    After update, chrome-sandbox needs root and mode 4655?
    27 Posts 4 Posters 14.6k Views 4 Watching
    • karsten13K
      karsten13
      The “newer” electron versions are using sandboxing by default. But on master-branch is still the old electron 3.x active.
      So are you using the develop-branch or have you edited package.json und upgraded electron?
      The method to fix this is correct, an alternative way is disable sandboxing, which is not a good idea under security aspects. You can disable sandboxing e.g. by setting the environment variable ELECTRON_DISABLE_SANDBOX=1
      S R 2 Replies Last reply Reply Quote 0
        sdetweil @karsten13
        @karsten13 do you know what version this came in on? I will add the bypass into the automated install and upgrade
        • karsten13K
          karsten13
          tested only 3.x, 6.x, 7.x
          In 3.x sandbox was disabled, in >=6.x enabled
            sdetweil @karsten13
            @karsten13 thx. I tested 6.0.12, and didn’t have problems w sandbox…
            • karsten13K
              karsten13
              you tested on a raspberry pi? And with a non-root user?
                sdetweil @karsten13
                @karsten13 correct
                • karsten13K
                  karsten13
                  node@pi4:/opt/magic_mirror$ npm install
                  npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                  npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
                  > electron-chromedriver@6.0.0 install /opt/magic_mirror/node_modules/electron-chromedriver
                  > node ./download-chromedriver.js
                  > core-js@2.6.11 postinstall /opt/magic_mirror/node_modules/core-js
                  > node -e "try{require('./postinstall')}catch(e){}"
                  > console-stamp@0.2.9 postinstall /opt/magic_mirror/node_modules/console-stamp
                  > node ./msg.js
                  Attention
                      Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
                      For more details goto: https://www.npmjs.com/package/console-stamp/v/next
                  > electron@6.0.12 postinstall /opt/magic_mirror/node_modules/electron
                  > node install.js
                  Downloading tmp-433-1-SHASUMS256.txt-6.0.12
                  [============================================>] 100.0% of 5.2 kB (5.2 kB/s)
                  > magicmirror@2.10.0 install /opt/magic_mirror
                  > cd vendor && npm install
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  audited 220 packages in 4.267s
                  found 5 vulnerabilities (4 low, 1 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                  > magicmirror@2.10.0 postinstall /opt/magic_mirror
                  > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
                  MagicMirror installation successful!
                  > magicmirror@2.10.0 install-fonts /opt/magic_mirror
                  > cd fonts && npm install
                  audited 1 package in 0.716s
                  found 0 vulnerabilities
                  npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  added 1056 packages from 1151 contributors and audited 2946 packages in 119.117s
                  52 packages are looking for funding
                    run `npm fund` for details
                  node@pi4:/opt/magic_mirror$ npm start
                  > magicmirror@2.10.0 start /opt/magic_mirror
                  > ./run-start.sh
                  [516:0131/000550.394975:FATAL:setuid_sandbox_host.cc(157)] The SUID sandbox helper binary was found, but is not configured correctly. Rather than run without sandboxing I'm aborting now. You need to make sure that /opt/magic_mirror/node_modules/electron/dist/chrome-sandbox is owned by root and has mode 4755.
                  • karsten13K
                    karsten13
                    node@pi4:/opt/magic_mirror$ cat package.json
                      "name": "magicmirror",
                      "version": "2.10.0",
                      "description": "The open source modular smart mirror platform.",
                      "main": "js/electron.js",
                      "scripts": {
                        "start": "./run-start.sh",
                        "install": "cd vendor && npm install",
                        "install-fonts": "cd fonts && npm install",
                        "postinstall": "sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts",
                        "test": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests --recursive",
                        "test:unit": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests/unit --recursive",
                        "test:e2e": "NODE_ENV=test ./node_modules/mocha/bin/mocha tests/e2e --recursive",
                        "config:check": "node tests/configs/check_config.js",
                        "lint": "grunt"
                      "repository": {
                        "type": "git",
                        "url": "git+https://github.com/MichMich/MagicMirror.git"
                      "keywords": [
                        "magic mirror",
                        "smart mirror",
                        "mirror UI",
                        "modular"
                      "author": "Michael Teeuw",
                      "contributors": [
                        "https://github.com/MichMich/MagicMirror/graphs/contributors"
                      "license": "MIT",
                      "bugs": {
                        "url": "https://github.com/MichMich/MagicMirror/issues"
                      "homepage": "https://magicmirror.builders",
                      "devDependencies": {
                        "chai": "^4.1.2",
                        "chai-as-promised": "^7.1.1",
                        "current-week-number": "^1.0.7",
                        "danger": "^3.1.3",
                        "grunt": "latest",
                        "grunt-eslint": "latest",
                        "grunt-jsonlint": "latest",
                        "grunt-markdownlint": "latest",
                        "grunt-stylelint": "latest",
                        "grunt-yamllint": "latest",
                        "http-auth": "^3.2.3",
                        "jsdom": "^11.6.2",
                        "jshint": "^2.10.2",
                        "mocha": "^7.0.0",
                        "mocha-each": "^1.1.0",
                        "mocha-logger": "^1.0.6",
                        "spectron": "^8.0.0",
                        "stylelint": "latest",
                        "stylelint-config-standard": "latest",
                        "time-grunt": "latest"
                      "optionalDependencies": {
                        "electron": "6.0.12"
                      "dependencies": {
                        "colors": "^1.1.2",
                        "console-stamp": "^0.2.9",
                        "express": "^4.16.2",
                        "express-ipfilter": "^1.0.1",
                        "feedme": "latest",
                        "helmet": "^3.21.2",
                        "iconv-lite": "latest",
                        "lodash": "^4.17.15",
                        "module-alias": "^2.2.2",
                        "moment": "latest",
                        "request": "^2.88.0",
                        "rrule": "^2.6.2",
                        "rrule-alt": "^2.2.8",
                        "simple-git": "^1.85.0",
                        "socket.io": "^2.1.1",
                        "valid-url": "latest"
                      "_moduleAliases": {
                        "node_helper": "js/node_helper.js"
                      sdetweil @karsten13
                      @karsten13 weird. I didn’t test w 2.10, but did 2.9 and changed to electron to 6.0.12
                      Never had a problem. Pi 3 and 4, odroid, Jetson nano.
                        Richard238 @karsten13
                        @karsten13 said in After update, chrome-sandbox needs root and mode 4655?:
                        Neither that I am aware of.
                        All I did was apply a batch of commits.
                        • karsten13K
                          karsten13
                          may you can give us more infos about your setup.
                          Please navigate to your magic mirror dir (/home/pi/MagicMirror) and post the result of
                          • cat package.json
                          • git status
                          • node -v
                          • npm -v
                            Richard238
                            • Cat package.json
                            pi@pi_mirror:~/MagicMirror $ cat package.json
                              "version": "2.11.0-develop",
                              "scripts": {
                                "lint": "grunt"
                              "repository": {
                                "type": "git",
                              "keywords": [
                                "magic mirror",
                                "smart mirror",
                                "mirror UI",
                                "modular"
                              "contributors": [
                              "license": "MIT",
                              "bugs": {
                                "chai": "^4.1.2",
                                "danger": "^3.1.3",
                                "grunt": "latest",
                                "jsdom": "^11.6.2",
                                "mocha": "^7.0.0",
                                "electron": "^6.1.7"
                              "dependencies": {
                                "colors": "^1.1.2",
                                "feedme": "latest",
                                "moment": "latest",
                                "rrule": "^2.6.2",
                              "_moduleAliases": {
                            • GIT Status:
                            pi@pi_mirror:~/MagicMirror $ git status
                            On branch develop
                            Your branch is behind 'origin/develop' by 17 commits, and can be fast-forwarded.
                              (use "git pull" to update your local branch)
                              (use "git add <file>..." to update what will be committed)
                              (use "git checkout -- <file>..." to discard changes in working directory)
                            	modified:   css/main.css
                            Untracked files:
                              (use "git add <file>..." to include in what will be committed)
                            	InstallGuideURL.txt
                            	MMM-EventHorizon/
                            	READ_ME.txt
                            	core
                            	css/customOLD.css
                            	modules/default/calendar/calendar1.js
                            	modules/default/compliments/compliments.js.ORIG
                            	modules/default/compliments/compliments.json
                            	modules/default/compliments/compliments2.js
                            no changes added to commit (use "git add" and/or "git commit -a")
                            • Node Version:
                            pi@pi_mirror:~/MagicMirror $ node -v
                            v6.9.5
                            • NPM Version:
                            pi@pi_mirror:~/MagicMirror $ npm -v
                            3.10.10
                            • karsten13K
                              karsten13
                              thx, so you are on the develop branch with electron 6.x
                                sdetweil @karsten13
                                @karsten13 and old node and npm
                                • karsten13K
                                  karsten13
                                  yes, saw that, but my tests were run with
                                  node@pi4:/opt/magic_mirror$ node -v
                                  v13.5.0
                                  node@pi4:/opt/magic_mirror$ npm -v
                                  6.13.4
                                    sdetweil @karsten13
                                    @karsten13 u are ok, he is downlevel…
                                    installer is still only checking node 10 minimum… should I change it?
                                    • karsten13K
                                      karsten13
                                      thats your decision, this problem seems unrelated to the node/npm version, but so old stuff can cause other problems, so may you should warn at least …
                                        sdetweil @karsten13
                                        @karsten13 if installer is used, i upgrade to latest 10.x, and latest npm… don’t warn
                                        • karsten13K
                                          karsten13 @sdetweil
                                          o.k., so your question was about using a newer node version than 10? Maybe the latest lts version, I’m not sure, think this is 12.
                                            sdetweil @karsten13
                                            @karsten13 both 10 and 12 are lts, 12 just started, 10 entering maint in April, 12 enters maint in october
                                            Release Status Codename Initial Release Active LTS Start Maintenance LTS Start End-of-life
                                            v10 Active LTS Dubnium 2018-04-24 2018-10-30 2020-04-01 2021-04-30
                                            v12 Active LTS Erbium 2019-04-23 2019-10-21 2020-10-21 2022-04-30
