    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 21.2k Views 9 Watching
    • I
      iorifly @dvbit
      @dvbit said in Which modules with Home Assistant currently work?:
      smartwebdisplay
      I don’t know this module (smartwebdisplay). And I already have a lovelace on my tablet.
      D 1 Reply Last reply
      • I
        iorifly @cyberphox
        @cyberphox said in Which modules with Home Assistant currently work?:
        You are using:
        https://github.com/leinich/MMM-homeassistant-sensors
        I said this one works:
        https://github.com/aserramonner/MMM-HASS
        It’s not working either.
        https://forum.magicmirror.builders/topic/12014/erro-mmm-hass/4
        C 1 Reply Last reply
          cyberphox @iorifly
          @iorifly What is not working? Your MagicMirror itself?
          Or can you just not add this module?
          Does your Mirror work fine without this module loaded?
          S I 2 Replies Last reply
            sdetweil @cyberphox
            @cyberphox his problem in unrelated to module. I am debugging
              cyberphox @sdetweil
              @sdetweil I figured it might not be!
              Thanks!!! You rock as always
              • I
                iorifly @cyberphox
                @cyberphox
                Yes, my mirror works perfectly without the module.
                I have some topics here. look at my problems:
                  sdetweil @iorifly
                  @iorifly fix reported in other topic
                  • I
                    iorifly
                    With the help of @sdetweil , I was able to solve problems with MM.
                    Now I am having trouble accessing HA with MMM-HASS.
                      If anyone can help I will be happy.
                    alt text
                    My HA configuration looks like this configuration.yam:
                    homeassistant:
                      whitelist_external_dirs:
                        - /tmp
                        - /config/temp/
                      auth_providers:
                          - type: legacy_api_password
                            api_password: "juere3027"
                          - type: trusted_networks
                            trusted_networks:
                              - 192.168.1.0/24
                              - 127.0.0.1
                              - ::1
                            allow_bypass_login: true
                          - type: homeassistant
                    config.js
                                    module: "MMM-HASS",
                                    position: "middle_center",
                                            host: "192.168.1.158",
                                            port: "8123",
                                            apipassword: "juere3027",
                                            hassiotoken: true,
                                            https: false,
                                            devices: [
                                            { deviceLabel: "Quintal",
                                                    deviceReadings: [
                                                    { sensor: "sensor.caixa_dagua", icon: "mdi:waves", suffix: "%"}
                    The mirror executes loads the other modules, but HASS does not load. I have the following output:
                    > magicmirror@2.10.1 start /home/pi/MagicMirror
                    > ./run-start.sh
                    [22:26:04.896] [LOG] Starting MagicMirror: v2.10.1
                    [22:26:04.931] [LOG] Loading config ...
                    [22:26:04.951] [LOG] Loading module helpers ...
                    [22:26:04.959] [LOG] No helper found for module: alert.
                    [22:26:05.139] [LOG] Initializing new module helper ...
                    [22:26:05.146] [LOG] Module helper loaded: updatenotification
                    [22:26:05.151] [LOG] No helper found for module: clock.
                    [22:26:06.647] [LOG] Initializing new module helper ...
                    [22:26:06.650] [LOG] Module helper loaded: calendar
                    [22:26:06.653] [LOG] No helper found for module: compliments.
                    [22:26:07.888] [LOG] Initializing new module helper ...
                    [22:26:07.890] [LOG] Module helper loaded: MMM-DarkSkyForecast
                    [22:26:08.030] [LOG] Initializing new module helper ...
                    [22:26:08.035] [LOG] Module helper loaded: newsfeed
                    [22:26:08.129] [LOG] Initializing new module helper ...
                    [22:26:08.133] [LOG] Module helper loaded: MMM-HASS
                    [22:26:08.137] [LOG] All module helpers loaded.
                    [22:26:08.143] [LOG] Starting server on port 8080 ...
                    [22:26:08.251] [LOG] Server started ...
                    [22:26:08.256] [LOG] Connecting socket for: updatenotification
                    [22:26:08.261] [LOG] Connecting socket for: calendar
                    [22:26:08.265] [LOG] Starting node helper for: calendar
                    [22:26:08.268] [LOG] Connecting socket for: MMM-DarkSkyForecast
                    [22:26:08.271] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                    [22:26:08.275] [LOG] Connecting socket for: newsfeed
                    [22:26:08.278] [LOG] Starting module: newsfeed
                    [22:26:08.282] [LOG] Connecting socket for: MMM-HASS
                    [22:26:08.288] [LOG] Sockets connected & modules started ...
                    [22:26:08.293] [LOG]
                    Ready to go! Please point your browser to: http://localhost:8080
                    Starting chromium browser now, have patience, it takes a minute
                    [22:26:08.451] [ERROR]  { Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                        at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                        at listenInCluster (net.js:1328:12)
                        at GetAddrInfoReqWrap.doListen [as callback] (net.js:1461:7)
                        at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
                      code: 'EADDRINUSE',
                      errno: 'EADDRINUSE',
                      syscall: 'listen',
                      address: '127.0.0.1',
                      port: 8080 }
                    [22:26:08.444] [LOG]    Whoops! There was an uncaught exception...
                    [22:26:08.510] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [22:26:08.512] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                     --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
                    [22:26:22.272] [LOG]    Use existing news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml
                    [22:26:22.303] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                    [22:26:22.388] [LOG]    { undefined: undefined, label: 'Quintal' }
                    • I
                      iorifly
                      I see that the module tries to connect to the Home assistant.
                      https://imgur.com/oHjP479
                        sdetweil @iorifly
                        @iorifly said in Which modules with Home Assistant currently work?:
                        EADDRINUSE
                        U already have some application using that port, and are trying to start another
                        • I
                          iorifly
                          I don’t know what it would be. It is not related to MMM-HASS.
                          Even with a simple config.js I have this msg. I think I should restart my raspberry.
                            sdetweil @iorifly
                            @iorifly does mm start on boot?
                            • I
                              iorifly
                              Do not. I restarted and the msg stopped. Now I’m fighting with MMM-HASS.
                              I take back what I said. He did give me more information!
                              The mistake I have is in the development of the module. The error is in the connection of the module to the HA system.
                              I can’t do anything but wait for the developer’s announcement.
                              [14:23:57.773] [LOG]    Create new news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml - Interval: 300000
                              [14:23:57.895] [LOG]    { deviceLabel: 'Quintal',
                                deviceReadings:
                                 [ { sensor: 'sensor.caixa_dagua',
                                     icon: 'wi wi-thermometer',
                                     suffix: '%' } ] }
                              [14:23:57.919] [LOG]    192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                              [14:23:57.920] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                              [14:23:58.215] [ERROR]  (node:18860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                              [14:23:58.440] [LOG]    null
                              [14:23:58.443] [LOG]    401: Unauthorized
                              [14:23:58.445] [LOG]    { undefined: undefined, label: 'Quintal' }
                              [14:23:59.415] [LOG]    Refreshed access token because it has expired. Expired at: 14:23:57 now is: 14:23:59
                              [14:23:59.450] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
                              [14:23:59.487] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
                              pi@raspberrypi:~/MagicMirror $
                              • I
                                iorifly
                                I tried this option but also to no avail.
                                https://github.com/aserramonner/MMM-HASS/pull/13
                                  darbos @iorifly
                                  @iorifly to dvbit point you could just use fullpageos if you just want to display a Lovelace tab…
                                  Also, I have had homeassistany sensors working recently…if you want to give some more detail of what you’ve done and what the problem is. And share you relevant code I can try to help…
                                  I 1 Reply Last reply
                                  • I
                                    iorifly @darbos
                                    @darbos
                                    I would love to know how to display only one lovelace tab. But still it would be the whole screen or I can go down the screen to show only what I want.
                                    I have my problem report here too:
                                    https://community.home-assistant.io/t/magic-mirror/8443/59
                                    what do you need ? I can pass everything !!!
                                      dvbit
                                      You can use a custom card called custom header to minimize the top and right bar . also having it happen just for the mm through user agent recognition
                                        sdetweil @iorifly
                                        @iorifly add debuglogging: true,
                                        to the config.js for the HASS module
                                        it doesn’t handle errors at all… but will report status if that flag is enabled
                                        request(get_options, function(error, response, body) {
                                                  completed_requests++;
                                                  if(config.debuglogging) {
                                                    console.log(error);
                                                    console.log(body);
                                        • I
                                          iorifly @sdetweil
                                          added it to my config.js. However nothing happened or signaled … Thanks anyway.
                                            sdetweil @iorifly
                                            @iorifly Will be in the terminal window, or pm2 logs output
