    602 Posts 67 Posters 2.2m Views 68 Watching
    • N Offline
      Number_5
      Hello ,
      first I deactivated the config module.
      pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
      -bash: !?1971@192.168.2.108:80/cam/realmonitor?: event not found
      pi@raspberrypi:~/MagicMirror/config $ pm2 start MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
      [PM2] MagicMirror ✓
      [PM2] Process successfully started
      │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
      │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 30912 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
      │ 1 │ omx_stream1 │ default │ N/A │ fork │ 30880 │ 4s │ 741 │ online │ 0% │ 2.6mb │ pi │ disabled │
      It does not work, :-(
      • evroomE Offline
        evroom @Number_5
        @Number_5
        Can you try with quotes (single, double) ?
        omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0"
        omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
        when the command works, but still no video, then add --genlog
        omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
        This will creat a log file called omxplayer.log under the directory where you started omxplayer.
        MagicMirror version: 2.37.0
        • N Offline
          Number_5
          1. First 1 start magic mirror.
          2. with 2 qoutes
          3. with 1 qoute
          [PM2] MagicMirror ✓
          │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
          │ 1 │ omx_stream1 │ default │ N/A │ fork │ 8825 │ 2s │ 1000 │ online │ 0% │ 2.5mb │ pi │ disabled │
          [1]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2
          pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0”
          omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0”
          [2] 9584
          [3] 9585
          pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
          have a nice day ;)
          [2]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2
          [3] Fertig subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2
          S evroomE 2 Replies Last reply Reply Quote 0
            sdetweil @Number_5
            @Number_5 pm2 stop 0, pm2 stop 1
            just from the commandline…(ctrl-alt-t) . does a video window open on any of these?
            • evroomE Offline
              evroom @Number_5
              @Number_5
              Better to stop MM temporarily or disable the module with disabled: true, and a restart of MM.
              Also make sure omx_stream1 process is not running.
              pm2 status
              pm2 stop omx_stream1
              pm2 delete omx_stream1
              pm2 status
              Then do the single quoted command, with logging enabled.
              • N Offline
                Number_5
                Hello ,
                1. I started it from the command line
                but no windows opens. or I’m doing something wrong.
                pi@raspberrypi:~/MagicMirror/config $ --genlog
                -bash: --genlog: Kommando nicht gefunden.
                pi@raspberrypi:~/MagicMirror/config $ pm2 status
                │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 13m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                │ 1 │ omx_stream1 │ default │ N/A │ fork │ 14967 │ 0s │ 1152 │ online │ 0% │ 2.6mb │ pi │ disabled │
                pi@raspberrypi:~/MagicMirror/config $ pm2 stop omx_stream1
                [PM2] Applying action stopProcessId on app [omx_stream1](ids: 1)
                [PM2] omx_stream1 ✓
                │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 14m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1156 │ stopped │ 0% │ 0b │ pi │ disabled │
                pi@raspberrypi:~/MagicMirror/config $ pm2 delete omx_stream1
                [PM2] Applying action deleteProcessId on app [omx_stream1](ids: 1)
                [PM2] omx_stream1 ✓
                [PM2][WARN] Current process list running is not in sync with saved list. omx_stream1 differs. Type ‘pm2 save’ to synchronize.
                pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
                have a nice day ;)
                • evroomE Offline
                  evroom @Number_5
                  @Number_5
                  Could you please post commands and output using the </> tag ?
                  So, select the command or output and click on the </> symbol.
                  Does the log say anything useful ?
                  more omxplayer.log
                  Pleas do not post the complete log, unless small.
                  30 lines tops.
                  head -30 omxplayer.log
                  • N Offline
                    Number_5
                    ok sorry,
                    in future output and commands in </>
                    thats the logfile
                    pi@raspberrypi:~/MagicMirror/config $ more omxplayer.log
                    20:14:18 T:1939277143   DEBUG: DllBcm: Using omx system library
                    20:14:18 T:1939278613   DEBUG: DllOMX: Using omx system library
                    20:14:18 T:1939279243   DEBUG: DllAvFormat: Using libavformat system library
                    20:14:18 T:1939280418 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                    20:14:18 T:1939280521 WARNING: DBus connection failed, trying alternate
                    20:14:18 T:1939281594   DEBUG: DBus connection succeeded
                    20:14:18 T:1939282354   DEBUG: Keyboard: DBus connection succeeded
                    20:14:18 T:1939282502   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                    20:14:18 T:1939282604   DEBUG: DllAvUtilBase: Using libavutil system library
                    20:14:18 T:1939282636   DEBUG: DllAvCodec: Using libavcodec system library
                    20:14:18 T:1939282654   DEBUG: DllAvFormat: Using libavformat system library
                    20:14:18 T:1939282994   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                    20:14:18 T:1939283372   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                    20:14:18 T:1939283465   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                    20:14:18 T:1939283726   DEBUG: OMXThread::StopThread - Thread stopped
                    evroomE 3 Replies Last reply Reply Quote 0
                    • evroomE Offline
                      evroom @Number_5
                      @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                      ok sorry,
                      Nothing to be sorry for; you are learning as you go :-)
                      • evroomE Offline
                        evroom @Number_5
                        Okay, without getting rid of this error, omxplayer and therefore MMM-RTSPStream using omxplayer will not work for you.
                        I have an Axis cam and there it did not work because to the resolution I used, had to use one of the resolutions that is supported by the cam.
                        Where you able to open
                        http://your-mirror-ip:8080/MMM-RTSPStream/config.html
                        and see the cam there ?
                        Could try ffmpeg, but there I have to pass.
                        What camera are we talking about ?
                        • evroomE Offline
                          evroom @Number_5
                          @Number_5
                          Can you try with another port number (554 iso 80) ?
                          omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                          • N Offline
                            Number_5
                            Hello
                            it is a,
                            DAHUA mini-dome Kamera hd-cvi 2 megapixels für indoor/outdoor g ip7. 30 m nightview fixe objektiv 2,8 mm. - AC/DC-Adapter : AC/DC-Adapter 12V 600mA (port 80)
                            also i have a Luna Hd
                            L-KA-2601 1 160,00 160,00
                            IR Bullet-Kamera (HD-CVI), Full HD,
                            if i open
                            http://XXX.xxx,x.xxx:8080/MMM-RTSPStream/config.html
                            I am denied access
                              sdetweil @Number_5
                              I am denied access
                              probably have to use the url syntax for userid and password
                              http://admin:roland!?1971@example.com
                              that is going to the magic mirror port
                              so, in the config.js do you have
                              address: “0.0.0.0”,
                              and
                              ipWHiltelist:[],
                              • evroomE Offline
                                evroom @Number_5
                                @Number_5
                                Try with port 554, see previous post.
                                And see
                                https://github.com/shbatm/MMM-RTSPStream
                                “Using the module” on the config.html part I was referring to.
                                The IP there, is the MM IP, or localhost, not your cam IP.
                                • evroomE Offline
                                  evroom @evroom
                                  See
                                  https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/379
                                  • N Offline
                                    Number_5
                                    Hello
                                    I’m just overwhelmed with the syntax.
                                    and
                                    I’ll try tomorrow and give feedback, thanks for your support
                                    • N Offline
                                      Number_5 @evroom
                                      @evroom
                                      thats the result with the port 554
                                      pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                                      have a nice day ;)
                                      pi@raspberrypi:~/MagicMirror/config $ head -30 omxplayer.log
                                      21:33:25 T:18446744071806154291   DEBUG: DllBcm: Using omx system library
                                      21:33:25 T:18446744071806155602   DEBUG: DllOMX: Using omx system library
                                      21:33:25 T:18446744071806156277   DEBUG: DllAvFormat: Using libavformat system library
                                      21:33:25 T:18446744071806157458 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                                      21:33:25 T:18446744071806157567 WARNING: DBus connection failed, trying alternate
                                      21:33:25 T:18446744071806158687   DEBUG: DBus connection succeeded
                                      21:33:25 T:18446744071806159455   DEBUG: Keyboard: DBus connection succeeded
                                      21:33:25 T:18446744071806159602   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                      21:33:25 T:18446744071806159705   DEBUG: DllAvUtilBase: Using libavutil system library
                                      21:33:25 T:18446744071806159738   DEBUG: DllAvCodec: Using libavcodec system library
                                      21:33:25 T:18446744071806159756   DEBUG: DllAvFormat: Using libavformat system library
                                      21:33:25 T:18446744071806160118   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                                      21:33:25 T:18446744071806160518   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                                      21:33:25 T:18446744071806179771   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                      21:33:25 T:18446744071806180025   DEBUG: OMXThread::StopThread - Thread stopped
                                      • N Offline
                                        Number_5
                                        Hello Sam,
                                        with 0.0.0.0.8080/MMM-rtspStream I was able to open the module configurator.
                                        evroom said:
                                        And see
                                        It means the mirror id is not the raspberry pi?
                                        where can I find the mm id?
                                        evroomE S 3 Replies Last reply Reply Quote 0
                                        • evroomE Offline
                                          evroom @Number_5
                                          @Number_5
                                          When you run MM locally on your Pi, then your MM IP is your Pi IP.
                                          IP being the IP address, not an id.
                                          When you are able to open the RTSPStream configurator using 0.0.0.0.8080/MMM-rtspStream, then that’s fine.
                                          Continue with step 2 from this post:
                                            sdetweil @Number_5
                                            I don’t see that (mirror id) in the doc for this module
                                            i do see this for testing the camera connection
                                            Testing a camera feed
                                            To test to make sure you have a working url for a camera feed: create a text file with the URL as the first and only line in the file. Save the file as .strm and open the file with a video player like VLC.
                                            unfortuantely I can’t use this module on my dev system as there is no omxplayer…
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 30
                                            • 31
                                            • 21 / 31
