian/ jessie/main rsync armhf 3.1.1-3 [373 kB]
Es wurden 4.613 kB in 2 s geholt (1.577 kB/s).
Vormals nicht ausgewähltes Paket libcurl3-gnutls:armhf wird gewählt.
(Lese Datenbank … 31227 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von …/libcurl3-gnutls_7.38.0-4+deb8u4_armhf.deb …
Entpacken von libcurl3-gnutls:armhf (7.38.0-4+deb8u4) …
Vormals nicht ausgewähltes Paket liberror-perl wird gewählt.
Vorbereitung zum Entpacken von …/liberror-perl_0.17-1.1_all.deb …
Entpacken von liberror-perl (0.17-1.1) …
Vormals nicht ausgewähltes Paket git-man wird gewählt.
Vorbereitung zum Entpacken von …/git-man_1%3a2.1.4-2.1+deb8u2_all.deb …
Entpacken von git-man (1:2.1.4-2.1+deb8u2) …
Vormals nicht ausgewähltes Paket git wird gewählt.
Vorbereitung zum Entpacken von …/git_1%3a2.1.4-2.1+deb8u2_armhf.deb …
Entpacken von git (1:2.1.4-2.1+deb8u2) …
Vormals nicht ausgewähltes Paket rsync wird gewählt.
Vorbereitung zum Entpacken von …/rsync_3.1.1-3_armhf.deb …
Entpacken von rsync (3.1.1-3) …
Trigger für man-db (2.7.0.2-5) werden verarbeitet …
Trigger für systemd (215-17+deb8u5) werden verarbeitet …
libcurl3-gnutls:armhf (7.38.0-4+deb8u4) wird eingerichtet …
liberror-perl (0.17-1.1) wird eingerichtet …
git-man (1:2.1.4-2.1+deb8u2) wird eingerichtet …
git (1:2.1.4-2.1+deb8u2) wird eingerichtet …
rsync (3.1.1-3) wird eingerichtet …
Trigger für libc-bin (2.19-18+deb8u6) werden verarbeitet …
Check current Node installation …
Node.js is not installed.
Installing Node.js …Installing the NodeSource Node.js v6.x repo…
Populating apt-get cache…
- apt-get update
OK http://archive.raspberrypi.org jessie InRelease
OK http://mirrordirector.raspbian.org jessie InRelease
OK http://mirrordirector.raspbian.org jessie/main armhf Packages
OK http://mirrordirector.raspbian.org jessie/contrib armhf Packages
OK http://mirrordirector.raspbian.org jessie/non-free armhf Packages
OK http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_AT
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-de_AT
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_AT
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_AT
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
OK http://archive.raspberrypi.org jessie/main armhf Packages
OK http://archive.raspberrypi.org jessie/ui armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-de_AT
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-de_AT
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Installing packages required for setup: apt-transport-https…
- apt-get install -y apt-transport-https > /dev/null 2>&1
Confirming “jessie” is supported…
- curl -sLf -o /dev/null ‘https://deb.nodesource.com/node_6.x/dists/jessie/Release’
Adding the NodeSource signing key to your keyring…
- curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
OK
Creating apt sources list file for the NodeSource Node.js v6.x repo…
- echo ‘deb https://deb.nodesource.com/node_6.x jessie main’ > /etc/apt/sources.list.d/nodesource.list
- echo ‘deb-src https://deb.nodesource.com/node_6.x jessie main’ >> /etc/apt/sources.list.d/nodesource.list
Running
apt-get update
for you…- apt-get update
Holen: 1 https://deb.nodesource.com jessie InRelease [3.914 B]
Holen: 2 https://deb.nodesource.com jessie/main Sources [760 B]
Holen: 3 https://deb.nodesource.com jessie/main armhf Packages [962 B]
Holen: 4 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
Holen: 5 https://deb.nodesource.com jessie/main Translation-de [162 B]
Holen: 6 https://deb.nodesource.com jessie/main Translation-en [162 B]
Holen: 7 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
Holen: 8 https://deb.nodesource.com jessie/main Translation-de [162 B]
Holen: 9 https://deb.nodesource.com jessie/main Translation-en [162 B]
Holen: 10 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
Holen: 11 https://deb.nodesource.com jessie/main Translation-de [162 B]
Holen: 12 https://deb.nodesource.com jessie/main Translation-en [162 B]
Holen: 13 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
Holen: 14 https://deb.nodesource.com jessie/main Translation-de [162 B]
Holen: 15 https://deb.nodesource.com jessie/main Translation-en [162 B]
Holen: 16 https://deb.nodesource.com jessie/main Translation-de_AT [162 B]
Ign https://deb.nodesource.com jessie/main Translation-de_AT
Holen: 17 https://deb.nodesource.com jessie/main Translation-de [162 B]
Holen: 18 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Es wurden 5.636 B in 8 s geholt (688 B/s).
Run
apt-get install nodejs
(as root) to install Node.js v6.x and npmPaketlisten werden gelesen… Fertig
nodejs
0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 8.932 kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 45,5 MB Plattenplatz zusätzlich benutzt.
Holen: 1 https://deb.nodesource.com/node_6.x/ jessie/main nodejs armhf 6.9.1-1nodesource1~jessie1 [8.932 kB]
Es wurden 8.932 kB in 6 s geholt (1.367 kB/s).
Vormals nicht ausgewähltes Paket nodejs wird gewählt.
(Lese Datenbank … 32046 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von …/nodejs_6.9.1-1nodesource1~jessie1_armhf.deb …
Entpacken von nodejs (6.9.1-1nodesource1~jessie1) …
nodejs (6.9.1-1nodesource1~jessie1) wird eingerichtet …
Node.js installation Done!
Cloning MagicMirror …
Klone nach ‘MagicMirror’…
remote: Counting objects: 4363, done.
remote: Compressing objects: 100% (5/5), done.
remote: Total 4363 (delta 0), reused 0 (delta 0), pack-reused 4358
Empfange Objekte: 100% (4363/4363), 10.43 MiB | 920.00 KiB/s, Fertig.
Löse Unterschiede auf: 100% (2288/2288), Fertig.
Prüfe Konnektivität… Fertig.
Cloning MagicMirror Done!
Installing dependencies …
npm WARN deprecated electron-prebuilt@1.3.8: electron-prebuilt has been renamed to electron. For more details, see http://electron.atom.io/blog/2016/08/16/npm-install-electron
npm WARN prefer global coffee-script@1.10.0 should be installed with -g
npm WARN prefer global colorguard@1.2.0 should be installed with -g
npm WARN prefer global jsonlint@1.6.2 should be installed with -gelectron-prebuilt@1.3.8 postinstall /home/pi/MagicMirror/node_modules/electron-prebuilt
node install.jsDownloading SHASUMS256.txt
[============================================>] 100.0% of 2.77 kB (2.77 kB/s)magicmirror@2.0.0 prepublish /home/pi/MagicMirror
npm run snyk-protectmagicmirror@2.0.0 snyk-protect /home/pi/MagicMirror
snyk protectSuccessfully applied Snyk patches
magicmirror@2.0.0 /home/pi/MagicMirror
├─┬ electron-prebuilt@1.3.8
│ ├─┬ electron-download@3.0.1
│ │ ├─┬ fs-extra@0.30.0
│ │ │ ├── jsonfile@2.4.0
│ │ │ ├── klaw@1.3.1
│ │ │ └── rimraf@2.5.4
│ │ ├── home-path@1.0.3
│ │ ├── minimist@1.2.0
│ │ ├─┬ nugget@2.0.1
│ │ │ ├── pretty-bytes@1.0.4
│ │ │ ├─┬ progress-stream@1.2.0
│ │ │ │ ├── speedometer@0.1.4
│ │ │ │ └─┬ through2@0.2.3
│ │ │ │ └─┬ xtend@2.1.2
│ │ │ │ └── object-keys@0.4.0
│ │ │ ├── single-line-log@1.1.2
│ │ │ └── throttleit@0.0.2
│ │ ├── path-exists@2.1.0
│ │ ├─┬ rc@1.1.6
│ │ │ ├── deep-extend@0.4.1
│ │ │ └── ini@1.3.4
│ │ └── sumchecker@1.2.0
│ └─┬ extract-zip@1.5.0
│ ├─┬ concat-stream@1.5.0
│ │ ├─┬ readable-stream@2.0.6
│ │ │ ├── core-util-is@1.0.2
│ │ │ ├── isarray@1.0.0
│ │ │ ├── process-nextick-args@1.0.7
│ │ │ ├── string_decoder@0.10.31
│ │ │ └── util-deprecate@1.0.2
│ │ └── typedarray@0.0.6
│ ├── debug@0.7.4
│ ├─┬ mkdirp@0.5.0
│ │ └── minimist@0.0.8
│ └─┬ yauzl@2.4.1
│ └─┬ fd-slicer@1.0.1
│ └── pend@1.2.0
├─┬ express@4.14.0
│ ├─┬ accepts@1.3.3
│ │ └── negotiator@0.6.1
│ ├── array-flatten@1.1.1
│ ├── content-disposition@0.5.1
│ ├── content-type@1.0.2
│ ├── cookie@0.3.1
│ ├── cookie-signature@1.0.6
│ ├─┬ debug@2.2.0
│ │ └── ms@0.7.1
│ ├── depd@1.1.0
│ ├── encodeurl@1.0.1
│ ├── escape-html@1.0.3
│ ├── etag@1.7.0
│ ├─┬ finalhandler@0.5.0
│ │ ├── statuses@1.3.0
│ │ └── unpipe@1.0.0
│ ├── fresh@0.3.0
│ ├── merge-descriptors@1.0.1
│ ├── methods@1.1.2
│ ├─┬ on-finished@2.3.0
│ │ └── ee-first@1.1.1
│ ├── parseurl@1.3.1
│ ├── path-to-regexp@0.1.7
│ ├─┬ proxy-addr@1.1.2
│ │ ├── forwarded@0.1.0
│ │ └── ipaddr.js@1.1.1
│ ├── qs@6.2.0
│ ├── range-parser@1.2.0
│ ├─┬ send@0.14.1
│ │ ├── destroy@1.0.4
│ │ ├─┬ http-errors@1.5.0
│ │ │ ├── inherits@2.0.1
│ │ │ └── setprototypeof@1.0.1
│ │ └── mime@1.3.4
│ ├── serve-static@1.11.1
│ ├─┬ type-is@1.6.13
│ │ └── media-typer@0.3.0
│ ├── utils-merge@1.0.0
│ └── vary@1.1.0
├─┬ feedme@0.3.2
│ ├── clarinet@0.11.0
│ ├── eventyoshi@0.1.6
│ └── sax@1.2.1
├─┬ UNMET PEER DEPENDENCY grunt@1.0.1
│ ├── coffee-script@1.10.0
│ ├─┬ dateformat@1.0.12
│ │ ├── get-stdin@4.0.1
│ │ └─┬ meow@3.7.0
│ │ ├─┬ camelcase-keys@2.1.0
│ │ │ └── camelcase@2.1.1
│ │ ├── decamelize@1.2.0
│ │ ├─┬ loud-rejection@1.6.0
│ │ │ ├─┬ currently-unhandled@0.4.1
│ │ │ │ └── array-find-index@1.0.2
│ │ │ └── signal-exit@3.0.1
│ │ ├── map-obj@1.0.1
│ │ ├─┬ normalize-package-data@2.3.5
│ │ │ ├─┬ is-builtin-module@1.0.0
│ │ │ │ └── builtin-modules@1.1.1
│ │ │ └─┬ validate-npm-package-license@3.0.1
│ │ │ ├─┬ spdx-correct@1.0.2
│ │ │ │ └── spdx-license-ids@1.2.2
│ │ │ └── spdx-expression-parse@1.0.4
│ │ ├─┬ read-pkg-up@1.0.1
│ │ │ ├── find-up@1.1.2
│ │ │ └─┬ read-pkg@1.1.0
│ │ │ ├─┬ load-json-file@1.1.0
│ │ │ │ └─┬ strip-bom@2.0.0
│ │ │ │ └── is-utf8@0.2.1
│ │ │ └── path-type@1.1.0
│ │ ├─┬ redent@1.0.0
│ │ │ ├─┬ indent-string@2.1.0
│ │ │ │ └── repeating@2.0.1
│ │ │ └── strip-indent@1.0.1
│ │ └── trim-newlines@1.0.0
│ ├── eventemitter2@0.4.14
│ ├── exit@0.1.2
│ ├─┬ findup-sync@0.3.0
│ │ └── glob@5.0.15
│ ├─┬ glob@7.0.6
│ │ ├── fs.realpath@1.0.0
│ │ ├─┬ inflight@1.0.6
│ │ │ └── wrappy@1.0.2
│ │ ├── inherits@2.0.3
│ │ └── once@1.4.0
│ ├─┬ grunt-cli@1.2.0
│ │ └── resolve@1.1.7
│ ├── grunt-known-options@1.1.0
│ ├─┬ grunt-legacy-log@1.0.0
│ │ ├── colors@1.1.2
│ │ ├─┬ grunt-legacy-log-utils@1.0.0
│ │ │ └── lodash@4.3.0
│ │ ├── lodash@3.10.1
│ │ └── underscore.string@3.2.3
│ ├─┬ grunt-legacy-util@1.0.0
│ │ ├── async@1.5.2
│ │ ├── getobject@0.1.0
│ │ ├── lodash@4.3.0
│ │ └─┬ which@1.2.11
│ │ └── isexe@1.1.2
│ ├─┬ js-yaml@3.5.5
│ │ ├─┬ argparse@1.0.9
│ │ │ └── sprintf-js@1.0.3
│ │ └── esprima@2.7.3
│ ├─┬ minimatch@3.0.3
│ │ └─┬ brace-expansion@1.1.6
│ │ └── concat-map@0.0.1
│ ├── nopt@3.0.6
│ ├── path-is-absolute@1.0.1
│ └── rimraf@2.2.8
├─┬ grunt-eslint@19.0.0
│ ├─┬ chalk@1.1.3
│ │ ├── ansi-styles@2.2.1
│ │ ├── escape-string-regexp@1.0.5
│ │ ├─┬ has-ansi@2.0.0
│ │ │ └── ansi-regex@2.0.0
│ │ ├── strip-ansi@3.0.1
│ │ └── supports-color@2.0.0
│ └─┬ eslint@3.9.0
│ ├─┬ babel-code-frame@6.16.0
│ │ └── js-tokens@2.0.0
│ ├─┬ doctrine@1.5.0
│ │ └── isarray@1.0.0
│ ├─┬ escope@3.6.0
│ │ ├─┬ es6-map@0.1.4
│ │ │ ├── d@0.1.1
│ │ │ ├── es5-ext@0.10.12
│ │ │ ├── es6-iterator@2.0.0
│ │ │ ├── es6-set@0.1.4
│ │ │ ├── es6-symbol@3.1.0
│ │ │ └── event-emitter@0.3.4
│ │ ├── es6-weak-map@2.0.1
│ │ └─┬ esrecurse@4.1.0
│ │ └── estraverse@4.1.1
│ ├─┬ espree@3.3.2
│ │ ├── acorn@4.0.3
│ │ └─┬ acorn-jsx@3.0.1
│ │ └── acorn@3.3.0
│ ├── estraverse@4.2.0
│ ├── esutils@2.0.2
│ ├─┬ file-entry-cache@2.0.0
│ │ └─┬ flat-cache@1.2.1
│ │ ├── circular-json@0.3.1
│ │ ├─┬ del@2.2.2
│ │ │ ├── globby@5.0.0
│ │ │ ├── is-path-cwd@1.0.0
│ │ │ └─┬ is-path-in-cwd@1.0.0
│ │ │ └── is-path-inside@1.0.0
│ │ └─┬ write@0.2.1
│ │ └─┬ mkdirp@0.5.1
│ ├── glob@7.1.1
│ ├── globals@9.12.0
│ ├── ignore@3.2.0
│ ├── imurmurhash@0.1.4
│ ├─┬ inquirer@0.12.0
│ │ ├─┬ readline2@1.0.1
│ │ │ └── mute-stream@0.0.5
│ │ ├── run-async@0.1.0
│ │ └── rx-lite@3.1.2
│ ├─┬ is-my-json-valid@2.15.0
│ │ ├── generate-function@2.0.0
│ │ ├─┬ generate-object-property@1.2.0
│ │ │ └── is-property@1.0.2
│ │ ├── jsonpointer@4.0.0
│ │ └── xtend@4.0.1
│ ├─┬ is-resolvable@1.0.0
│ │ └── tryit@1.0.3
│ ├─┬ json-stable-stringify@1.0.1
│ │ └── jsonify@0.0.0
│ ├─┬ levn@0.3.0
│ │ ├── prelude-ls@1.1.2
│ │ └── type-check@0.3.2
│ ├── lodash@4.16.4
│ ├── natural-compare@1.4.0
│ ├─┬ optionator@0.8.2
│ │ ├── deep-is@0.1.3
│ │ ├── fast-levenshtein@2.0.5
│ │ └── wordwrap@1.0.0
│ ├── path-is-inside@1.0.2
│ ├── pluralize@1.2.1
│ ├── progress@1.1.8
│ ├─┬ require-uncached@1.0.2
│ │ ├─┬ caller-path@0.1.0
│ │ │ └── callsites@0.2.0
│ │ └── resolve-from@1.0.1
│ ├─┬ shelljs@0.7.5
│ │ ├── interpret@1.0.1
│ │ └── rechoir@0.6.2
│ ├── strip-bom@3.0.0
│ ├── strip-json-comments@1.0.4
│ ├─┬ table@3.8.3
│ │ ├─┬ ajv@4.8.2
│ │ │ └── co@4.6.0
│ │ ├── ajv-keywords@1.1.1
│ │ ├── slice-ansi@0.0.4
│ │ └─┬ string-width@2.0.0
│ │ └── is-fullwidth-code-point@2.0.0
│ └─┬ user-home@2.0.0
│ └── os-homedir@1.0.2
├─┬ grunt-jsonlint@1.1.0
│ ├─┬ jsonlint@1.6.2
│ │ ├── JSV@4.0.2
│ │ └─┬ nomnom@1.8.1
│ │ ├─┬ chalk@0.4.0
│ │ │ ├── ansi-styles@1.0.0
│ │ │ ├── has-color@0.1.7
│ │ │ └── strip-ansi@0.1.1
│ │ └── underscore@1.6.0
│ └── strip-json-comments@2.0.1
├─┬ grunt-markdownlint@1.0.9
│ └─┬ markdownlint@0.2.0
│ └─┬ markdown-it@7.0.1
│ ├── entities@1.1.1
│ ├── linkify-it@2.0.2
│ ├── mdurl@1.0.1
│ └── uc.micro@1.0.3
├─┬ grunt-stylelint@0.6.0
│ └─┬ stylelint@7.5.0
│ ├─┬ autoprefixer@6.5.1
│ │ ├── browserslist@1.4.0
│ │ ├── caniuse-db@1.0.30000570
│ │ ├── normalize-range@0.1.2
│ │ └── num2fraction@1.2.2
│ ├── balanced-match@0.4.2
│ ├─┬ colorguard@1.2.0
│ │ ├── color-diff@0.1.7
│ │ ├─┬ pipetteur@2.0.3
│ │ │ ├── onecolor@3.0.4
│ │ │ └─┬ synesthesia@1.0.1
│ │ │ └── css-color-names@0.0.3
│ │ ├─┬ plur@2.1.2
│ │ │ └── irregular-plurals@1.2.0
│ │ └── yargs@1.3.3
│ ├─┬ cosmiconfig@2.1.0
│ │ ├─┬ parse-json@2.2.0
│ │ │ └─┬ error-ex@1.3.0
│ │ │ └── is-arrayish@0.2.1
│ │ └── require-from-string@1.2.1
│ ├─┬ doiuse@2.5.0
│ │ ├─┬ css-rule-stream@1.1.0
│ │ │ ├── css-tokenize@1.0.1
│ │ │ ├── duplexer2@0.0.2
│ │ │ └─┬ through2@0.6.5
│ │ │ ├── readable-stream@1.0.34
│ │ │ └── xtend@4.0.1
│ │ ├─┬ duplexer2@0.0.2
│ │ │ └── readable-stream@1.1.14
│ │ ├─┬ jsonfilter@1.1.2
│ │ │ ├─┬ JSONStream@0.8.4
│ │ │ │ └── jsonparse@0.0.5
│ │ │ ├─┬ stream-combiner@0.2.2
│ │ │ │ └── duplexer@0.1.1
│ │ ├─┬ ldjson-stream@1.2.1
│ │ │ ├─┬ split2@0.2.1
│ │ │ │ └─┬ through2@0.6.5
│ │ │ │ ├── readable-stream@1.0.34
│ │ │ │ └── xtend@4.0.1
│ │ ├─┬ source-map@0.4.4
│ │ │ └── amdefine@1.0.0
│ │ ├─┬ through2@0.6.5
│ │ └─┬ yargs@3.15.0
│ │ ├── camelcase@1.2.1
│ │ ├─┬ cliui@2.1.0
│ │ │ ├─┬ center-align@0.1.3
│ │ │ │ ├─┬ align-text@0.1.4
│ │ │ │ │ ├─┬ kind-of@3.0.4
│ │ │ │ │ │ └── is-buffer@1.1.4
│ │ │ │ │ ├── longest@1.0.1
│ │ │ │ │ └── repeat-string@1.6.1
│ │ │ │ └── lazy-cache@1.0.4
│ │ │ ├── right-align@0.1.3
│ │ │ └── wordwrap@0.0.2
│ │ └── window-size@0.1.4
│ ├─┬ execall@1.0.0
│ │ └─┬ clone-regexp@1.0.0
│ │ ├── is-regexp@1.0.0
│ │ └── is-supported-regexp-flag@1.0.0
│ ├── get-stdin@5.0.1
│ ├─┬ globby@6.0.0
│ │ └── pify@2.3.0
│ ├── globjoin@0.1.4
│ ├── html-tags@1.1.1
│ ├── known-css-properties@0.0.5
│ ├── log-symbols@1.0.2
│ ├─┬ multimatch@2.1.0
│ │ ├── array-differ@1.0.0
│ │ ├─┬ array-union@1.0.2
│ │ │ └── array-uniq@1.0.3
│ │ └── arrify@1.0.1
│ ├── normalize-selector@0.2.0
│ ├─┬ postcss@5.2.5
│ │ ├── js-base64@2.1.9
│ │ ├── source-map@0.5.6
│ │ └─┬ supports-color@3.1.2
│ │ └── has-flag@1.0.0
│ ├── postcss-less@0.14.0
│ ├── postcss-media-query-parser@0.2.3
│ ├── postcss-reporter@1.4.1
│ ├── postcss-resolve-nested-selector@0.1.1
│ ├── postcss-scss@0.3.1
│ ├─┬ postcss-selector-parser@2.2.1
│ │ ├── flatten@1.0.2
│ │ ├── indexes-of@1.0.1
│ │ └── uniq@1.0.1
│ ├── postcss-value-parser@3.3.0
│ ├── resolve-from@2.0.0
│ ├── specificity@0.3.0
│ ├─┬ string-width@2.0.0
│ ├── style-search@0.1.0
│ ├─┬ stylehacks@2.3.1
│ │ ├─┬ read-file-stdin@0.2.1
│ │ │ └── gather-stream@1.0.0
│ │ └── write-file-stdout@0.0.2
│ ├── sugarss@0.2.0
│ └── svg-tags@1.0.0
├─┬ grunt-yamllint@0.2.0
│ ├── async@0.9.2
│ ├─┬ chalk@0.5.1
│ │ ├── ansi-styles@1.1.0
│ │ ├─┬ has-ansi@0.1.0
│ │ │ └── ansi-regex@0.2.1
│ │ ├── strip-ansi@0.3.0
│ │ └── supports-color@0.2.0
│ └── js-yaml@3.6.1
├── iconv-lite@0.4.13
├── moment@2.15.2
├─┬ request@2.76.0
│ ├── aws-sign2@0.6.0
│ ├── aws4@1.5.0
│ ├── caseless@0.11.0
│ ├─┬ combined-stream@1.0.5
│ │ └── delayed-stream@1.0.0
│ ├── extend@3.0.0
│ ├── forever-agent@0.6.1
│ ├─┬ form-data@2.1.1
│ │ └── asynckit@0.4.0
│ ├─┬ har-validator@2.0.6
│ │ ├─┬ commander@2.9.0
│ │ │ └── graceful-readlink@1.0.1
│ │ └─┬ pinkie-promise@2.0.1
│ │ └── pinkie@2.0.4
│ ├─┬ hawk@3.1.3
│ │ ├── boom@2.10.1
│ │ ├── cryptiles@2.0.5
│ │ ├── hoek@2.16.3
│ │ └── sntp@1.0.9
│ ├─┬ http-signature@1.1.1
│ │ ├── assert-plus@0.2.0
│ │ ├─┬ jsprim@1.3.1
│ │ │ ├── extsprintf@1.0.2
│ │ │ ├── json-schema@0.2.3
│ │ │ └── verror@1.3.6
│ │ └─┬ sshpk@1.10.1
│ │ ├── asn1@0.2.3
│ │ ├── assert-plus@1.0.0
│ │ ├── bcrypt-pbkdf@1.0.0
│ │ ├─┬ dashdash@1.14.0
│ │ │ └── assert-plus@1.0.0
│ │ ├── ecc-jsbn@0.1.1
│ │ ├─┬ getpass@0.1.6
│ │ ├── jodid25519@1.0.2
│ │ ├── jsbn@0.1.0
│ │ └── tweetnacl@0.14.3
│ ├── is-typedarray@1.0.0
│ ├── isstream@0.1.2
│ ├── json-stringify-safe@5.0.1
│ ├─┬ mime-types@2.1.12
│ │ └── mime-db@1.24.0
│ ├── node-uuid@1.4.7
│ ├── oauth-sign@0.8.2
│ ├── qs@6.3.0
│ ├── stringstream@0.0.5
│ ├─┬ tough-cookie@2.3.2
│ │ └── punycode@1.4.1
│ └── tunnel-agent@0.4.3
├── rrule@2.1.0
├─┬ snyk@1.19.1
│ ├── abbrev@1.0.9
│ ├── ansi-escapes@1.4.0
│ ├─┬ configstore@1.4.0
│ │ ├── graceful-fs@4.1.9
│ │ ├── object-assign@4.1.0
│ │ ├── os-tmpdir@1.0.2
│ │ ├── osenv@0.1.3
│ │ ├── uuid@2.0.3
│ │ ├─┬ write-file-atomic@1.2.0
│ │ │ └── slide@1.1.6
│ │ └── xdg-basedir@2.0.0
│ ├── es6-promise@3.3.1
│ ├── hasbin@1.2.3
│ ├─┬ inquirer@1.0.3
│ │ ├─┬ cli-cursor@1.0.2
│ │ │ └─┬ restore-cursor@1.0.1
│ │ │ ├── exit-hook@1.1.1
│ │ │ └── onetime@1.1.0
│ │ ├── cli-width@2.1.0
│ │ ├── mute-stream@0.0.6
│ │ ├─┬ run-async@2.2.0
│ │ │ └── is-promise@2.1.0
│ │ ├── rx@4.1.0
│ │ ├─┬ string-width@1.0.2
│ │ │ ├── code-point-at@1.0.1
│ │ │ └── is-fullwidth-code-point@1.0.0
│ │ └── through@2.3.8
│ ├── open@0.0.5
│ ├─┬ os-name@1.0.3
│ │ ├── osx-release@1.1.0
│ │ └── win-release@1.1.1
│ ├── semver@5.3.0
│ ├─┬ snyk-config@1.0.1
│ │ └─┬ nconf@0.7.2
│ │ └── async@0.9.2
│ ├─┬ snyk-module@1.7.0
│ │ ├── hosted-git-info@2.1.5
│ │ └─┬ validate-npm-package-name@2.2.2
│ │ └── builtins@0.0.7
│ ├─┬ snyk-policy@1.5.2
│ │ └── lodash.clonedeep@4.5.0
│ ├─┬ snyk-recursive-readdir@2.0.0
│ │ └── minimatch@3.0.2
│ ├── snyk-resolve@1.0.0
│ ├─┬ snyk-resolve-deps@1.7.0
│ │ ├── ansicolors@0.3.2
│ │ ├─┬ clite@0.3.0
│ │ │ ├── lodash.defaults@4.2.0
│ │ │ ├── lodash.defaultsdeep@4.6.0
│ │ │ ├── lodash.mergewith@4.6.0
│ │ │ ├─┬ update-notifier@0.6.3
│ │ │ │ ├─┬ boxen@0.3.1
│ │ │ │ │ ├── filled-array@1.1.0
│ │ │ │ │ └── widest-line@1.0.0
│ │ │ │ ├─┬ configstore@2.1.0
│ │ │ │ │ └─┬ dot-prop@3.0.0
│ │ │ │ │ └── is-obj@1.0.1
│ │ │ │ └─┬ latest-version@2.0.0
│ │ │ │ └─┬ package-json@2.4.0
│ │ │ │ ├─┬ got@5.6.0
│ │ │ │ │ ├─┬ create-error-class@3.0.2
│ │ │ │ │ │ └── capture-stack-trace@1.0.0
│ │ │ │ │ ├─┬ duplexer2@0.1.4
│ │ │ │ │ │ └─┬ readable-stream@2.1.5
│ │ │ │ │ │ └── isarray@1.0.0
│ │ │ │ │ ├── is-plain-obj@1.1.0
│ │ │ │ │ ├── is-retry-allowed@1.1.0
│ │ │ │ │ ├── node-status-codes@1.0.0
│ │ │ │ │ ├─┬ readable-stream@2.1.5
│ │ │ │ │ ├── unzip-response@1.0.1
│ │ │ │ │ └── url-parse-lax@1.0.0
│ │ │ │ └── registry-auth-token@3.1.0
│ │ │ └─┬ yargs@4.8.1
│ │ │ ├─┬ cliui@3.2.0
│ │ │ │ └── wrap-ansi@2.0.0
│ │ │ ├── get-caller-file@1.0.2
│ │ │ ├── lodash.assign@4.2.0
│ │ │ ├─┬ os-locale@1.4.0
│ │ │ │ └─┬ lcid@1.0.0
│ │ │ │ └── invert-kv@1.0.0
│ │ │ ├── require-directory@2.1.1
│ │ │ ├── require-main-filename@1.0.1
│ │ │ ├── set-blocking@2.0.0
│ │ │ ├── which-module@1.0.0
│ │ │ ├── window-size@0.2.0
│ │ │ ├── y18n@3.2.1
│ │ │ └─┬ yargs-parser@2.4.1
│ │ │ └── camelcase@3.0.0
│ │ └─┬ lru-cache@4.0.1
│ │ ├── pseudomap@1.0.2
│ │ └── yallist@2.0.0
│ ├─┬ snyk-tree@1.0.0
│ │ └── archy@1.0.0
│ ├── snyk-try-require@1.1.1
│ ├── tempfile@1.1.1
│ ├─┬ then-fs@2.0.0
│ │ └─┬ promise@7.1.1
│ │ └── asap@2.0.5
│ ├── undefsafe@0.0.3
│ ├─┬ update-notifier@0.5.0
│ │ ├── is-npm@1.0.0
│ │ ├─┬ latest-version@1.0.1
│ │ │ └─┬ package-json@1.2.0
│ │ │ ├─┬ got@3.3.1
│ │ │ │ ├─┬ duplexify@3.5.0
│ │ │ │ │ ├─┬ end-of-stream@1.0.0
│ │ │ │ │ │ └── once@1.3.3
│ │ │ │ │ │ ├── buffer-shims@1.0.0
│ │ │ │ │ └── stream-shift@1.0.0
│ │ │ │ ├── infinity-agent@2.0.3
│ │ │ │ ├── is-redirect@1.0.0
│ │ │ │ ├── is-stream@1.1.0
│ │ │ │ ├── lowercase-keys@1.0.0
│ │ │ │ ├── nested-error-stacks@1.0.2
│ │ │ │ ├── object-assign@3.0.0
│ │ │ │ ├── prepend-http@1.0.4
│ │ │ │ ├─┬ read-all-stream@3.1.0
│ │ │ │ └── timed-out@2.0.0
│ │ │ └── registry-url@3.1.0
│ │ ├── repeating@1.1.3
│ │ ├── semver-diff@2.1.0
│ │ └── string-length@1.0.1
│ └─┬ url@0.11.0
│ ├── punycode@1.3.2
│ └── querystring@0.2.0
├─┬ socket.io@1.5.1
│ ├─┬ engine.io@1.7.2
│ │ ├── base64id@0.1.0
│ │ ├─┬ engine.io-parser@1.3.1
│ │ │ ├── after@0.8.1
│ │ │ ├── arraybuffer.slice@0.0.6
│ │ │ ├── base64-arraybuffer@0.1.5
│ │ │ ├── blob@0.0.4
│ │ │ ├── has-binary@0.1.6
│ │ │ └── wtf-8@1.0.0
│ │ └─┬ ws@1.1.1
│ │ ├── options@0.0.6
│ │ └── ultron@1.0.2
│ ├─┬ has-binary@0.1.7
│ │ └── isarray@0.0.1
│ ├─┬ socket.io-adapter@0.4.0
│ │ └─┬ socket.io-parser@2.2.2
│ │ ├── benchmark@1.0.0
│ │ ├── debug@0.7.4
│ │ └── json3@3.2.6
│ ├─┬ socket.io-client@1.5.1
│ │ ├── backo2@1.0.2
│ │ ├── component-bind@1.0.0
│ │ ├── component-emitter@1.2.0
│ │ ├─┬ engine.io-client@1.7.2
│ │ │ ├── component-inherit@0.0.3
│ │ │ ├── has-cors@1.1.0
│ │ │ ├── parsejson@0.0.1
│ │ │ ├── parseqs@0.0.2
│ │ │ ├── xmlhttprequest-ssl@1.5.1
│ │ │ └── yeast@0.1.2
│ │ ├── indexof@0.0.1
│ │ ├── object-component@0.0.3
│ │ ├─┬ parseuri@0.0.4
│ │ │ └─┬ better-assert@1.0.2
│ │ │ └── callsite@1.0.0
│ │ └── to-array@0.1.4
│ └─┬ socket.io-parser@2.3.1
│ ├── component-emitter@1.1.2
│ └── json3@3.3.2
├── stylelint-config-standard@14.0.0
├─┬ time-grunt@1.4.0
│ ├─┬ date-time@1.1.0
│ │ └── time-zone@0.1.0
│ ├── figures@1.7.0
│ ├── hooker@0.2.3
│ ├── number-is-nan@1.0.1
│ ├─┬ pretty-ms@2.1.0
│ │ ├── is-finite@1.0.2
│ │ ├── parse-ms@1.0.1
│ │ └── plur@1.0.0
│ └── text-table@0.2.0
├── valid-url@1.0.9
└─┬ walk@2.3.9
└── foreachasync@3.0.0npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
Dependencies installation Done!We’re ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
pi@MM:~ $
- apt-get update
All right. It looks like the next step is to copy the sample config.js file to it’s final location and then run this puppy.
Are you doing this directly on the Pi or via SSH?
Maybe use something like pastebin for verbose output? Just for thread readability.
@bhepler
the problem is that i (and many others) get an electron error. (compare the posting of @FlorianRD )
i tried both: direkt an sshkind regards!
@kiefersmith sorry, i will try it the next time! Thank you for the hint!
Fail! I did not get time this weekend to try this. I got as far as downloading the new Raspbian image. I need to get another project done first, and it’s taking a lot of my time to complete. I will get to the testing, be patient.
Okay, guys, I got it working. Not sure exactly how. However, I have the basic steps:
- re-imaged Raspbian
sudo apt-update
,sudo apt-get upgrade
,sudo apt-get autoremove
- reboot
- install latest versions of nodejs and npm (make sure they are actually up to date with
--version
) - install electron from source (I believe I did this globally
-g
.) - build MagicMirror from source (not using auto-install script)
- create your
config.js
file. - RUN ELECTRON FROM CONSOLE (just type
electron
) cd MagicMirror
- now run
sudo npm install && npm start
This worked for me! Hopefully it will work for you guys too.
Edit: This also works without
electron
running. I think the issue comes when electron does not install properly? -
@KirAsh4 well time is very precious in times like these ;) don´t get stressed due to our bug reports!
thanks a lot that you are getting a look on it. -
@cpramhofer, not particularly stressed, just a matter of time … and life moving on.
