    Currentweather,doesn't appear.
    7 Posts 3 Posters 1.4k Views 1 Watching
    • brobergB Offline
      broberg Project Sponsor
      The only thing that I see wrong is that the position doesn’t exist.
      These are the positions that you can choose from :
      top_bar, top_left, top_center, top_right, upper_third, middle_center, lower_third, bottom_left, bottom_center, bottom_right, bottom_bar, fullscreen_above, and fullscreen_below
      A reference for the positions (regions) can be found here :
      https://forum.magicmirror.builders/topic/286/regions/2
        A Former User
        There is no center_right position.
        Read about regions here: https://forum.magicmirror.builders/topic/286/regions
          samson_82
          Changed it to bottom_right.
          doesn’t appear.
          there is no error message or anything else
          • brobergB Offline
            broberg Project Sponsor @samson_82
            @samson_82
            I tested this with my mirror (2.9.0)
            	module: "currentweather",
            	position: "bottom_right",
            	locationID: "2956710",
            	appid: "my api code",
            And had no issues, Double check your API code and the Mirrors internet connection.
              samson_82
              The raspberry is connected to the internet by cable
              I have replaced the ID with XXXX.
              In the config I have it.
              Everything works, only the module does not want to
                samson_82
                so. I was able to fix the problem.
                an error must have crept in during installation.
                once ran over the upgrade bash.
                bash -c “$ (curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” force
                After a new installation of the basic modules, the weather module now works correctly.
