    organization of the text next to the icon.
    48 Posts 3 Posters 27.6k Views 5 Watching
      text alignment, you will have to change the code. the author did not provide element classes you could modify with css. (see the code from one of my prior posts, he just set style to ‘align-left’ or ‘align-right’ or let it default (text nodes align right by default for ltr languages)
      adding a line under some entries,
      you will have to modify the code to add that capability
        doubleT Module Developer
        It can be done in css even if there are no class names. Give me a minute.
        • I Offline
          iorifly
          Thanks! I’m in no hurry. Even because it took me a long time to get here. sdetweil helped me extremely.
          Thank you very much for all your support! sensational you !!!.
            If you want to work in the code and are not afraid that an update might overwrite it, you could try to change
            		// Name
            		newCell = newrow.insertCell(1);
            		newText = document.createTextNode(name);
            		newCell.appendChild(newText);
            to
            		// Name
            		newCell.className = "align-left";
            That seems to be what’s aligning the icon cell to the left. That css comes from MM’s main.css.
            • I Offline
              iorifly
              I will try to locate this code.
              in which module file do I look for it?
                MMM-homeassistant-sensors.js
                • I Offline
                  iorifly
                  @doubleT said in organization of the text next to the icon.:
                  newCell.className = “align-left”;
                  alignment resolved. Can I now create lines to separate groups? Or is it impossible?
                    Ok, please keep in mind that this is not the best solution (working directly in the code).
                    If you want to make the changes via custom.css file, try this:
                    (Now, since the module is called “MMM-homeassistant-sensors” I’m going to assume the element is identifiable with _“.module.MMM-homeassistant-sensors” …)
                    Tell each 2nd cell to align its content left:
                    .module.MMM-homeassistant-sensors table tr td:nth-of-type(2) {
                        text-align: left;
                    Tell the cells of the 3rd and 6th line to have a bottom border line:
                    .module.MMM-homeassistant-sensors table tr:nth-of-type(3) td,
                    .module.MMM-homeassistant-sensors table tr:nth-of-type(6) td {
                        border-bottom: 1px solid white;
                    If the line is separated, try:
                    .module.MMM-homeassistant-sensors table {
                        border-spacing: 0;
                    EDIT: There was an error, it’s text-align, of course. Not test-align.
                    • I Offline
                      iorifly
                      Let me see if I got it. I need to change the custom.css file. Where is it located?
                      in the css folder. I only have the main.css file
                        Create a file named “custom.css” and put the code from above inside it.
                        • I Offline
                          iorifly
                          border-spacing: 0;
                          nothing happened. This is the same way. He did not create the lines.
                            Yeeeeah … what about the one above that? The 2nd part. ;)
                              sdetweil @iorifly
                              @iorifly take the .module prefix off, not needed
                              • I Offline
                                iorifly @sdetweil
                                @sdetweil ok
                                • I Offline
                                  iorifly @doubleT
                                  @doubleT
                                  excuse. LOL
                                    I did not understand.
                                    The content of the custom.css should be:
                                        test-align: left;
                                        border-spacing: 0;
                                    All of it. Not just the last part.
                                    • I Offline
                                      iorifly
                                      test-align: left;
                                      border-spacing: 0;
                                          test-align: left;
                                          border-spacing: 0;
                                        @sdetweil I don’t have any modules with uper case letters (MMM- …) at the moment. Can you confirm the module class name is with uper case letters or is it changed to lower case?
                                        In this situation, with a unique module name, it’s ok to identfy the module without the .module but in general I’d say it’s best practice that if you want to address a specific module, you describe it as precise as possible.
                                        E.g. there might be a module “image_frame” that you want to address but there’s also a module that somewhere within its structure has one div with the class “image_frame” that you don’t want to address. Then it’s absolutely necessary to address the target with .module.image_frame
                                        • I Offline
                                          iorifly
                                          added “.modulo” before .MMM
                                            And that worked? :thinking_face:
                                            • 2 / 3
