    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 15.8k Views 9 Watching
    • I Offline
      iorifly
      Dear,
      I have HA working for many years. I would like to add to MM, however, I’ve tried two modules and I can not configure any … Any charitable soul, could help me in this way ??
        cyberphox
        MMM-HASS works
        • I Offline
          iorifly
          I am trying to use this:
          but I am having the following problem :(:
          https://forum.magicmirror.builders/topic/11972/mmm-homeassistant-sensors-erro
            cyberphox
            You are using:
            https://github.com/leinich/MMM-homeassistant-sensors
            I said this one works:
            https://github.com/aserramonner/MMM-HASS
            • I Offline
              iorifly
              I tried it, I was unsuccessful. I have no net at the moment. (Problems with a Supplier) When I return, I will try this module again. Hope it works. I will post here.
              • I Offline
                iorifly
                I am having the following problem with him.
                pi@raspberrypi:~/MagicMirror $ ^C
                > magicmirror@2.10.0 start /home/pi/MagicMirror
                > ./run-start.sh
                [21:26:31.205] [LOG] Starting MagicMirror: v2.10.0
                [21:26:31.239] [LOG] Loading config ...
                [21:26:31.258] [LOG] Loading module helpers ...
                [21:26:31.265] [LOG] No helper found for module: alert.
                [21:26:31.449] [LOG] Initializing new module helper ...
                [21:26:31.452] [LOG] Module helper loaded: updatenotification
                [21:26:31.457] [LOG] No helper found for module: clock.
                [21:26:32.663] [LOG] Initializing new module helper ...
                [21:26:32.665] [LOG] Module helper loaded: MMM-Screencast
                [21:26:34.035] [LOG] Initializing new module helper ...
                [21:26:34.037] [LOG] Module helper loaded: calendar
                [21:26:34.039] [LOG] No helper found for module: compliments.
                [21:26:35.266] [LOG] Initializing new module helper ...
                [21:26:35.268] [LOG] Module helper loaded: MMM-DarkSkyForecast
                [21:26:35.410] [LOG] Initializing new module helper ...
                [21:26:35.412] [LOG] Module helper loaded: newsfeed
                [21:26:35.524] [LOG] Initializing new module helper ...
                [21:26:35.526] [LOG] Module helper loaded: MMM-HASS
                [21:26:35.529] [LOG] All module helpers loaded.
                [21:26:35.534] [LOG] Starting server on port 8080 ...
                [21:26:35.643] [LOG] Server started ...
                [21:26:35.649] [LOG] Connecting socket for: updatenotification
                [21:26:35.654] [LOG] Connecting socket for: MMM-Screencast
                [21:26:35.659] [LOG] Connecting socket for: calendar
                [21:26:35.663] [LOG] Starting node helper for: calendar
                [21:26:35.669] [LOG] Connecting socket for: MMM-DarkSkyForecast
                [21:26:35.675] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                [21:26:35.681] [LOG] Connecting socket for: newsfeed
                [21:26:35.686] [LOG] Starting module: newsfeed
                [21:26:35.689] [LOG] Connecting socket for: MMM-HASS
                [21:26:35.693] [LOG] Sockets connected & modules started ...
                [21:26:35.696] [LOG]
                Ready to go! Please point your browser to: http://localhost:8080
                Starting chromium browser now, have patience, it takes a minute
                 --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
                events.js:174
                      throw er; // Unhandled 'error' event
                Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                    at doWrite (_stream_writable.js:411:19)
                    at writeOrBuffer (_stream_writable.js:399:5)
                    at Socket.Writable.write (_stream_writable.js:299:11)
                    at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
                    at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10)
                    at process.emit (events.js:198:13)
                    at process._fatalException (internal/bootstrap/node.js:497:27)
                ^C
                load MM, but all modules have msg of loading …
                NOTE: I was missing. Because I was without internet for 05 days.
                  dvbit @iorifly
                  what prevents you to prepare a dedicated hass lovelace tab and display that with module smartwebdisplay?
                  • I Offline
                    iorifly @dvbit
                    @dvbit said in Which modules with Home Assistant currently work?:
                    smartwebdisplay
                    I don’t know this module (smartwebdisplay). And I already have a lovelace on my tablet.
                    • I Offline
                      iorifly @cyberphox
                      @cyberphox said in Which modules with Home Assistant currently work?:
                      You are using:
                      It’s not working either.
                      https://forum.magicmirror.builders/topic/12014/erro-mmm-hass/4
                        cyberphox @iorifly
                        @iorifly What is not working? Your MagicMirror itself?
                        Or can you just not add this module?
                        Does your Mirror work fine without this module loaded?
                        S I 2 Replies Last reply Reply Quote 0
                        • 1 / 4
