    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 21.2k Views 9 Watching
    • I
      iorifly
      I don’t know what it would be. It is not related to MMM-HASS.
      Even with a simple config.js I have this msg. I think I should restart my raspberry.
        sdetweil @iorifly
        @iorifly does mm start on boot?
        • I
          iorifly
          Do not. I restarted and the msg stopped. Now I’m fighting with MMM-HASS.
          I take back what I said. He did give me more information!
          The mistake I have is in the development of the module. The error is in the connection of the module to the HA system.
          I can’t do anything but wait for the developer’s announcement.
          [14:23:57.773] [LOG]    Create new news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml - Interval: 300000
          [14:23:57.895] [LOG]    { deviceLabel: 'Quintal',
            deviceReadings:
             [ { sensor: 'sensor.caixa_dagua',
                 icon: 'wi wi-thermometer',
                 suffix: '%' } ] }
          [14:23:57.919] [LOG]    192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
          [14:23:57.920] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
          [14:23:58.215] [ERROR]  (node:18860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          [14:23:58.440] [LOG]    null
          [14:23:58.443] [LOG]    401: Unauthorized
          [14:23:58.445] [LOG]    { undefined: undefined, label: 'Quintal' }
          [14:23:59.415] [LOG]    Refreshed access token because it has expired. Expired at: 14:23:57 now is: 14:23:59
          [14:23:59.450] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
          [14:23:59.487] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
          pi@raspberrypi:~/MagicMirror $
          • I
            iorifly
            I tried this option but also to no avail.
            https://github.com/aserramonner/MMM-HASS/pull/13
              darbos @iorifly
              @iorifly to dvbit point you could just use fullpageos if you just want to display a Lovelace tab…
              Also, I have had homeassistany sensors working recently…if you want to give some more detail of what you’ve done and what the problem is. And share you relevant code I can try to help…
              I 1 Reply Last reply
              • I
                iorifly @darbos
                @darbos
                I would love to know how to display only one lovelace tab. But still it would be the whole screen or I can go down the screen to show only what I want.
                I have my problem report here too:
                https://community.home-assistant.io/t/magic-mirror/8443/59
                what do you need ? I can pass everything !!!
                  dvbit
                  You can use a custom card called custom header to minimize the top and right bar . also having it happen just for the mm through user agent recognition
                    sdetweil @iorifly
                    @iorifly add debuglogging: true,
                    to the config.js for the HASS module
                    it doesn’t handle errors at all… but will report status if that flag is enabled
                    request(get_options, function(error, response, body) {
                              completed_requests++;
                              if(config.debuglogging) {
                                console.log(error);
                                console.log(body);
                    • I
                      iorifly @sdetweil
                      added it to my config.js. However nothing happened or signaled … Thanks anyway.
                        sdetweil @iorifly
                        @iorifly Will be in the terminal window, or pm2 logs output
                        • I
                          iorifly
                          I managed to solve !!! Connected !!! THANKS !!
                            sdetweil @iorifly
                            @iorifly what was it? Can’t keep us guessing!
                            • I
                              iorifly
                              I created another token (in HA). and replace in the module.
                              • I
                                iorifly
                                but I will try to use this module. It seems to be more complete.
                                https://github.com/leinich/MMM-homeassistant-sensors
                                I will create another token in the Home assistant (HA) for him.
                                • I
                                  iorifly
                                  actually this module is also working. That is,
                                  operational modules tested by me:
                                  MMM-HASS
                                    Babene1 Project Sponsor
                                    i want to use the modul MMM-HASS
                                    but i get the error in HA “Login attempt or request with invalid authentication from”
                                    i use Home Assistant 0.116.2
                                    here is my MM-Config from the Modul:
                                               module: "MMM-HASS",
                                                       host: "xxx.xxx.xxx.xxx",
                                                       port: "8123",
                                                       apipassword: "xxxxxx",
                                                       hassiotoken: true,
                                                       token: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                                       https: false,
                                                       devices: [
                                                       { deviceLabel: "Temp Test",
                                                               deviceReadings: [
                                                               { sensor: "sensor.temp1", icon: "wi wi-thermometer", suffix: "°"},
                                                               { sensor: "sensor.temp1 _2", icon: "wi wi-humidity", suffix: "%"},
                                    In MM:
                                    Temp Test undefined°undefined%
                                    Log from MM:
                                    [2021-01-09 10:36:47.251] [LOG] { undefined: undefined, label: Temp Test }
                                    [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1?api_password= xxxxxx
                                    [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1_2?api_password= xxxxxx
                                    [2021-01-09 10:37:47.524] [LOG] { undefined: undefined, label: Temp Test }
                                    What I have to config in HA? Would be really grateful for tips
                                    B 1 Reply Last reply
                                      Babene1 Project Sponsor @Babene1
                                      Only for information, in case someone has the same problem.
                                      The module works for me now, with the above configuration
                                      I found the following articles: https://github.com/aserramonner/MMM-HASS/pull/13/commits/bd816304ba146ad84bce5cada65cb3416194aca7
                                      I made these changes: In File „node_helper.js“ von MMM-HASS
                                      row 130 changed in:
                                      post_options.headers = { 'Authorization' : 'Bearer ' + config.token };
                                      row 176 changed in:
                                      get_options.headers = { 'Authorization' : 'Bearer ' + config.token };
                                      Coolie1101C 1 Reply Last reply
                                      • Coolie1101C
                                        Coolie1101 @Babene1
                                        @babene1 Hey, I followed your setup instructions but still get undefined for the sensors, any ideas?
                                        Config
        module: "MMM-HASS",
        host: "hass_ip",
        port: "8123",
        apipassword: "hass_api_password",
        hassiotoken: "true",
        token: "hass_token_for_MMM-HASS"
        https: false,
        devices: [
        { deviceLabel: "Interior",
        deviceReadings: [
        { sensor: "sensor.living_room_thermostat_temperature"},
        { sensor: "sensor.living_room_ac_temperature"}
                                          Babene1 Project Sponsor @Coolie1101
                                          @coolie1101 do you make changes in „node_helper.js“ from MMM-HASS?
                                          • Coolie1101C
                                            Coolie1101 @Babene1
                                            @babene1 yes
