    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 19.5k Views 9 Watching
      cyberphox
      You are using:
      https://github.com/leinich/MMM-homeassistant-sensors
      I said this one works:
      https://github.com/aserramonner/MMM-HASS
      • I Offline
        iorifly
        I tried it, I was unsuccessful. I have no net at the moment. (Problems with a Supplier) When I return, I will try this module again. Hope it works. I will post here.
        • I Offline
          iorifly
          I am having the following problem with him.
          pi@raspberrypi:~/MagicMirror $ ^C
          > magicmirror@2.10.0 start /home/pi/MagicMirror
          > ./run-start.sh
          [21:26:31.205] [LOG] Starting MagicMirror: v2.10.0
          [21:26:31.239] [LOG] Loading config ...
          [21:26:31.258] [LOG] Loading module helpers ...
          [21:26:31.265] [LOG] No helper found for module: alert.
          [21:26:31.449] [LOG] Initializing new module helper ...
          [21:26:31.452] [LOG] Module helper loaded: updatenotification
          [21:26:31.457] [LOG] No helper found for module: clock.
          [21:26:32.663] [LOG] Initializing new module helper ...
          [21:26:32.665] [LOG] Module helper loaded: MMM-Screencast
          [21:26:34.035] [LOG] Initializing new module helper ...
          [21:26:34.037] [LOG] Module helper loaded: calendar
          [21:26:34.039] [LOG] No helper found for module: compliments.
          [21:26:35.266] [LOG] Initializing new module helper ...
          [21:26:35.268] [LOG] Module helper loaded: MMM-DarkSkyForecast
          [21:26:35.410] [LOG] Initializing new module helper ...
          [21:26:35.412] [LOG] Module helper loaded: newsfeed
          [21:26:35.524] [LOG] Initializing new module helper ...
          [21:26:35.526] [LOG] Module helper loaded: MMM-HASS
          [21:26:35.529] [LOG] All module helpers loaded.
          [21:26:35.534] [LOG] Starting server on port 8080 ...
          [21:26:35.643] [LOG] Server started ...
          [21:26:35.649] [LOG] Connecting socket for: updatenotification
          [21:26:35.654] [LOG] Connecting socket for: MMM-Screencast
          [21:26:35.659] [LOG] Connecting socket for: calendar
          [21:26:35.663] [LOG] Starting node helper for: calendar
          [21:26:35.669] [LOG] Connecting socket for: MMM-DarkSkyForecast
          [21:26:35.675] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
          [21:26:35.681] [LOG] Connecting socket for: newsfeed
          [21:26:35.686] [LOG] Starting module: newsfeed
          [21:26:35.689] [LOG] Connecting socket for: MMM-HASS
          [21:26:35.693] [LOG] Sockets connected & modules started ...
          [21:26:35.696] [LOG]
          Ready to go! Please point your browser to: http://localhost:8080
          Starting chromium browser now, have patience, it takes a minute
           --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
          events.js:174
                throw er; // Unhandled 'error' event
          Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
              at doWrite (_stream_writable.js:411:19)
              at writeOrBuffer (_stream_writable.js:399:5)
              at Socket.Writable.write (_stream_writable.js:299:11)
              at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
              at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10)
              at process.emit (events.js:198:13)
              at process._fatalException (internal/bootstrap/node.js:497:27)
          ^C
          load MM, but all modules have msg of loading …
          NOTE: I was missing. Because I was without internet for 05 days.
            dvbit @iorifly
            what prevents you to prepare a dedicated hass lovelace tab and display that with module smartwebdisplay?
            • I Offline
              iorifly @dvbit
              @dvbit said in Which modules with Home Assistant currently work?:
              smartwebdisplay
              I don’t know this module (smartwebdisplay). And I already have a lovelace on my tablet.
              • I Offline
                iorifly @cyberphox
                @cyberphox said in Which modules with Home Assistant currently work?:
                You are using:
                It’s not working either.
                https://forum.magicmirror.builders/topic/12014/erro-mmm-hass/4
                  cyberphox @iorifly
                  @iorifly What is not working? Your MagicMirror itself?
                  Or can you just not add this module?
                  Does your Mirror work fine without this module loaded?
                  S I 2 Replies Last reply Reply Quote 0
                    sdetweil @cyberphox
                    @cyberphox his problem in unrelated to module. I am debugging
                      cyberphox @sdetweil
                      @sdetweil I figured it might not be!
                      Thanks!!! You rock as always
                      • I Offline
                        iorifly @cyberphox
                        @cyberphox
                        Yes, my mirror works perfectly without the module.
                        I have some topics here. look at my problems:
                          sdetweil @iorifly
                          @iorifly fix reported in other topic
                          • I Offline
                            iorifly
                            With the help of @sdetweil , I was able to solve problems with MM.
                            Now I am having trouble accessing HA with MMM-HASS.
                              If anyone can help I will be happy.
                            alt text
                            My HA configuration looks like this configuration.yam:
                            homeassistant:
                              whitelist_external_dirs:
                                - /tmp
                                - /config/temp/
                              auth_providers:
                                  - type: legacy_api_password
                                    api_password: "juere3027"
                                  - type: trusted_networks
                                    trusted_networks:
                                      - 192.168.1.0/24
                                      - 127.0.0.1
                                      - ::1
                                    allow_bypass_login: true
                                  - type: homeassistant
                            config.js
                                            module: "MMM-HASS",
                                            position: "middle_center",
                                                    host: "192.168.1.158",
                                                    port: "8123",
                                                    apipassword: "juere3027",
                                                    hassiotoken: true,
                                                    https: false,
                                                    devices: [
                                                    { deviceLabel: "Quintal",
                                                            deviceReadings: [
                                                            { sensor: "sensor.caixa_dagua", icon: "mdi:waves", suffix: "%"}
                            The mirror executes loads the other modules, but HASS does not load. I have the following output:
                            > magicmirror@2.10.1 start /home/pi/MagicMirror
                            > ./run-start.sh
                            [22:26:04.896] [LOG] Starting MagicMirror: v2.10.1
                            [22:26:04.931] [LOG] Loading config ...
                            [22:26:04.951] [LOG] Loading module helpers ...
                            [22:26:04.959] [LOG] No helper found for module: alert.
                            [22:26:05.139] [LOG] Initializing new module helper ...
                            [22:26:05.146] [LOG] Module helper loaded: updatenotification
                            [22:26:05.151] [LOG] No helper found for module: clock.
                            [22:26:06.647] [LOG] Initializing new module helper ...
                            [22:26:06.650] [LOG] Module helper loaded: calendar
                            [22:26:06.653] [LOG] No helper found for module: compliments.
                            [22:26:07.888] [LOG] Initializing new module helper ...
                            [22:26:07.890] [LOG] Module helper loaded: MMM-DarkSkyForecast
                            [22:26:08.030] [LOG] Initializing new module helper ...
                            [22:26:08.035] [LOG] Module helper loaded: newsfeed
                            [22:26:08.129] [LOG] Initializing new module helper ...
                            [22:26:08.133] [LOG] Module helper loaded: MMM-HASS
                            [22:26:08.137] [LOG] All module helpers loaded.
                            [22:26:08.143] [LOG] Starting server on port 8080 ...
                            [22:26:08.251] [LOG] Server started ...
                            [22:26:08.256] [LOG] Connecting socket for: updatenotification
                            [22:26:08.261] [LOG] Connecting socket for: calendar
                            [22:26:08.265] [LOG] Starting node helper for: calendar
                            [22:26:08.268] [LOG] Connecting socket for: MMM-DarkSkyForecast
                            [22:26:08.271] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                            [22:26:08.275] [LOG] Connecting socket for: newsfeed
                            [22:26:08.278] [LOG] Starting module: newsfeed
                            [22:26:08.282] [LOG] Connecting socket for: MMM-HASS
                            [22:26:08.288] [LOG] Sockets connected & modules started ...
                            [22:26:08.293] [LOG]
                            [22:26:08.451] [ERROR]  { Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                                at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                                at listenInCluster (net.js:1328:12)
                                at GetAddrInfoReqWrap.doListen [as callback] (net.js:1461:7)
                                at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
                              code: 'EADDRINUSE',
                              errno: 'EADDRINUSE',
                              syscall: 'listen',
                              address: '127.0.0.1',
                              port: 8080 }
                            [22:26:08.444] [LOG]    Whoops! There was an uncaught exception...
                            [22:26:08.510] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            [22:26:08.512] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            [22:26:22.272] [LOG]    Use existing news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml
                            [22:26:22.303] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                            [22:26:22.388] [LOG]    { undefined: undefined, label: 'Quintal' }
                            • I Offline
                              iorifly
                              I see that the module tries to connect to the Home assistant.
                              https://imgur.com/oHjP479
                                sdetweil @iorifly
                                @iorifly said in Which modules with Home Assistant currently work?:
                                EADDRINUSE
                                U already have some application using that port, and are trying to start another
                                • I Offline
                                  iorifly
                                  I don’t know what it would be. It is not related to MMM-HASS.
                                  Even with a simple config.js I have this msg. I think I should restart my raspberry.
                                    sdetweil @iorifly
                                    @iorifly does mm start on boot?
                                    • I Offline
                                      iorifly
                                      Do not. I restarted and the msg stopped. Now I’m fighting with MMM-HASS.
                                      I take back what I said. He did give me more information!
                                      The mistake I have is in the development of the module. The error is in the connection of the module to the HA system.
                                      I can’t do anything but wait for the developer’s announcement.
                                      [14:23:57.773] [LOG]    Create new news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml - Interval: 300000
                                      [14:23:57.895] [LOG]    { deviceLabel: 'Quintal',
                                        deviceReadings:
                                         [ { sensor: 'sensor.caixa_dagua',
                                             icon: 'wi wi-thermometer',
                                             suffix: '%' } ] }
                                      [14:23:57.919] [LOG]    192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                                      [14:23:57.920] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                                      [14:23:58.215] [ERROR]  (node:18860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                      [14:23:58.440] [LOG]    null
                                      [14:23:58.443] [LOG]    401: Unauthorized
                                      [14:23:58.445] [LOG]    { undefined: undefined, label: 'Quintal' }
                                      [14:23:59.415] [LOG]    Refreshed access token because it has expired. Expired at: 14:23:57 now is: 14:23:59
                                      [14:23:59.450] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
                                      [14:23:59.487] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
                                      • I Offline
                                        iorifly
                                        I tried this option but also to no avail.
                                        https://github.com/aserramonner/MMM-HASS/pull/13
                                          darbos @iorifly
                                          @iorifly to dvbit point you could just use fullpageos if you just want to display a Lovelace tab…
                                          Also, I have had homeassistany sensors working recently…if you want to give some more detail of what you’ve done and what the problem is. And share you relevant code I can try to help…
                                          • I Offline
                                            iorifly @darbos
                                            @darbos
                                            I would love to know how to display only one lovelace tab. But still it would be the whole screen or I can go down the screen to show only what I want.
                                            I have my problem report here too:
                                            https://community.home-assistant.io/t/magic-mirror/8443/59
                                            what do you need ? I can pass everything !!!
