    Currentweather,doesn't appear.
    7 Posts 3 Posters 1.5k Views 1 Watching
      samson_82
      Hi there.
      i have a problem with the currenweather module.
      no matter what I try, it just doesn’t appear.
      everyone else, do what they should.
      hope that one of you can help me.
      	module: "currentweather",
      	position: "center_right",
      	classes: "default everyone",
      	locationID: "2956710",
      	appid: "XXXXXXXXXXXXXXXXXXXXXXX",
      	apiVersion: "2.5",
      	apiBase: "http://api.openweathermap.org/data/",
      	WeatherEndpoint: "weather"
      • brobergB Offline
        broberg Project Sponsor
        The only thing that I see wrong is that the position doesn’t exist.
        These are the positions that you can choose from :
        top_bar, top_left, top_center, top_right, upper_third, middle_center, lower_third, bottom_left, bottom_center, bottom_right, bottom_bar, fullscreen_above, and fullscreen_below
        A reference for the positions (regions) can be found here :
        https://forum.magicmirror.builders/topic/286/regions/2
          A Former User
          There is no center_right position.
          Read about regions here: https://forum.magicmirror.builders/topic/286/regions
            samson_82
            Changed it to bottom_right.
            doesn’t appear.
            there is no error message or anything else
            • brobergB Offline
              broberg Project Sponsor @samson_82
              @samson_82
              I tested this with my mirror (2.9.0)
              	position: "bottom_right",
              	appid: "my api code",
              And had no issues, Double check your API code and the Mirrors internet connection.
                samson_82
                The raspberry is connected to the internet by cable
                I have replaced the ID with XXXX.
                In the config I have it.
                Everything works, only the module does not want to
                  samson_82
                  so. I was able to fix the problem.
                  an error must have crept in during installation.
                  once ran over the upgrade bash.
                  bash -c “$ (curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
                  After a new installation of the basic modules, the weather module now works correctly.
