    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 20.3k Views 9 Watching
      darbos @iorifly
      @iorifly to dvbit point you could just use fullpageos if you just want to display a Lovelace tab…
      Also, I have had homeassistany sensors working recently…if you want to give some more detail of what you’ve done and what the problem is. And share you relevant code I can try to help…
      • I Offline
        iorifly @darbos
        @darbos
        I would love to know how to display only one lovelace tab. But still it would be the whole screen or I can go down the screen to show only what I want.
        I have my problem report here too:
        https://community.home-assistant.io/t/magic-mirror/8443/59
        what do you need ? I can pass everything !!!
          dvbit
          You can use a custom card called custom header to minimize the top and right bar . also having it happen just for the mm through user agent recognition
            sdetweil @iorifly
            @iorifly add debuglogging: true,
            to the config.js for the HASS module
            it doesn’t handle errors at all… but will report status if that flag is enabled
            request(get_options, function(error, response, body) {
                      completed_requests++;
                      if(config.debuglogging) {
                        console.log(error);
                        console.log(body);
            • I Offline
              iorifly @sdetweil
              added it to my config.js. However nothing happened or signaled … Thanks anyway.
                sdetweil @iorifly
                @iorifly Will be in the terminal window, or pm2 logs output
                • I Offline
                  iorifly
                  I managed to solve !!! Connected !!! THANKS !!
                    sdetweil @iorifly
                    @iorifly what was it? Can’t keep us guessing!
                    • I Offline
                      iorifly
                      I created another token (in HA). and replace in the module.
                      • I Offline
                        iorifly
                        but I will try to use this module. It seems to be more complete.
                        https://github.com/leinich/MMM-homeassistant-sensors
                        I will create another token in the Home assistant (HA) for him.
                        • I Offline
                          iorifly
                          actually this module is also working. That is,
                          operational modules tested by me:
                          MMM-HASS
                            Babene1 Project Sponsor
                            i want to use the modul MMM-HASS
                            but i get the error in HA “Login attempt or request with invalid authentication from”
                            i use Home Assistant 0.116.2
                            here is my MM-Config from the Modul:
                                       module: "MMM-HASS",
                                               host: "xxx.xxx.xxx.xxx",
                                               port: "8123",
                                               apipassword: "xxxxxx",
                                               hassiotoken: true,
                                               token: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                               https: false,
                                               devices: [
                                               { deviceLabel: "Temp Test",
                                                       deviceReadings: [
                                                       { sensor: "sensor.temp1", icon: "wi wi-thermometer", suffix: "°"},
                                                       { sensor: "sensor.temp1 _2", icon: "wi wi-humidity", suffix: "%"},
                            In MM:
                            Temp Test undefined°undefined%
                            Log from MM:
                            [2021-01-09 10:36:47.251] [LOG] { undefined: undefined, label: Temp Test }
                            [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1?api_password= xxxxxx
                            [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1_2?api_password= xxxxxx
                            [2021-01-09 10:37:47.524] [LOG] { undefined: undefined, label: Temp Test }
                            What I have to config in HA? Would be really grateful for tips
                              Babene1 Project Sponsor @Babene1
                              Only for information, in case someone has the same problem.
                              The module works for me now, with the above configuration
                              I found the following articles: https://github.com/aserramonner/MMM-HASS/pull/13/commits/bd816304ba146ad84bce5cada65cb3416194aca7
                              I made these changes: In File „node_helper.js“ von MMM-HASS
                              row 130 changed in:
                              post_options.headers = { 'Authorization' : 'Bearer ' + config.token };
                              row 176 changed in:
                              get_options.headers = { 'Authorization' : 'Bearer ' + config.token };
                              Coolie1101C 1 Reply Last reply Reply Quote 0
                              • Coolie1101C Offline
                                Coolie1101 @Babene1
                                @babene1 Hey, I followed your setup instructions but still get undefined for the sensors, any ideas?
                                Config
                                                        module: "MMM-HASS",
        host: "hass_ip",
        port: "8123",
        apipassword: "hass_api_password",
        hassiotoken: "true",
        token: "hass_token_for_MMM-HASS"
        https: false,
        devices: [
        { deviceLabel: "Interior",
        deviceReadings: [
        { sensor: "sensor.living_room_thermostat_temperature"},
        { sensor: "sensor.living_room_ac_temperature"}
                                  Babene1 Project Sponsor @Coolie1101
                                  @coolie1101 do you make changes in „node_helper.js“ from MMM-HASS?
                                    Coolie1101 @Babene1
                                    @babene1 yes
                                      @coolie1101 do you have an error entry in the home assistant log?
                                        Coolie1101 @Babene1
                                        @babene1 No, no errors, in HA.
