    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 19.7k Views 9 Watching
      sdetweil @iorifly
      @iorifly fix reported in other topic
      • I Offline
        iorifly
        With the help of @sdetweil , I was able to solve problems with MM.
        Now I am having trouble accessing HA with MMM-HASS.
          If anyone can help I will be happy.
        alt text
        My HA configuration looks like this configuration.yam:
        homeassistant:
          whitelist_external_dirs:
            - /tmp
            - /config/temp/
          auth_providers:
              - type: legacy_api_password
                api_password: "juere3027"
              - type: trusted_networks
                trusted_networks:
                  - 192.168.1.0/24
                  - 127.0.0.1
                  - ::1
                allow_bypass_login: true
              - type: homeassistant
        config.js
                        module: "MMM-HASS",
                        position: "middle_center",
                                host: "192.168.1.158",
                                port: "8123",
                                apipassword: "juere3027",
                                hassiotoken: true,
                                https: false,
                                devices: [
                                { deviceLabel: "Quintal",
                                        deviceReadings: [
                                        { sensor: "sensor.caixa_dagua", icon: "mdi:waves", suffix: "%"}
        The mirror executes loads the other modules, but HASS does not load. I have the following output:
        > magicmirror@2.10.1 start /home/pi/MagicMirror
        > ./run-start.sh
        [22:26:04.896] [LOG] Starting MagicMirror: v2.10.1
        [22:26:04.931] [LOG] Loading config ...
        [22:26:04.951] [LOG] Loading module helpers ...
        [22:26:04.959] [LOG] No helper found for module: alert.
        [22:26:05.139] [LOG] Initializing new module helper ...
        [22:26:05.146] [LOG] Module helper loaded: updatenotification
        [22:26:05.151] [LOG] No helper found for module: clock.
        [22:26:06.647] [LOG] Initializing new module helper ...
        [22:26:06.650] [LOG] Module helper loaded: calendar
        [22:26:06.653] [LOG] No helper found for module: compliments.
        [22:26:07.888] [LOG] Initializing new module helper ...
        [22:26:07.890] [LOG] Module helper loaded: MMM-DarkSkyForecast
        [22:26:08.030] [LOG] Initializing new module helper ...
        [22:26:08.035] [LOG] Module helper loaded: newsfeed
        [22:26:08.129] [LOG] Initializing new module helper ...
        [22:26:08.133] [LOG] Module helper loaded: MMM-HASS
        [22:26:08.137] [LOG] All module helpers loaded.
        [22:26:08.143] [LOG] Starting server on port 8080 ...
        [22:26:08.251] [LOG] Server started ...
        [22:26:08.256] [LOG] Connecting socket for: updatenotification
        [22:26:08.261] [LOG] Connecting socket for: calendar
        [22:26:08.265] [LOG] Starting node helper for: calendar
        [22:26:08.268] [LOG] Connecting socket for: MMM-DarkSkyForecast
        [22:26:08.271] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
        [22:26:08.275] [LOG] Connecting socket for: newsfeed
        [22:26:08.278] [LOG] Starting module: newsfeed
        [22:26:08.282] [LOG] Connecting socket for: MMM-HASS
        [22:26:08.288] [LOG] Sockets connected & modules started ...
        [22:26:08.293] [LOG]
        Ready to go! Please point your browser to: http://localhost:8080
        Starting chromium browser now, have patience, it takes a minute
        [22:26:08.451] [ERROR]  { Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
            at Server.setupListenHandle [as _listen2] (net.js:1280:14)
            at listenInCluster (net.js:1328:12)
            at GetAddrInfoReqWrap.doListen [as callback] (net.js:1461:7)
            at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
          code: 'EADDRINUSE',
          errno: 'EADDRINUSE',
          syscall: 'listen',
          address: '127.0.0.1',
          port: 8080 }
        [22:26:08.444] [LOG]    Whoops! There was an uncaught exception...
        [22:26:08.510] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [22:26:08.512] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
         --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
        [22:26:22.272] [LOG]    Use existing news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml
        [22:26:22.303] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
        [22:26:22.388] [LOG]    { undefined: undefined, label: 'Quintal' }
        • I Offline
          iorifly
          I see that the module tries to connect to the Home assistant.
          https://imgur.com/oHjP479
            sdetweil @iorifly
            @iorifly said in Which modules with Home Assistant currently work?:
            EADDRINUSE
            U already have some application using that port, and are trying to start another
            • I Offline
              iorifly
              I don’t know what it would be. It is not related to MMM-HASS.
              Even with a simple config.js I have this msg. I think I should restart my raspberry.
                sdetweil @iorifly
                @iorifly does mm start on boot?
                • I Offline
                  iorifly
                  Do not. I restarted and the msg stopped. Now I’m fighting with MMM-HASS.
                  I take back what I said. He did give me more information!
                  The mistake I have is in the development of the module. The error is in the connection of the module to the HA system.
                  I can’t do anything but wait for the developer’s announcement.
                  [14:23:57.773] [LOG]    Create new news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml - Interval: 300000
                  [14:23:57.895] [LOG]    { deviceLabel: 'Quintal',
                    deviceReadings:
                     [ { sensor: 'sensor.caixa_dagua',
                         icon: 'wi wi-thermometer',
                         suffix: '%' } ] }
                  [14:23:57.919] [LOG]    192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                  [14:23:57.920] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                  [14:23:58.215] [ERROR]  (node:18860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  [14:23:58.440] [LOG]    null
                  [14:23:58.443] [LOG]    401: Unauthorized
                  [14:23:58.445] [LOG]    { undefined: undefined, label: 'Quintal' }
                  [14:23:59.415] [LOG]    Refreshed access token because it has expired. Expired at: 14:23:57 now is: 14:23:59
                  [14:23:59.450] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
                  [14:23:59.487] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
                  pi@raspberrypi:~/MagicMirror $
                  • I Offline
                    iorifly
                    I tried this option but also to no avail.
                    https://github.com/aserramonner/MMM-HASS/pull/13
                      darbos @iorifly
                      @iorifly to dvbit point you could just use fullpageos if you just want to display a Lovelace tab…
                      Also, I have had homeassistany sensors working recently…if you want to give some more detail of what you’ve done and what the problem is. And share you relevant code I can try to help…
                      • I Offline
                        iorifly @darbos
                        @darbos
                        I would love to know how to display only one lovelace tab. But still it would be the whole screen or I can go down the screen to show only what I want.
                        I have my problem report here too:
                        https://community.home-assistant.io/t/magic-mirror/8443/59
                        what do you need ? I can pass everything !!!
                          dvbit
                          You can use a custom card called custom header to minimize the top and right bar . also having it happen just for the mm through user agent recognition
                            sdetweil @iorifly
                            @iorifly add debuglogging: true,
                            to the config.js for the HASS module
                            it doesn’t handle errors at all… but will report status if that flag is enabled
                            request(get_options, function(error, response, body) {
                                      completed_requests++;
                                      if(config.debuglogging) {
                                        console.log(error);
                                        console.log(body);
                            • I Offline
                              iorifly @sdetweil
                              added it to my config.js. However nothing happened or signaled … Thanks anyway.
                                sdetweil @iorifly
                                @iorifly Will be in the terminal window, or pm2 logs output
                                • I Offline
                                  iorifly
                                  I managed to solve !!! Connected !!! THANKS !!
                                    sdetweil @iorifly
                                    @iorifly what was it? Can’t keep us guessing!
                                    • I Offline
                                      iorifly
                                      I created another token (in HA). and replace in the module.
                                      • I Offline
                                        iorifly
                                        but I will try to use this module. It seems to be more complete.
                                        https://github.com/leinich/MMM-homeassistant-sensors
                                        I will create another token in the Home assistant (HA) for him.
                                        • I Offline
                                          iorifly
                                          actually this module is also working. That is,
                                          operational modules tested by me:
                                          MMM-HASS
                                            Babene1 Project Sponsor
                                            i want to use the modul MMM-HASS
                                            but i get the error in HA “Login attempt or request with invalid authentication from”
                                            i use Home Assistant 0.116.2
                                            here is my MM-Config from the Modul:
                                                       module: "MMM-HASS",
                                                               host: "xxx.xxx.xxx.xxx",
                                                               port: "8123",
                                                               apipassword: "xxxxxx",
                                                               hassiotoken: true,
                                                               token: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                                               https: false,
                                                               devices: [
                                                               { deviceLabel: "Temp Test",
        deviceReadings: [
        { sensor: "sensor.temp1", icon: "wi wi-thermometer", suffix: "°"},
        { sensor: "sensor.temp1 _2", icon: "wi wi-humidity", suffix: "%"},
                                            In MM:
                                            Temp Test undefined°undefined%
                                            Log from MM:
                                            [2021-01-09 10:36:47.251] [LOG] { undefined: undefined, label: Temp Test }
                                            [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1?api_password= xxxxxx
                                            [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1_2?api_password= xxxxxx
                                            [2021-01-09 10:37:47.524] [LOG] { undefined: undefined, label: Temp Test }
                                            What I have to config in HA? Would be really grateful for tips
