    After update, chrome-sandbox needs root and mode 4655?
    27 Posts 4 Posters 14.3k Views 4 Watching
    • karsten13K Offline
      karsten13
      node@pi4:/opt/magic_mirror$ npm install
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
      > electron-chromedriver@6.0.0 install /opt/magic_mirror/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      > core-js@2.6.11 postinstall /opt/magic_mirror/node_modules/core-js
      > node -e "try{require('./postinstall')}catch(e){}"
      > console-stamp@0.2.9 postinstall /opt/magic_mirror/node_modules/console-stamp
      > node ./msg.js
      Attention
          Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
          For more details goto: https://www.npmjs.com/package/console-stamp/v/next
      > electron@6.0.12 postinstall /opt/magic_mirror/node_modules/electron
      > node install.js
      Downloading tmp-433-1-SHASUMS256.txt-6.0.12
      [============================================>] 100.0% of 5.2 kB (5.2 kB/s)
      > magicmirror@2.10.0 install /opt/magic_mirror
      > cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      audited 220 packages in 4.267s
      found 5 vulnerabilities (4 low, 1 high)
        run `npm audit fix` to fix them, or `npm audit` for details
      > magicmirror@2.10.0 postinstall /opt/magic_mirror
      > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
      MagicMirror installation successful!
      > magicmirror@2.10.0 install-fonts /opt/magic_mirror
      > cd fonts && npm install
      audited 1 package in 0.716s
      found 0 vulnerabilities
      npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      added 1056 packages from 1151 contributors and audited 2946 packages in 119.117s
      52 packages are looking for funding
        run `npm fund` for details
      node@pi4:/opt/magic_mirror$ npm start
      > magicmirror@2.10.0 start /opt/magic_mirror
      > ./run-start.sh
      [516:0131/000550.394975:FATAL:setuid_sandbox_host.cc(157)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I'm aborting now. You need to make sure that /opt/magic_mirror/node_modules/electron/dist/chrome-sandbox is owned by root and has mode 4755.
        karsten13
        node@pi4:/opt/magic_mirror$ cat package.json
          "name": "magicmirror",
          "version": "2.10.0",
          "description": "The open source modular smart mirror platform.",
          "main": "js/electron.js",
          "scripts": {
            "start": "./run-start.sh",
            "install": "cd vendor && npm install",
            "install-fonts": "cd fonts && npm install",
            "postinstall": "sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts",
            "test": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests --recursive",
            "test:unit": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests/unit --recursive",
            "test:e2e": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive",
            "config:check": "node tests/configs/check_config.js",
            "lint": "grunt"
          "repository": {
            "type": "git",
            "url": "git+https://github.com/MichMich/MagicMirror.git"
          "keywords": [
            "magic mirror",
            "smart mirror",
            "mirror UI",
            "modular"
          "author": "Michael Teeuw",
          "contributors": [
            "https://github.com/MichMich/MagicMirror/graphs/contributors"
          "license": "MIT",
          "bugs": {
            "url": "https://github.com/MichMich/MagicMirror/issues"
          "homepage": "https://magicmirror.builders",
          "devDependencies": {
            "chai": "^4.1.2",
            "chai-as-promised": "^7.1.1",
            "current-week-number": "^1.0.7",
            "danger": "^3.1.3",
            "grunt": "latest",
            "grunt-eslint": "latest",
            "grunt-jsonlint": "latest",
            "grunt-markdownlint": "latest",
            "grunt-stylelint": "latest",
            "grunt-yamllint": "latest",
            "http-auth": "^3.2.3",
            "jsdom": "^11.6.2",
            "jshint": "^2.10.2",
            "mocha": "^7.0.0",
            "mocha-each": "^1.1.0",
            "mocha-logger": "^1.0.6",
            "spectron": "^8.0.0",
            "stylelint": "latest",
            "stylelint-config-standard": "latest",
            "time-grunt": "latest"
          "optionalDependencies": {
            "electron": "6.0.12"
          "dependencies": {
            "colors": "^1.1.2",
            "console-stamp": "^0.2.9",
            "express": "^4.16.2",
            "express-ipfilter": "^1.0.1",
            "feedme": "latest",
            "helmet": "^3.21.2",
            "iconv-lite": "latest",
            "lodash": "^4.17.15",
            "module-alias": "^2.2.2",
            "moment": "latest",
            "request": "^2.88.0",
            "rrule": "^2.6.2",
            "rrule-alt": "^2.2.8",
            "simple-git": "^1.85.0",
            "socket.io": "^2.1.1",
            "valid-url": "latest"
          "_moduleAliases": {
            "node_helper": "js/node_helper.js"
          sdetweil @karsten13
          @karsten13 weird. I didn’t test w 2.10, but did 2.9 and changed to electron to 6.0.12
          Never had a problem. Pi 3 and 4, odroid, Jetson nano.
            Richard238 @karsten13
            @karsten13 said in After update, chrome-sandbox needs root and mode 4655?:
            So are you using the develop-branch or have you edited package.json und upgraded electron?
            Neither that I am aware of.
            All I did was apply a batch of commits.
              karsten13
              may you can give us more infos about your setup.
              Please navigate to your magic mirror dir (/home/pi/MagicMirror) and post the result of
              • cat package.json
              • git status
              • node -v
              • npm -v
                Richard238
                • Cat package.json
                pi@pi_mirror:~/MagicMirror $ cat package.json
                  "version": "2.11.0-develop",
                  "scripts": {
                    "lint": "grunt"
                  "repository": {
                    "type": "git",
                  "keywords": [
                    "magic mirror",
                    "smart mirror",
                    "mirror UI",
                    "modular"
                  "contributors": [
                  "license": "MIT",
                  "bugs": {
                    "chai": "^4.1.2",
                    "danger": "^3.1.3",
                    "grunt": "latest",
                    "jsdom": "^11.6.2",
                    "mocha": "^7.0.0",
                    "electron": "^6.1.7"
                  "dependencies": {
                    "colors": "^1.1.2",
                    "feedme": "latest",
                    "moment": "latest",
                    "rrule": "^2.6.2",
                  "_moduleAliases": {
                • GIT Status:
                pi@pi_mirror:~/MagicMirror $ git status
                On branch develop
                Your branch is behind 'origin/develop' by 17 commits, and can be fast-forwarded.
                  (use "git pull" to update your local branch)
                  (use "git add <file>..." to update what will be committed)
                  (use "git checkout -- <file>..." to discard changes in working directory)
                	modified:   css/main.css
                Untracked files:
                  (use "git add <file>..." to include in what will be committed)
                	InstallGuideURL.txt
                	MMM-EventHorizon/
                	READ_ME.txt
                	core
                	css/customOLD.css
                	modules/default/calendar/calendar1.js
                	modules/default/compliments/compliments.js.ORIG
                	modules/default/compliments/compliments.json
                	modules/default/compliments/compliments2.js
                no changes added to commit (use "git add" and/or "git commit -a")
                • Node Version:
                pi@pi_mirror:~/MagicMirror $ node -v
                v6.9.5
                • NPM Version:
                pi@pi_mirror:~/MagicMirror $ npm -v
                3.10.10
                  karsten13
                  thx, so you are on the develop branch with electron 6.x
                    sdetweil @karsten13
                    @karsten13 and old node and npm
                      karsten13
                      yes, saw that, but my tests were run with
                      node@pi4:/opt/magic_mirror$ node -v
                      v13.5.0
                      node@pi4:/opt/magic_mirror$ npm -v
                      6.13.4
                        sdetweil @karsten13
                        @karsten13 u are ok, he is downlevel…
                        installer is still only checking node 10 minimum… should I change it?
                          karsten13
                          thats your decision, this problem seems unrelated to the node/npm version, but so old stuff can cause other problems, so may you should warn at least …
                            sdetweil @karsten13
                            @karsten13 if installer is used, i upgrade to latest 10.x, and latest npm… don’t warn
                              karsten13 @sdetweil
                              o.k., so your question was about using a newer node version than 10? Maybe the latest lts version, I’m not sure, think this is 12.
                                sdetweil @karsten13
                                @karsten13 both 10 and 12 are lts, 12 just started, 10 entering maint in April, 12 enters maint in october
                                Release Status Codename Initial Release Active LTS Start Maintenance LTS Start End-of-life
                                v10 Active LTS Dubnium 2018-04-24 2018-10-30 2020-04-01 2021-04-30
                                v12 Active LTS Erbium 2019-04-23 2019-10-21 2020-10-21 2022-04-30
                                  Richard238
                                  Would it be advisable then, regardless of the chrome-sandbox issue, to update NODE and NPM on my MM?
                                  If so how, and to which version of each?
                                    karsten13
                                    I think they all work, you’re using 10, the official docker image uses 12 and I’m using 13 in my images …
                                      Saabman Project Sponsor
                                      I realize this is an old topic but the issue has raised its head a couple of times for me recently doing fresh installs on Debian 10 ( not on a Pi but on some intel boxes)
                                      The OP’s solution in the first post resolved it problem - Thankyou
                                        sdetweil @Saabman
                                        @saabman also my updater and installer fix this as well as a separate script to fix sandbox
                                        see https://github.com/sdetweil/MagicMirror_scripts
                                          Saabman Project Sponsor @sdetweil
                                          @sdetweil cheers thankyou for your fine work
