    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 21.2k Views 9 Watching
      cyberphox @sdetweil
      @sdetweil I figured it might not be!
      Thanks!!! You rock as always
      • I
        iorifly @cyberphox
        @cyberphox
        Yes, my mirror works perfectly without the module.
        I have some topics here. look at my problems:
        https://forum.magicmirror.builders/topic/12014/erro-mmm-hass/4
          sdetweil @iorifly
          @iorifly fix reported in other topic
          • I
            iorifly
            With the help of @sdetweil , I was able to solve problems with MM.
            Now I am having trouble accessing HA with MMM-HASS.
              If anyone can help I will be happy.
            alt text
            My HA configuration looks like this configuration.yam:
            homeassistant:
              whitelist_external_dirs:
                - /tmp
                - /config/temp/
              auth_providers:
                  - type: legacy_api_password
                    api_password: "juere3027"
                  - type: trusted_networks
                    trusted_networks:
                      - 192.168.1.0/24
                      - 127.0.0.1
                      - ::1
                    allow_bypass_login: true
                  - type: homeassistant
            config.js
                            module: "MMM-HASS",
                            position: "middle_center",
                                    host: "192.168.1.158",
                                    port: "8123",
                                    apipassword: "juere3027",
                                    hassiotoken: true,
                                    https: false,
                                    devices: [
                                    { deviceLabel: "Quintal",
                                            deviceReadings: [
                                            { sensor: "sensor.caixa_dagua", icon: "mdi:waves", suffix: "%"}
            The mirror executes loads the other modules, but HASS does not load. I have the following output:
            > magicmirror@2.10.1 start /home/pi/MagicMirror
            > ./run-start.sh
            [22:26:04.896] [LOG] Starting MagicMirror: v2.10.1
            [22:26:04.931] [LOG] Loading config ...
            [22:26:04.951] [LOG] Loading module helpers ...
            [22:26:04.959] [LOG] No helper found for module: alert.
            [22:26:05.139] [LOG] Initializing new module helper ...
            [22:26:05.146] [LOG] Module helper loaded: updatenotification
            [22:26:05.151] [LOG] No helper found for module: clock.
            [22:26:06.647] [LOG] Initializing new module helper ...
            [22:26:06.650] [LOG] Module helper loaded: calendar
            [22:26:06.653] [LOG] No helper found for module: compliments.
            [22:26:07.888] [LOG] Initializing new module helper ...
            [22:26:07.890] [LOG] Module helper loaded: MMM-DarkSkyForecast
            [22:26:08.030] [LOG] Initializing new module helper ...
            [22:26:08.035] [LOG] Module helper loaded: newsfeed
            [22:26:08.129] [LOG] Initializing new module helper ...
            [22:26:08.133] [LOG] Module helper loaded: MMM-HASS
            [22:26:08.137] [LOG] All module helpers loaded.
            [22:26:08.143] [LOG] Starting server on port 8080 ...
            [22:26:08.251] [LOG] Server started ...
            [22:26:08.256] [LOG] Connecting socket for: updatenotification
            [22:26:08.261] [LOG] Connecting socket for: calendar
            [22:26:08.265] [LOG] Starting node helper for: calendar
            [22:26:08.268] [LOG] Connecting socket for: MMM-DarkSkyForecast
            [22:26:08.271] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
            [22:26:08.275] [LOG] Connecting socket for: newsfeed
            [22:26:08.278] [LOG] Starting module: newsfeed
            [22:26:08.282] [LOG] Connecting socket for: MMM-HASS
            [22:26:08.288] [LOG] Sockets connected & modules started ...
            [22:26:08.293] [LOG]
            Ready to go! Please point your browser to: http://localhost:8080
            Starting chromium browser now, have patience, it takes a minute
            [22:26:08.451] [ERROR]  { Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                at listenInCluster (net.js:1328:12)
                at GetAddrInfoReqWrap.doListen [as callback] (net.js:1461:7)
                at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '127.0.0.1',
              port: 8080 }
            [22:26:08.444] [LOG]    Whoops! There was an uncaught exception...
            [22:26:08.510] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [22:26:08.512] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
             --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
            [22:26:22.272] [LOG]    Use existing news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml
            [22:26:22.303] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
            [22:26:22.388] [LOG]    { undefined: undefined, label: 'Quintal' }
            • I
              iorifly
              I see that the module tries to connect to the Home assistant.
              https://imgur.com/oHjP479
                sdetweil @iorifly
                @iorifly said in Which modules with Home Assistant currently work?:
                EADDRINUSE
                U already have some application using that port, and are trying to start another
                • I
                  iorifly
                  I don’t know what it would be. It is not related to MMM-HASS.
                  Even with a simple config.js I have this msg. I think I should restart my raspberry.
                    sdetweil @iorifly
                    @iorifly does mm start on boot?
                    • I
                      iorifly
                      Do not. I restarted and the msg stopped. Now I’m fighting with MMM-HASS.
                      I take back what I said. He did give me more information!
                      The mistake I have is in the development of the module. The error is in the connection of the module to the HA system.
                      I can’t do anything but wait for the developer’s announcement.
                      [14:23:57.773] [LOG]    Create new news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml - Interval: 300000
                      [14:23:57.895] [LOG]    { deviceLabel: 'Quintal',
                        deviceReadings:
                         [ { sensor: 'sensor.caixa_dagua',
                             icon: 'wi wi-thermometer',
                             suffix: '%' } ] }
                      [14:23:57.919] [LOG]    192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                      [14:23:57.920] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                      [14:23:58.215] [ERROR]  (node:18860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                      [14:23:58.440] [LOG]    null
                      [14:23:58.443] [LOG]    401: Unauthorized
                      [14:23:58.445] [LOG]    { undefined: undefined, label: 'Quintal' }
                      [14:23:59.415] [LOG]    Refreshed access token because it has expired. Expired at: 14:23:57 now is: 14:23:59
                      [14:23:59.450] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
                      [14:23:59.487] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
                      pi@raspberrypi:~/MagicMirror $
                      • I
                        iorifly
                        I tried this option but also to no avail.
                        https://github.com/aserramonner/MMM-HASS/pull/13
                          darbos @iorifly
                          @iorifly to dvbit point you could just use fullpageos if you just want to display a Lovelace tab…
                          Also, I have had homeassistany sensors working recently…if you want to give some more detail of what you’ve done and what the problem is. And share you relevant code I can try to help…
                          I 1 Reply Last reply
                          • I
                            iorifly @darbos
                            @darbos
                            I would love to know how to display only one lovelace tab. But still it would be the whole screen or I can go down the screen to show only what I want.
                            I have my problem report here too:
                            https://community.home-assistant.io/t/magic-mirror/8443/59
                            what do you need ? I can pass everything !!!
                              dvbit
                              You can use a custom card called custom header to minimize the top and right bar . also having it happen just for the mm through user agent recognition
                                sdetweil @iorifly
                                @iorifly add debuglogging: true,
                                to the config.js for the HASS module
                                it doesn’t handle errors at all… but will report status if that flag is enabled
                                request(get_options, function(error, response, body) {
                                          completed_requests++;
                                          if(config.debuglogging) {
                                            console.log(error);
                                            console.log(body);
                                • I
                                  iorifly @sdetweil
                                  added it to my config.js. However nothing happened or signaled … Thanks anyway.
                                    sdetweil @iorifly
                                    @iorifly Will be in the terminal window, or pm2 logs output
                                    • I
                                      iorifly
                                      I managed to solve !!! Connected !!! THANKS !!
                                        sdetweil @iorifly
                                        @iorifly what was it? Can’t keep us guessing!
                                        • I
                                          iorifly
                                          I created another token (in HA). and replace in the module.
                                          • I
                                            iorifly
                                            but I will try to use this module. It seems to be more complete.
                                            https://github.com/leinich/MMM-homeassistant-sensors
                                            I will create another token in the Home assistant (HA) for him.
