    602 Posts 67 Posters 2.2m Views 68 Watching
    • N Offline
      Number_5
      ok sorry,
      in future output and commands in </>
      thats the logfile
      pi@raspberrypi:~/MagicMirror/config $ more omxplayer.log
      20:14:18 T:1939277143   DEBUG: DllBcm: Using omx system library
      20:14:18 T:1939278613   DEBUG: DllOMX: Using omx system library
      20:14:18 T:1939279243   DEBUG: DllAvFormat: Using libavformat system library
      20:14:18 T:1939280418 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
      20:14:18 T:1939280521 WARNING: DBus connection failed, trying alternate
      20:14:18 T:1939281594   DEBUG: DBus connection succeeded
      20:14:18 T:1939282354   DEBUG: Keyboard: DBus connection succeeded
      20:14:18 T:1939282502   DEBUG: OMXThread::Create - Thread with id -1387290944 started
      20:14:18 T:1939282604   DEBUG: DllAvUtilBase: Using libavutil system library
      20:14:18 T:1939282636   DEBUG: DllAvCodec: Using libavcodec system library
      20:14:18 T:1939282654   DEBUG: DllAvFormat: Using libavformat system library
      20:14:18 T:1939282994   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
      20:14:18 T:1939283372   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
      20:14:18 T:1939283465   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
      20:14:18 T:1939283726   DEBUG: OMXThread::StopThread - Thread stopped
      evroomE 3 Replies Last reply Reply Quote 0
      • evroomE Offline
        evroom @Number_5
        @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        ok sorry,
        Nothing to be sorry for; you are learning as you go :-)
        MagicMirror version: 2.35.0
        Test environment:
        MagicMirror version: 2.36.0-develop
        • evroomE Offline
          evroom @Number_5
          Okay, without getting rid of this error, omxplayer and therefore MMM-RTSPStream using omxplayer will not work for you.
          I have an Axis cam and there it did not work because to the resolution I used, had to use one of the resolutions that is supported by the cam.
          Where you able to open
          http://your-mirror-ip:8080/MMM-RTSPStream/config.html
          and see the cam there ?
          Could try ffmpeg, but there I have to pass.
          What camera are we talking about ?
          Test environment:
          • evroomE Offline
            evroom @Number_5
            @Number_5
            Can you try with another port number (554 iso 80) ?
            omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
            Test environment:
            • N Offline
              Number_5
              Hello
              it is a,
              DAHUA mini-dome Kamera hd-cvi 2 megapixels für indoor/outdoor g ip7. 30 m nightview fixe objektiv 2,8 mm. - AC/DC-Adapter : AC/DC-Adapter 12V 600mA (port 80)
              also i have a Luna Hd
              L-KA-2601 1 160,00 160,00
              IR Bullet-Kamera (HD-CVI), Full HD,
              if i open
              http://XXX.xxx,x.xxx:8080/MMM-RTSPStream/config.html
              I am denied access
              S evroomE 2 Replies Last reply Reply Quote 0
                sdetweil @Number_5
                I am denied access
                probably have to use the url syntax for userid and password
                http://admin:roland!?1971@example.com
                that is going to the magic mirror port
                so, in the config.js do you have
                address: “0.0.0.0”,
                and
                ipWHiltelist:[],
                • evroomE Offline
                  evroom @Number_5
                  @Number_5
                  Try with port 554, see previous post.
                  And see
                  https://github.com/shbatm/MMM-RTSPStream
                  “Using the module” on the config.html part I was referring to.
                  The IP there, is the MM IP, or localhost, not your cam IP.
                  Test environment:
                  • evroomE Offline
                    evroom @evroom
                    See
                    https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/379
                    Test environment:
                    • N Offline
                      Number_5
                      Hello
                      I’m just overwhelmed with the syntax.
                      and
                      I’ll try tomorrow and give feedback, thanks for your support
                      • N Offline
                        Number_5 @evroom
                        @evroom
                        thats the result with the port 554
                        pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                        have a nice day ;)
                        pi@raspberrypi:~/MagicMirror/config $ head -30 omxplayer.log
                        21:33:25 T:18446744071806154291   DEBUG: DllBcm: Using omx system library
                        21:33:25 T:18446744071806155602   DEBUG: DllOMX: Using omx system library
                        21:33:25 T:18446744071806156277   DEBUG: DllAvFormat: Using libavformat system library
                        21:33:25 T:18446744071806157458 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                        21:33:25 T:18446744071806157567 WARNING: DBus connection failed, trying alternate
                        21:33:25 T:18446744071806158687   DEBUG: DBus connection succeeded
                        21:33:25 T:18446744071806159455   DEBUG: Keyboard: DBus connection succeeded
                        21:33:25 T:18446744071806159602   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                        21:33:25 T:18446744071806159705   DEBUG: DllAvUtilBase: Using libavutil system library
                        21:33:25 T:18446744071806159738   DEBUG: DllAvCodec: Using libavcodec system library
                        21:33:25 T:18446744071806159756   DEBUG: DllAvFormat: Using libavformat system library
                        21:33:25 T:18446744071806160118   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                        21:33:25 T:18446744071806160518   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                        21:33:25 T:18446744071806179771   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                        21:33:25 T:18446744071806180025   DEBUG: OMXThread::StopThread - Thread stopped
                        • N Offline
                          Number_5
                          Hello Sam,
                          with 0.0.0.0.8080/MMM-rtspStream I was able to open the module configurator.
                          evroom said:
                          And see
                          It means the mirror id is not the raspberry pi?
                          where can I find the mm id?
                          evroomE S 3 Replies Last reply Reply Quote 0
                          • evroomE Offline
                            evroom @Number_5
                            @Number_5
                            When you run MM locally on your Pi, then your MM IP is your Pi IP.
                            IP being the IP address, not an id.
                            When you are able to open the RTSPStream configurator using 0.0.0.0.8080/MMM-rtspStream, then that’s fine.
                            Continue with step 2 from this post:
                            Test environment:
                              sdetweil @Number_5
                              I don’t see that (mirror id) in the doc for this module
                              i do see this for testing the camera connection
                              Testing a camera feed
                              To test to make sure you have a working url for a camera feed: create a text file with the URL as the first and only line in the file. Save the file as .strm and open the file with a video player like VLC.
                              unfortuantely I can’t use this module on my dev system as there is no omxplayer…
                              • evroomE Offline
                                evroom @Number_5
                                @Number_5
                                One more thing to try. Just leave out the port altogether.
                                I use it without specifying the port.
                                omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
                                Test environment:
                                • N Offline
                                  Number_5 @sdetweil
                                  @sdetweil said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                  create a text file
                                  Hallo Sam,
                                  1. i have created a textfile wit this line:
                                  rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=1&subtype=0
                                  2 )opend in vlc player direct on raspberry
                                  3) query answered user:admin passwort:roland!?1971
                                  4) saw the stream thats working fine
                                  rtsp://User:Passwort@IP:PORT/cam/realmonitor?channel=1&subtype=0
                                  here i inserted the user, passwort , Ip and port, channel from the camera.
                                  • N Offline
                                    Number_5 @evroom
                                    Hello evroom,
                                    thats the result. Error after debug the file.
                                    pi@raspberrypi:~/MagicMirror $ pm2 stop 1
                                    [PM2] Applying action stopProcessId on app [1](ids: 1)
                                    [PM2] omx_stream1 ✓
                                    │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                                    │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 0 │ 0 │ 0 │ stopped │ 0% │ 0b │ pi │ disabled │
                                    │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 30 │ stopped │ 0% │ 0b │ pi │ disabled │
                                    pi@raspberrypi:~/MagicMirror $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0'
                                    have a nice day ;)
                                    pi@raspberrypi:~/MagicMirror $ more omxplayer.log
                                    20:10:50 T:18446744072147623537   DEBUG: DllBcm: Using omx system library
                                    20:10:50 T:18446744072147624751   DEBUG: DllOMX: Using omx system library
                                    20:10:50 T:18446744072147625400   DEBUG: DllAvFormat: Using libavformat system library
                                    20:10:50 T:18446744072147626711   DEBUG: DBus connection succeeded
                                    20:10:50 T:18446744072147627442   DEBUG: Keyboard: DBus connection succeeded
                                    20:10:50 T:18446744072147627591   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                    20:10:50 T:18446744072147627696   DEBUG: DllAvUtilBase: Using libavutil system library
                                    20:10:50 T:18446744072147627719   DEBUG: DllAvCodec: Using libavcodec system library
                                    20:10:50 T:18446744072147627738   DEBUG: DllAvFormat: Using libavformat system library
                                    20:10:50 T:18446744072147628026   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                                    20:10:50 T:18446744072147628457   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108/cam/realmonitor?channel=2&subtype=0
                                    20:10:50 T:18446744072147647754   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                    20:10:50 T:18446744072147648005   DEBUG: OMXThread::StopThread - Thread stopped
                                    • N Offline
                                      Number_5 @evroom
                                      @evroom
                                      @evroom
                                      Hello evroom
                                      thats my config.js
                                      var config = {
                                              address: "0.0.0.0", // Address to listen on, can be:
                                              port: 8080,
                                              ipWhitelist: [], // Set [] to allow all IP addresses
                                      //        module: 'MMM-RTSPStream',
                                      //        position: 'middle_center',
                                      //        config: {
                                      //            initialSetup: true,
                                          module: "MMM-RTSPStream",
                                          position: "middle_center",
                                              autoStart: true,
                                              rotateStreams: true,
                                              rotateStreamTimeout: 10,
                                              moduleWidth: 354,
                                              moduleHeight: 240,
                                              localPlayer: 'ffmpeg',
                                              remotePlayer: 'none',
                                              showSnapWhenPaused: true,
                                              remoteSnaps: true,
                                              shutdownDelay: 12,
                                                  stream1: {
                                                  url: 'rtsp://admin:roland!?1971@192.168.2.140.2.108:554/cam/realmonitor?channel=2&subtype=0',
                                                  frameRate: 'undefined',
                                                  snapshotType: 'url',
                                                  snapshotRefresh: 10,
                                                  width: undefined,
                                                  height: undefined,
                                                  ffmpegPort: 9999,
                                      1. pm2 flush
                                      pi@raspberrypi:~ $ pm2 flush
                                      [PM2] Flushing /home/pi/.pm2/pm2.log
                                      [PM2] Flushing:
                                      [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                                      [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                                      [PM2] Flushing:
                                      [PM2] /dev/null
                                      [PM2] /home/pi/.pm2/logs/omx-stream1-error.log
                                      [PM2] Logs flushed
                                      pi@raspberrypi:~ $
                                      in this case i have took the ;
                                      url: ‘rtsp://admin:roland!?1971@192.168.2.140.2.108:554/cam/realmonitor?channel=2&subtype=0’,
                                      User, passwot from camera, id from raspberry, port as suggested, but with port 80 the real port its also not working.
                                      rtsp://Benutzer:Passwort@IP:PORT/cam/realmonitor?channel=1&subtype=0
                                      • evroomE Offline
                                        evroom @Number_5
                                        1. query answered
                                        Did vlc player come with this query for user and password?
                                        The reason for supplying it in the URL is to not have to supply user and password.
                                        So, perhaps omxplayer has the same issue, but it will not ask for user and password like vlc player does.
                                        When vlc did not ask for the user and password, then we know the URL is correct, or at least can be parsed correct.
                                        Test environment:
                                        • N Offline
                                          Number_5
                                          yes, thats correct, querry follows after confirmation the url. then the stream follows
                                          thanks for your help.
                                          • evroomE Offline
                                            evroom @Number_5
                                            I suggested to NOT use a port, so to ditch the :80 or :554.
                                            And when using the omxplayer command, you will need to supply the cam IP.
                                            Does your spelling check change the word IP in id??
                                            I know it can be confusing, but you will need to read things right in order for us (the community) to be able to help you. He says in a friendly tone and manner :-)
                                            Test environment:
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 30
                                            • 31
                                            • 21 / 31
