    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 21.2k Views 9 Watching
    • I
      iorifly
      I tried this option but also to no avail.
      https://github.com/aserramonner/MMM-HASS/pull/13
        darbos @iorifly
        @iorifly to dvbit point you could just use fullpageos if you just want to display a Lovelace tab…
        Also, I have had homeassistany sensors working recently…if you want to give some more detail of what you’ve done and what the problem is. And share you relevant code I can try to help…
        I 1 Reply Last reply
        • I
          iorifly @darbos
          @darbos
          I would love to know how to display only one lovelace tab. But still it would be the whole screen or I can go down the screen to show only what I want.
          I have my problem report here too:
          https://community.home-assistant.io/t/magic-mirror/8443/59
          what do you need ? I can pass everything !!!
            dvbit
            You can use a custom card called custom header to minimize the top and right bar . also having it happen just for the mm through user agent recognition
              sdetweil @iorifly
              @iorifly add debuglogging: true,
              to the config.js for the HASS module
              it doesn’t handle errors at all… but will report status if that flag is enabled
              request(get_options, function(error, response, body) {
                        completed_requests++;
                        if(config.debuglogging) {
                          console.log(error);
                          console.log(body);
              • I
                iorifly @sdetweil
                added it to my config.js. However nothing happened or signaled … Thanks anyway.
                  sdetweil @iorifly
                  @iorifly Will be in the terminal window, or pm2 logs output
                  • I
                    iorifly
                    I managed to solve !!! Connected !!! THANKS !!
                      sdetweil @iorifly
                      @iorifly what was it? Can’t keep us guessing!
                      • I
                        iorifly
                        I created another token (in HA). and replace in the module.
                        • I
                          iorifly
                          but I will try to use this module. It seems to be more complete.
                          https://github.com/leinich/MMM-homeassistant-sensors
                          I will create another token in the Home assistant (HA) for him.
                          • I
                            iorifly
                            actually this module is also working. That is,
                            operational modules tested by me:
                            MMM-HASS
                              Babene1 Project Sponsor
                              i want to use the modul MMM-HASS
                              but i get the error in HA “Login attempt or request with invalid authentication from”
                              i use Home Assistant 0.116.2
                              here is my MM-Config from the Modul:
                                         module: "MMM-HASS",
                                                 host: "xxx.xxx.xxx.xxx",
                                                 port: "8123",
                                                 apipassword: "xxxxxx",
                                                 hassiotoken: true,
                                                 token: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                                 https: false,
                                                 devices: [
                                                 { deviceLabel: "Temp Test",
                                                         deviceReadings: [
                                                         { sensor: "sensor.temp1", icon: "wi wi-thermometer", suffix: "°"},
                                                         { sensor: "sensor.temp1 _2", icon: "wi wi-humidity", suffix: "%"},
                              In MM:
                              Temp Test undefined°undefined%
                              Log from MM:
                              [2021-01-09 10:36:47.251] [LOG] { undefined: undefined, label: Temp Test }
                              [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1?api_password= xxxxxx
                              [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1_2?api_password= xxxxxx
                              [2021-01-09 10:37:47.524] [LOG] { undefined: undefined, label: Temp Test }
                              What I have to config in HA? Would be really grateful for tips
                              B 1 Reply Last reply
                                Babene1 Project Sponsor @Babene1
                                Only for information, in case someone has the same problem.
                                The module works for me now, with the above configuration
                                I found the following articles: https://github.com/aserramonner/MMM-HASS/pull/13/commits/bd816304ba146ad84bce5cada65cb3416194aca7
                                I made these changes: In File „node_helper.js“ von MMM-HASS
                                row 130 changed in:
                                post_options.headers = { 'Authorization' : 'Bearer ' + config.token };
                                row 176 changed in:
                                get_options.headers = { 'Authorization' : 'Bearer ' + config.token };
                                Coolie1101C 1 Reply Last reply
                                • Coolie1101C
                                  Coolie1101 @Babene1
                                  @babene1 Hey, I followed your setup instructions but still get undefined for the sensors, any ideas?
                                  Config
                                                          module: "MMM-HASS",
        host: "hass_ip",
        port: "8123",
        apipassword: "hass_api_password",
        hassiotoken: "true",
        token: "hass_token_for_MMM-HASS"
        https: false,
        devices: [
        { deviceLabel: "Interior",
        deviceReadings: [
        { sensor: "sensor.living_room_thermostat_temperature"},
        { sensor: "sensor.living_room_ac_temperature"}
                                    Babene1 Project Sponsor @Coolie1101
                                    @coolie1101 do you make changes in „node_helper.js“ from MMM-HASS?
                                    • Coolie1101C
                                      Coolie1101 @Babene1
                                      @babene1 yes
                                        @coolie1101 do you have an error entry in the home assistant log?
                                        • Coolie1101C
                                          Coolie1101 @Babene1
                                          @babene1 No, no errors, in HA.
