    After update, chrome-sandbox needs root and mode 4655?
    27 Posts 4 Posters 15.0k Views 4 Watching
    • karsten13K
      karsten13
      node@pi4:/opt/magic_mirror$ cat package.json
        "name": "magicmirror",
        "version": "2.10.0",
        "description": "The open source modular smart mirror platform.",
        "main": "js/electron.js",
        "scripts": {
          "start": "./run-start.sh",
          "install": "cd vendor && npm install",
          "install-fonts": "cd fonts && npm install",
          "postinstall": "sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts",
          "test": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests --recursive",
          "test:unit": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests/unit --recursive",
          "test:e2e": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive",
          "config:check": "node tests/configs/check_config.js",
          "lint": "grunt"
        "repository": {
          "type": "git",
          "url": "git+https://github.com/MichMich/MagicMirror.git"
        "keywords": [
          "magic mirror",
          "smart mirror",
          "mirror UI",
          "modular"
        "author": "Michael Teeuw",
        "contributors": [
          "https://github.com/MichMich/MagicMirror/graphs/contributors"
        "license": "MIT",
        "bugs": {
          "url": "https://github.com/MichMich/MagicMirror/issues"
        "homepage": "https://magicmirror.builders",
        "devDependencies": {
          "chai": "^4.1.2",
          "chai-as-promised": "^7.1.1",
          "current-week-number": "^1.0.7",
          "danger": "^3.1.3",
          "grunt": "latest",
          "grunt-eslint": "latest",
          "grunt-jsonlint": "latest",
          "grunt-markdownlint": "latest",
          "grunt-stylelint": "latest",
          "grunt-yamllint": "latest",
          "http-auth": "^3.2.3",
          "jsdom": "^11.6.2",
          "jshint": "^2.10.2",
          "mocha": "^7.0.0",
          "mocha-each": "^1.1.0",
          "mocha-logger": "^1.0.6",
          "spectron": "^8.0.0",
          "stylelint": "latest",
          "stylelint-config-standard": "latest",
          "time-grunt": "latest"
        "optionalDependencies": {
          "electron": "6.0.12"
        "dependencies": {
          "colors": "^1.1.2",
          "console-stamp": "^0.2.9",
          "express": "^4.16.2",
          "express-ipfilter": "^1.0.1",
          "feedme": "latest",
          "helmet": "^3.21.2",
          "iconv-lite": "latest",
          "lodash": "^4.17.15",
          "module-alias": "^2.2.2",
          "moment": "latest",
          "request": "^2.88.0",
          "rrule": "^2.6.2",
          "rrule-alt": "^2.2.8",
          "simple-git": "^1.85.0",
          "socket.io": "^2.1.1",
          "valid-url": "latest"
        "_moduleAliases": {
          "node_helper": "js/node_helper.js"
        sdetweil @karsten13
        @karsten13 weird. I didn’t test w 2.10, but did 2.9 and changed to electron to 6.0.12
        Never had a problem. Pi 3 and 4, odroid, Jetson nano.
          Richard238 @karsten13
          @karsten13 said in After update, chrome-sandbox needs root and mode 4655?:
          So are you using the develop-branch or have you edited package.json und upgraded electron?
          Neither that I am aware of.
          All I did was apply a batch of commits.
          • karsten13K
            karsten13
            may you can give us more infos about your setup.
            Please navigate to your magic mirror dir (/home/pi/MagicMirror) and post the result of
            • cat package.json
            • git status
            • node -v
            • npm -v
              Richard238
              • Cat package.json
              pi@pi_mirror:~/MagicMirror $ cat package.json
                "version": "2.11.0-develop",
                "scripts": {
                  "lint": "grunt"
                "repository": {
                  "type": "git",
                "keywords": [
                  "magic mirror",
                  "smart mirror",
                  "mirror UI",
                  "modular"
                "contributors": [
                "license": "MIT",
                "bugs": {
                  "chai": "^4.1.2",
                  "danger": "^3.1.3",
                  "grunt": "latest",
                  "jsdom": "^11.6.2",
                  "mocha": "^7.0.0",
                  "electron": "^6.1.7"
                "dependencies": {
                  "colors": "^1.1.2",
                  "feedme": "latest",
                  "moment": "latest",
                  "rrule": "^2.6.2",
                "_moduleAliases": {
              • GIT Status:
              pi@pi_mirror:~/MagicMirror $ git status
              On branch develop
              Your branch is behind 'origin/develop' by 17 commits, and can be fast-forwarded.
                (use "git pull" to update your local branch)
                (use "git add <file>..." to update what will be committed)
                (use "git checkout -- <file>..." to discard changes in working directory)
              	modified:   css/main.css
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
              	InstallGuideURL.txt
              	MMM-EventHorizon/
              	READ_ME.txt
              	core
              	css/customOLD.css
              	modules/default/calendar/calendar1.js
              	modules/default/compliments/compliments.js.ORIG
              	modules/default/compliments/compliments.json
              	modules/default/compliments/compliments2.js
              no changes added to commit (use "git add" and/or "git commit -a")
              • Node Version:
              pi@pi_mirror:~/MagicMirror $ node -v
              v6.9.5
              • NPM Version:
              pi@pi_mirror:~/MagicMirror $ npm -v
              3.10.10
              • karsten13K
                karsten13
                thx, so you are on the develop branch with electron 6.x
                  sdetweil @karsten13
                  @karsten13 and old node and npm
                  • karsten13K
                    karsten13
                    yes, saw that, but my tests were run with
                    node@pi4:/opt/magic_mirror$ node -v
                    v13.5.0
                    node@pi4:/opt/magic_mirror$ npm -v
                    6.13.4
                      sdetweil @karsten13
                      @karsten13 u are ok, he is downlevel…
                      installer is still only checking node 10 minimum… should I change it?
                      • karsten13K
                        karsten13
                        thats your decision, this problem seems unrelated to the node/npm version, but so old stuff can cause other problems, so may you should warn at least …
                          sdetweil @karsten13
                          @karsten13 if installer is used, i upgrade to latest 10.x, and latest npm… don’t warn
                          karsten13K 1 Reply Last reply
                          • karsten13K
                            karsten13 @sdetweil
                            o.k., so your question was about using a newer node version than 10? Maybe the latest lts version, I’m not sure, think this is 12.
                              sdetweil @karsten13
                              @karsten13 both 10 and 12 are lts, 12 just started, 10 entering maint in April, 12 enters maint in october
                              Release Status Codename Initial Release Active LTS Start Maintenance LTS Start End-of-life
                              v10 Active LTS Dubnium 2018-04-24 2018-10-30 2020-04-01 2021-04-30
                              v12 Active LTS Erbium 2019-04-23 2019-10-21 2020-10-21 2022-04-30
                                Richard238
                                Would it be advisable then, regardless of the chrome-sandbox issue, to update NODE and NPM on my MM?
                                If so how, and to which version of each?
                                • karsten13K
                                  karsten13
                                  I think they all work, you’re using 10, the official docker image uses 12 and I’m using 13 in my images …
                                    Saabman Project Sponsor
                                    I realize this is an old topic but the issue has raised its head a couple of times for me recently doing fresh installs on Debian 10 ( not on a Pi but on some intel boxes)
                                    The OP’s solution in the first post resolved it problem - Thankyou
                                      sdetweil @Saabman
                                      @saabman also my updater and installer fix this as well as a separate script to fix sandbox
                                      see https://github.com/sdetweil/MagicMirror_scripts
                                        Saabman Project Sponsor @sdetweil
                                        @sdetweil cheers thankyou for your fine work
