    After update, chrome-sandbox needs root and mode 4655?
    27 Posts 4 Posters 11.6k Views 4 Watching
    • karsten13K Offline
      karsten13
      tested only 3.x, 6.x, 7.x
      In 3.x sandbox was disabled, in >=6.x enabled
        sdetweil @karsten13
        @karsten13 thx. I tested 6.0.12, and didn’t have problems w sandbox…
          karsten13
          you tested on a raspberry pi? And with a non-root user?
            sdetweil @karsten13
            @karsten13 correct
              karsten13
              node@pi4:/opt/magic_mirror$ npm install
              npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
              npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
              > electron-chromedriver@6.0.0 install /opt/magic_mirror/node_modules/electron-chromedriver
              > node ./download-chromedriver.js
              > core-js@2.6.11 postinstall /opt/magic_mirror/node_modules/core-js
              > node -e "try{require('./postinstall')}catch(e){}"
              > console-stamp@0.2.9 postinstall /opt/magic_mirror/node_modules/console-stamp
              > node ./msg.js
              Attention
                  Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
                  For more details goto: https://www.npmjs.com/package/console-stamp/v/next
              > electron@6.0.12 postinstall /opt/magic_mirror/node_modules/electron
              > node install.js
              Downloading tmp-433-1-SHASUMS256.txt-6.0.12
              [============================================>] 100.0% of 5.2 kB (5.2 kB/s)
              > magicmirror@2.10.0 install /opt/magic_mirror
              > cd vendor && npm install
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              audited 220 packages in 4.267s
              found 5 vulnerabilities (4 low, 1 high)
                run `npm audit fix` to fix them, or `npm audit` for details
              > magicmirror@2.10.0 postinstall /opt/magic_mirror
              > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
              MagicMirror installation successful!
              > magicmirror@2.10.0 install-fonts /opt/magic_mirror
              > cd fonts && npm install
              audited 1 package in 0.716s
              found 0 vulnerabilities
              npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              added 1056 packages from 1151 contributors and audited 2946 packages in 119.117s
              52 packages are looking for funding
                run `npm fund` for details
              node@pi4:/opt/magic_mirror$ npm start
              > magicmirror@2.10.0 start /opt/magic_mirror
              > ./run-start.sh
              [516:0131/000550.394975:FATAL:setuid_sandbox_host.cc(157)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I'm aborting now. You need to make sure that /opt/magic_mirror/node_modules/electron/dist/chrome-sandbox is owned by root and has mode 4755.
                karsten13
                node@pi4:/opt/magic_mirror$ cat package.json
                  "name": "magicmirror",
                  "version": "2.10.0",
                  "description": "The open source modular smart mirror platform.",
                  "main": "js/electron.js",
                  "scripts": {
                    "start": "./run-start.sh",
                    "install": "cd vendor && npm install",
                    "install-fonts": "cd fonts && npm install",
                    "postinstall": "sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts",
                    "test": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests --recursive",
                    "test:unit": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests/unit --recursive",
                    "test:e2e": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive",
                    "config:check": "node tests/configs/check_config.js",
                    "lint": "grunt"
                  "repository": {
                    "type": "git",
                    "url": "git+https://github.com/MichMich/MagicMirror.git"
                  "keywords": [
                    "magic mirror",
                    "smart mirror",
                    "mirror UI",
                    "modular"
                  "author": "Michael Teeuw",
                  "contributors": [
                    "https://github.com/MichMich/MagicMirror/graphs/contributors"
                  "license": "MIT",
                  "bugs": {
                    "url": "https://github.com/MichMich/MagicMirror/issues"
                  "homepage": "https://magicmirror.builders",
                  "devDependencies": {
                    "chai": "^4.1.2",
                    "chai-as-promised": "^7.1.1",
                    "current-week-number": "^1.0.7",
                    "danger": "^3.1.3",
                    "grunt": "latest",
                    "grunt-eslint": "latest",
                    "grunt-jsonlint": "latest",
                    "grunt-markdownlint": "latest",
                    "grunt-stylelint": "latest",
                    "grunt-yamllint": "latest",
                    "http-auth": "^3.2.3",
                    "jsdom": "^11.6.2",
                    "jshint": "^2.10.2",
                    "mocha": "^7.0.0",
                    "mocha-each": "^1.1.0",
                    "mocha-logger": "^1.0.6",
                    "spectron": "^8.0.0",
                    "stylelint": "latest",
                    "stylelint-config-standard": "latest",
                    "time-grunt": "latest"
                  "optionalDependencies": {
                    "electron": "6.0.12"
                  "dependencies": {
                    "colors": "^1.1.2",
                    "console-stamp": "^0.2.9",
                    "express": "^4.16.2",
                    "express-ipfilter": "^1.0.1",
                    "feedme": "latest",
                    "helmet": "^3.21.2",
                    "iconv-lite": "latest",
                    "lodash": "^4.17.15",
                    "module-alias": "^2.2.2",
                    "moment": "latest",
                    "request": "^2.88.0",
                    "rrule": "^2.6.2",
                    "rrule-alt": "^2.2.8",
                    "simple-git": "^1.85.0",
                    "socket.io": "^2.1.1",
                    "valid-url": "latest"
                  "_moduleAliases": {
                    "node_helper": "js/node_helper.js"
                  sdetweil @karsten13
                  @karsten13 weird. I didn’t test w 2.10, but did 2.9 and changed to electron to 6.0.12
                  Never had a problem. Pi 3 and 4, odroid, Jetson nano.
                    Richard238 @karsten13
                    @karsten13 said in After update, chrome-sandbox needs root and mode 4655?:
                    So are you using the develop-branch or have you edited package.json und upgraded electron?
                    Neither that I am aware of.
                    All I did was apply a batch of commits.
                      karsten13
                      may you can give us more infos about your setup.
                      Please navigate to your magic mirror dir (/home/pi/MagicMirror) and post the result of
                      • cat package.json
                      • git status
                      • node -v
                      • npm -v
                        Richard238
                        • Cat package.json
                        pi@pi_mirror:~/MagicMirror $ cat package.json
                          "version": "2.11.0-develop",
                          "scripts": {
                            "lint": "grunt"
                          "repository": {
                            "type": "git",
                          "keywords": [
                            "magic mirror",
                            "smart mirror",
                            "mirror UI",
                            "modular"
                          "contributors": [
                          "license": "MIT",
                          "bugs": {
                            "chai": "^4.1.2",
                            "danger": "^3.1.3",
                            "grunt": "latest",
                            "jsdom": "^11.6.2",
                            "mocha": "^7.0.0",
                            "electron": "^6.1.7"
                          "dependencies": {
                            "colors": "^1.1.2",
                            "feedme": "latest",
                            "moment": "latest",
                            "rrule": "^2.6.2",
                          "_moduleAliases": {
                        • GIT Status:
                        pi@pi_mirror:~/MagicMirror $ git status
                        On branch develop
                        Your branch is behind 'origin/develop' by 17 commits, and can be fast-forwarded.
                          (use "git pull" to update your local branch)
                          (use "git add <file>..." to update what will be committed)
                          (use "git checkout -- <file>..." to discard changes in working directory)
                        	modified:   css/main.css
                        Untracked files:
                          (use "git add <file>..." to include in what will be committed)
                        	InstallGuideURL.txt
                        	MMM-EventHorizon/
                        	READ_ME.txt
                        	core
                        	css/customOLD.css
                        	modules/default/calendar/calendar1.js
                        	modules/default/compliments/compliments.js.ORIG
                        	modules/default/compliments/compliments.json
                        	modules/default/compliments/compliments2.js
                        no changes added to commit (use "git add" and/or "git commit -a")
                        • Node Version:
                        pi@pi_mirror:~/MagicMirror $ node -v
                        v6.9.5
                        • NPM Version:
                        pi@pi_mirror:~/MagicMirror $ npm -v
                        3.10.10
