    602 Posts 67 Posters 2.3m Views 68 Watching
    • evroomE
      evroom @Number_5
      @Number_5
      Better to stop MM temporarily or disable the module with disabled: true, and a restart of MM.
      Also make sure omx_stream1 process is not running.
      pm2 status
      pm2 stop omx_stream1
      pm2 delete omx_stream1
      pm2 status
      Then do the single quoted command, with logging enabled.
      omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
      MagicMirror version: 2.37.0
      • N
        Number_5
        Hello ,
        1. I started it from the command line
        but no windows opens. or I’m doing something wrong.
        pi@raspberrypi:~/MagicMirror/config $ --genlog
        -bash: --genlog: Kommando nicht gefunden.
        pi@raspberrypi:~/MagicMirror/config $ pm2 status
        │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
        │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 13m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
        │ 1 │ omx_stream1 │ default │ N/A │ fork │ 14967 │ 0s │ 1152 │ online │ 0% │ 2.6mb │ pi │ disabled │
        pi@raspberrypi:~/MagicMirror/config $ pm2 stop omx_stream1
        [PM2] Applying action stopProcessId on app [omx_stream1](ids: 1)
        [PM2] omx_stream1 ✓
        │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 14m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
        │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1156 │ stopped │ 0% │ 0b │ pi │ disabled │
        pi@raspberrypi:~/MagicMirror/config $ pm2 delete omx_stream1
        [PM2] Applying action deleteProcessId on app [omx_stream1](ids: 1)
        [PM2] omx_stream1 ✓
        [PM2][WARN] Current process list running is not in sync with saved list. omx_stream1 differs. Type ‘pm2 save’ to synchronize.
        pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
        have a nice day ;)
        • evroomE
          evroom @Number_5
          @Number_5
          Could you please post commands and output using the </> tag ?
          So, select the command or output and click on the </> symbol.
          Does the log say anything useful ?
          more omxplayer.log
          Pleas do not post the complete log, unless small.
          30 lines tops.
          head -30 omxplayer.log
          • N
            Number_5
            ok sorry,
            in future output and commands in </>
            thats the logfile
            pi@raspberrypi:~/MagicMirror/config $ more omxplayer.log
            20:14:18 T:1939277143   DEBUG: DllBcm: Using omx system library
            20:14:18 T:1939278613   DEBUG: DllOMX: Using omx system library
            20:14:18 T:1939279243   DEBUG: DllAvFormat: Using libavformat system library
            20:14:18 T:1939280418 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
            20:14:18 T:1939280521 WARNING: DBus connection failed, trying alternate
            20:14:18 T:1939281594   DEBUG: DBus connection succeeded
            20:14:18 T:1939282354   DEBUG: Keyboard: DBus connection succeeded
            20:14:18 T:1939282502   DEBUG: OMXThread::Create - Thread with id -1387290944 started
            20:14:18 T:1939282604   DEBUG: DllAvUtilBase: Using libavutil system library
            20:14:18 T:1939282636   DEBUG: DllAvCodec: Using libavcodec system library
            20:14:18 T:1939282654   DEBUG: DllAvFormat: Using libavformat system library
            20:14:18 T:1939282994   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
            20:14:18 T:1939283372   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
            20:14:18 T:1939283465   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
            20:14:18 T:1939283726   DEBUG: OMXThread::StopThread - Thread stopped
            evroomE 3 Replies Last reply Reply Quote 0
            • evroomE
              evroom @Number_5
              @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              ok sorry,
              Nothing to be sorry for; you are learning as you go :-)
              • evroomE
                evroom @Number_5
                Okay, without getting rid of this error, omxplayer and therefore MMM-RTSPStream using omxplayer will not work for you.
                I have an Axis cam and there it did not work because to the resolution I used, had to use one of the resolutions that is supported by the cam.
                Where you able to open
                http://your-mirror-ip:8080/MMM-RTSPStream/config.html
                and see the cam there ?
                Could try ffmpeg, but there I have to pass.
                What camera are we talking about ?
                • evroomE
                  evroom @Number_5
                  @Number_5
                  Can you try with another port number (554 iso 80) ?
                  omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                  • N
                    Number_5
                    Hello
                    it is a,
                    DAHUA mini-dome Kamera hd-cvi 2 megapixels für indoor/outdoor g ip7. 30 m nightview fixe objektiv 2,8 mm. - AC/DC-Adapter : AC/DC-Adapter 12V 600mA (port 80)
                    also i have a Luna Hd
                    L-KA-2601 1 160,00 160,00
                    IR Bullet-Kamera (HD-CVI), Full HD,
                    if i open
                    http://XXX.xxx,x.xxx:8080/MMM-RTSPStream/config.html
                    I am denied access
                    S evroomE 2 Replies Last reply Reply Quote 0
                      sdetweil @Number_5
                      I am denied access
                      probably have to use the url syntax for userid and password
                      http://admin:roland!?1971@example.com
                      that is going to the magic mirror port
                      so, in the config.js do you have
                      address: “0.0.0.0”,
                      and
                      ipWHiltelist:[],
                      • evroomE
                        evroom @Number_5
                        @Number_5
                        Try with port 554, see previous post.
                        And see
                        https://github.com/shbatm/MMM-RTSPStream
                        “Using the module” on the config.html part I was referring to.
                        The IP there, is the MM IP, or localhost, not your cam IP.
                        • evroomE
                          evroom @evroom
                          See
                          https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/379
                          • N
                            Number_5
                            Hello
                            I’m just overwhelmed with the syntax.
                            and
                            I’ll try tomorrow and give feedback, thanks for your support
                            • N
                              Number_5 @evroom
                              @evroom
                              thats the result with the port 554
                              pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                              have a nice day ;)
                              pi@raspberrypi:~/MagicMirror/config $ head -30 omxplayer.log
                              21:33:25 T:18446744071806154291   DEBUG: DllBcm: Using omx system library
                              21:33:25 T:18446744071806155602   DEBUG: DllOMX: Using omx system library
                              21:33:25 T:18446744071806156277   DEBUG: DllAvFormat: Using libavformat system library
                              21:33:25 T:18446744071806157458 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                              21:33:25 T:18446744071806157567 WARNING: DBus connection failed, trying alternate
                              21:33:25 T:18446744071806158687   DEBUG: DBus connection succeeded
                              21:33:25 T:18446744071806159455   DEBUG: Keyboard: DBus connection succeeded
                              21:33:25 T:18446744071806159602   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                              21:33:25 T:18446744071806159705   DEBUG: DllAvUtilBase: Using libavutil system library
                              21:33:25 T:18446744071806159738   DEBUG: DllAvCodec: Using libavcodec system library
                              21:33:25 T:18446744071806159756   DEBUG: DllAvFormat: Using libavformat system library
                              21:33:25 T:18446744071806160118   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                              21:33:25 T:18446744071806160518   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                              21:33:25 T:18446744071806179771   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                              21:33:25 T:18446744071806180025   DEBUG: OMXThread::StopThread - Thread stopped
                              • N
                                Number_5
                                Hello Sam,
                                with 0.0.0.0.8080/MMM-rtspStream I was able to open the module configurator.
                                evroom said:
                                And see
                                It means the mirror id is not the raspberry pi?
                                where can I find the mm id?
                                evroomE S 3 Replies Last reply Reply Quote 0
                                • evroomE
                                  evroom @Number_5
                                  @Number_5
                                  When you run MM locally on your Pi, then your MM IP is your Pi IP.
                                  IP being the IP address, not an id.
                                  When you are able to open the RTSPStream configurator using 0.0.0.0.8080/MMM-rtspStream, then that’s fine.
                                  Continue with step 2 from this post:
                                    sdetweil @Number_5
                                    I don’t see that (mirror id) in the doc for this module
                                    i do see this for testing the camera connection
                                    Testing a camera feed
                                    To test to make sure you have a working url for a camera feed: create a text file with the URL as the first and only line in the file. Save the file as .strm and open the file with a video player like VLC.
                                    unfortuantely I can’t use this module on my dev system as there is no omxplayer…
                                    • evroomE
                                      evroom @Number_5
                                      @Number_5
                                      One more thing to try. Just leave out the port altogether.
                                      I use it without specifying the port.
                                      omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
                                      • N
                                        Number_5 @sdetweil
                                        @sdetweil said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                        create a text file
                                        Hallo Sam,
                                        1. i have created a textfile wit this line:
                                        rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=1&subtype=0
                                        2 )opend in vlc player direct on raspberry
                                        3) query answered user:admin passwort:roland!?1971
                                        4) saw the stream thats working fine
                                        rtsp://User:Passwort@IP:PORT/cam/realmonitor?channel=1&subtype=0
                                        here i inserted the user, passwort , Ip and port, channel from the camera.
                                        • N
                                          Number_5 @evroom
                                          Hello evroom,
                                          thats the result. Error after debug the file.
                                          pi@raspberrypi:~/MagicMirror $ pm2 stop 1
                                          [PM2] Applying action stopProcessId on app [1](ids: 1)
                                          [PM2] omx_stream1 ✓
                                          │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 0 │ 0 │ 0 │ stopped │ 0% │ 0b │ pi │ disabled │
                                          │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 30 │ stopped │ 0% │ 0b │ pi │ disabled │
                                          pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
                                          have a nice day ;)
                                          pi@raspberrypi:~/MagicMirror $ more omxplayer.log
                                          20:10:50 T:18446744072147623537   DEBUG: DllBcm: Using omx system library
                                          20:10:50 T:18446744072147624751   DEBUG: DllOMX: Using omx system library
                                          20:10:50 T:18446744072147625400   DEBUG: DllAvFormat: Using libavformat system library
                                          20:10:50 T:18446744072147626711   DEBUG: DBus connection succeeded
                                          20:10:50 T:18446744072147627442   DEBUG: Keyboard: DBus connection succeeded
                                          20:10:50 T:18446744072147627591   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                          20:10:50 T:18446744072147627696   DEBUG: DllAvUtilBase: Using libavutil system library
                                          20:10:50 T:18446744072147627719   DEBUG: DllAvCodec: Using libavcodec system library
                                          20:10:50 T:18446744072147627738   DEBUG: DllAvFormat: Using libavformat system library
                                          20:10:50 T:18446744072147628026   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                                          20:10:50 T:18446744072147628457   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                                          20:10:50 T:18446744072147647754   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                          20:10:50 T:18446744072147648005   DEBUG: OMXThread::StopThread - Thread stopped
                                          • N
                                            Number_5 @evroom
                                            @evroom
                                            @evroom
                                            Hello evroom
                                            thats my config.js
                                            var config = {
                                                    address: "0.0.0.0", // Address to listen on, can be:
                                                    port: 8080,
                                                    ipWhitelist: [], // Set [] to allow all IP addresses
                                            //        module: 'MMM-RTSPStream',
                                            //        position: 'middle_center',
                                            //        config: {
                                            //            initialSetup: true,
                                                module: "MMM-RTSPStream",
                                                position: "middle_center",
                                                    autoStart: true,
                                                    rotateStreams: true,
                                                    rotateStreamTimeout: 10,
                                                    moduleWidth: 354,
                                                    moduleHeight: 240,
                                                    localPlayer: 'ffmpeg',
                                                    remotePlayer: 'none',
                                                    showSnapWhenPaused: true,
                                                    remoteSnaps: true,
                                                    shutdownDelay: 12,
                                                        stream1: {
                                                        url: 'rtsp://admin:roland!?1971@192.168.2.140.2.108:554/cam/realmonitor?channel=2&subtype=0',
                                                        frameRate: 'undefined',
                                                        snapshotType: 'url',
                                                        snapshotRefresh: 10,
                                                        width: undefined,
                                                        height: undefined,
                                                        ffmpegPort: 9999,
                                            1. pm2 flush
                                            pi@raspberrypi:~ $ pm2 flush
                                            [PM2] Flushing /home/pi/.pm2/pm2.log
                                            [PM2] Flushing:
                                            [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                                            [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                                            [PM2] Flushing:
                                            [PM2] /dev/null
                                            [PM2] /home/pi/.pm2/logs/omx-stream1-error.log
                                            [PM2] Logs flushed
                                            pi@raspberrypi:~ $
                                            in this case i have took the ;
                                            url: ‘rtsp://admin:roland!?1971@192.168.2.140.2.108:554/cam/realmonitor?channel=2&subtype=0’,
                                            User, passwot from camera, id from raspberry, port as suggested, but with port 80 the real port its also not working.
                                            rtsp://Benutzer:Passwort@IP:PORT/cam/realmonitor?channel=1&subtype=0
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 30
                                            • 31
                                            • 21 / 31
