    602 Posts 67 Posters 2.4m Views 68 Watching
    • N
      Number_5 @evroom
      Hello evroom,
      our contribution has overlapped. The stream with BucksBunny works, I deleted it now from the config.
      I would like to follow your suggestion and will look for the description next.
        sdetweil @Number_5
        @Number_5
        Does this work by itself.
        omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
        • N
          Number_5
          Hello sdetweil,
          sorry i am new here. Should i copy this line direkt in config.js ? where exactly?
          evroomE S 2 Replies Last reply
          • evroomE
            evroom @Number_5
            @Number_5
            Command-line.
            Better deactivate the module before (this in the config.js):
            module: "MMM-RTSPStream",
            disabled: true,
            etc
            MagicMirror version: 2.37.0
              sdetweil @Number_5
              @Number_5 that’s the command the module is trying to execute ( from the log)
              Open a command prompt, cut/paste that and see if it works
              • N
                Number_5
                Hello ,
                first I deactivated the config module.
                pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                -bash: !?1971@192.168.2.108:80/cam/realmonitor?: event not found
                pi@raspberrypi:~/MagicMirror/config $ pm2 start MagicMirror
                [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                [PM2] MagicMirror ✓
                [PM2] Process successfully started
                │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 30912 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                │ 1 │ omx_stream1 │ default │ N/A │ fork │ 30880 │ 4s │ 741 │ online │ 0% │ 2.6mb │ pi │ disabled │
                It does not work, :-(
                evroomE 1 Reply Last reply
                • evroomE
                  evroom @Number_5
                  @Number_5
                  Can you try with quotes (single, double) ?
                  omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0"
                  omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
                  when the command works, but still no video, then add --genlog
                  omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
                  This will creat a log file called omxplayer.log under the directory where you started omxplayer.
                  • N
                    Number_5
                    1. First 1 start magic mirror.
                    2. with 2 qoutes
                    3. with 1 qoute
                    [PM2] MagicMirror ✓
                    │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                    │ 1 │ omx_stream1 │ default │ N/A │ fork │ 8825 │ 2s │ 1000 │ online │ 0% │ 2.5mb │ pi │ disabled │
                    [1]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2
                    pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0”
                    omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0”
                    [2] 9584
                    [3] 9585
                    pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
                    have a nice day ;)
                    [2]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2
                    [3] Fertig subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2
                    S evroomE 2 Replies Last reply
                      sdetweil @Number_5
                      @Number_5 pm2 stop 0, pm2 stop 1
                      just from the commandline…(ctrl-alt-t) . does a video window open on any of these?
                      • evroomE
                        evroom @Number_5
                        @Number_5
                        Better to stop MM temporarily or disable the module with disabled: true, and a restart of MM.
                        Also make sure omx_stream1 process is not running.
                        pm2 status
                        pm2 stop omx_stream1
                        pm2 delete omx_stream1
                        pm2 status
                        Then do the single quoted command, with logging enabled.
                        • N
                          Number_5
                          Hello ,
                          1. I started it from the command line
                          but no windows opens. or I’m doing something wrong.
                          pi@raspberrypi:~/MagicMirror/config $ --genlog
                          -bash: --genlog: Kommando nicht gefunden.
                          pi@raspberrypi:~/MagicMirror/config $ pm2 status
                          │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 13m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                          │ 1 │ omx_stream1 │ default │ N/A │ fork │ 14967 │ 0s │ 1152 │ online │ 0% │ 2.6mb │ pi │ disabled │
                          pi@raspberrypi:~/MagicMirror/config $ pm2 stop omx_stream1
                          [PM2] Applying action stopProcessId on app [omx_stream1](ids: 1)
                          [PM2] omx_stream1 ✓
                          │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 14m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                          │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1156 │ stopped │ 0% │ 0b │ pi │ disabled │
                          pi@raspberrypi:~/MagicMirror/config $ pm2 delete omx_stream1
                          [PM2] Applying action deleteProcessId on app [omx_stream1](ids: 1)
                          [PM2] omx_stream1 ✓
                          [PM2][WARN] Current process list running is not in sync with saved list. omx_stream1 differs. Type ‘pm2 save’ to synchronize.
                          pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
                          have a nice day ;)
                          • evroomE
                            evroom @Number_5
                            @Number_5
                            Could you please post commands and output using the </> tag ?
                            So, select the command or output and click on the </> symbol.
                            Does the log say anything useful ?
                            more omxplayer.log
                            Pleas do not post the complete log, unless small.
                            30 lines tops.
                            head -30 omxplayer.log
                            • N
                              Number_5
                              ok sorry,
                              in future output and commands in </>
                              thats the logfile
                              pi@raspberrypi:~/MagicMirror/config $ more omxplayer.log
                              20:14:18 T:1939277143   DEBUG: DllBcm: Using omx system library
                              20:14:18 T:1939278613   DEBUG: DllOMX: Using omx system library
                              20:14:18 T:1939279243   DEBUG: DllAvFormat: Using libavformat system library
                              20:14:18 T:1939280418 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                              20:14:18 T:1939280521 WARNING: DBus connection failed, trying alternate
                              20:14:18 T:1939281594   DEBUG: DBus connection succeeded
                              20:14:18 T:1939282354   DEBUG: Keyboard: DBus connection succeeded
                              20:14:18 T:1939282502   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                              20:14:18 T:1939282604   DEBUG: DllAvUtilBase: Using libavutil system library
                              20:14:18 T:1939282636   DEBUG: DllAvCodec: Using libavcodec system library
                              20:14:18 T:1939282654   DEBUG: DllAvFormat: Using libavformat system library
                              20:14:18 T:1939282994   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                              20:14:18 T:1939283372   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                              20:14:18 T:1939283465   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                              20:14:18 T:1939283726   DEBUG: OMXThread::StopThread - Thread stopped
                              evroomE 3 Replies Last reply
                              • evroomE
                                evroom @Number_5
                                @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                ok sorry,
                                Nothing to be sorry for; you are learning as you go :-)
                                • evroomE
                                  evroom @Number_5
                                  Okay, without getting rid of this error, omxplayer and therefore MMM-RTSPStream using omxplayer will not work for you.
                                  I have an Axis cam and there it did not work because to the resolution I used, had to use one of the resolutions that is supported by the cam.
                                  Where you able to open
                                  http://your-mirror-ip:8080/MMM-RTSPStream/config.html
                                  and see the cam there ?
                                  Could try ffmpeg, but there I have to pass.
                                  What camera are we talking about ?
                                  • evroomE
                                    evroom @Number_5
                                    @Number_5
                                    Can you try with another port number (554 iso 80) ?
                                    omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                                    N 1 Reply Last reply
                                    • N
                                      Number_5
                                      Hello
                                      it is a,
                                      DAHUA mini-dome Kamera hd-cvi 2 megapixels für indoor/outdoor g ip7. 30 m nightview fixe objektiv 2,8 mm. - AC/DC-Adapter : AC/DC-Adapter 12V 600mA (port 80)
                                      also i have a Luna Hd
                                      L-KA-2601 1 160,00 160,00
                                      IR Bullet-Kamera (HD-CVI), Full HD,
                                      if i open
                                      http://XXX.xxx,x.xxx:8080/MMM-RTSPStream/config.html
                                      I am denied access
                                        sdetweil @Number_5
                                        I am denied access
                                        probably have to use the url syntax for userid and password
                                        http://admin:roland!?1971@example.com
                                        that is going to the magic mirror port
                                        so, in the config.js do you have
                                        address: “0.0.0.0”,
                                        and
                                        ipWHiltelist:[],
                                        • evroomE
                                          evroom @Number_5
                                          @Number_5
                                          Try with port 554, see previous post.
                                          And see
                                          https://github.com/shbatm/MMM-RTSPStream
                                          “Using the module” on the config.html part I was referring to.
                                          The IP there, is the MM IP, or localhost, not your cam IP.
                                          • evroomE
                                            evroom @evroom
                                            See
                                            https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/379
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 30
                                            • 31
                                            • 21 / 31
