    organization of the text next to the icon.
    48 Posts 3 Posters 27.3k Views 5 Watching
      doubleT Module Developer
      Because the creator of that module gave the wrapper the class name “dimmed” in line 38 …
      • I Offline
        iorifly
        @doubleT Unfortunately not.
        • I Offline
          iorifly @doubleT
          @doubleT said in organization of the text next to the icon.:
          esmaecido
          what I put in place to make it clearer (alive)
            Can you show me what your custom.css file looks like now?
            • I Offline
              iorifly
              @doubleT
              .module.MMM-homeassistant-sensors table tr td:nth-of-type(2) {
                  test-align: left;
              .module.MMM-homeassistant-sensors table tr:nth-of-type(3) td,
              .module.MMM-homeassistant-sensors table tr:nth-of-type(6) td {
                  border-bottom: 1px solid white;
              .module.MMM-homeassistant-sensors table {
                  border-spacing: 0;
              note: I’m slow to answer because I have to wait 120s to post.
                Oh, I noticed a typo – even though that’s not the reason it’s not working. Change te_s_t-align to text-align, please. ;)
                What’s the name of the module in your config file?
                • I Offline
                  iorifly @doubleT
                  x t-align
                  hitting the text did not appear the line either.
                    In that case the css should work. And the css file is named custom.css? Exactly like that? And you restarted the mirror?
                    Since we’re already working directly in the code: In the module js there’s a line
                    var tableElement = document.createElement("table");
                    You can write a line directly after that:
                    tableElement.className = "homeassistant-table";
                    Then you should be able to address the table in the cusom.css like this:
                    .homeassistant-table tr td:nth-of-type(2) {
                        text-align: left;
                    .homeassistant-table tr:nth-of-type(3) td,
                    .homeassistant-table tr:nth-of-type(6) td {
                    .homeassistant-table {
                        border-spacing: 0;
                    Is the text brighter now?
                    EDIT: tableElement, not table.Element
                    • I Offline
                      iorifly
                      text-align: left;
                      border-spacing: 0;
                      do I delete the text from what was in the custom? or leave and put this?
                        Delete the previous code in custom.css if you added that className line in the module’s js.
                        • I Offline
                          iorifly @doubleT
                          @doubleT
                          If I put this line:
                          table.Element.className = "homeassistant-table";
                          after
                          the module does not load
                          Another thing the text is still gray.
                            Oh, sorry, “tableElement” – remove the dot. Sorry.
                            • I Offline
                              iorifly
                              The module loaded but without the lines yet.
                              Before you get tired LOL … please tell me how to make the text of the module more alive!
                                Remove the “dimmed” in line 38 of the code.
                                • 3 / 3
