    602 Posts 67 Posters 2.4m Views 68 Watching
      sdetweil @Number_5
      @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      Access denied to IP address: 127.0.0.1
      No, you didn’t change ipWhitelist to [] as I documented above
      • N
        Number_5
        Hallo Sam,
        sorry i have fixed it now.
        after:
        var config = {
        address: “0.0.0.0”, // Address to listen on, can be:
        // - “”, “0.0.0.0”, “::” to listen on any interface
        // Default, when address config is left out, is “localhost”
        port: 8080,
        ipWhitelist: [], // Set [] to allow all IP addresses
        After newstart I can see the white frame again. Inside the frame the title “Buck Bunny” and “Aussentür”
        as well as the symbol “play” can be seen. But not the stream.
        step 7 pm2 flush
        pi@raspberrypi:~/MagicMirror/config $ pm2 flush
        [PM2] Flushing /home/pi/.pm2/pm2.log
        [PM2] Flushing:
        [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
        [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
        [PM2] Flushing:
        [PM2] /dev/null
        [PM2] /home/pi/.pm2/logs/omx-stream1-error.log
        [PM2] Logs flushed
        step 8 restart MM
        pi@raspberrypi:~/MagicMirror/config $ pm2 restart MagicMirror
        [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
        [PM2] MagicMirror ✓
        │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
        │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 3001 │ 0s │ 1 │ online │ 0% │ 2.4mb │ pi │ disabled │
        │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 57 │ stopped │ 0% │ 0b │ pi │ disabled │
        step 9) check the logs
        pi@raspberrypi:~/MagicMirror/config $ pm2 logs --lines 200
        [TAILING] Tailing last 200 lines for [all] processes (change the value with --lines option)
        /home/pi/.pm2/pm2.log last 200 lines:
        PM2 | 2020-02-02T16:57:52: PM2 log: Stopping app:MagicMirror id:0
        PM2 | 2020-02-02T16:57:52: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2 | 2020-02-02T16:57:52: PM2 log: pid=2049 msg=process killed
        PM2 | 2020-02-02T16:57:52: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2 | 2020-02-02T16:57:52: PM2 log: App [MagicMirror:0] online
        PM2 | 2020-02-02T16:58:03: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:03: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:09: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:09: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:09: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:15: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:15: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:15: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:20: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:20: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:20: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:26: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:26: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:26: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:31: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:31: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:31: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:37: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:37: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:37: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:43: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:43: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:43: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:48: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:48: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:48: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:54: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:54: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:54: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:58:59: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:58:59: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:58:59: PM2 log: App [omx_stream1:1] online
        PM2 | 2020-02-02T16:59:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | 2020-02-02T16:59:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
        PM2 | 2020-02-02T16:59:05: PM2 log: App [omx_stream1:1] online
        /home/pi/.pm2/logs/omx-stream1-error.log last 200 lines:
        /home/pi/.pm2/logs/MagicMirror-error.log last 200 lines:
        0|MagicMir | [16:58:01.715] [ERROR] TypeError: port or a server must be provided
        0|MagicMir | at new WebSocketServer (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/node_modules/ws/lib/WebSocketServer.js:44:11)
        0|MagicMir | at VideoStream.stream2Socket (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/videoStream.js:32:23)
        0|MagicMir | at new VideoStream (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/videoStream.js:27:14)
        0|MagicMir | at Class.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:74:40)
        0|MagicMir | at streams.forEach (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:524:22)
        0|MagicMir | at Array.forEach ()
        0|MagicMir | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:523:21)
        0|MagicMir | at Socket. (/home/pi/MagicMirror/js/node_helper.js:113:11)
        0|MagicMir | at Socket.emit (events.js:182:13)
        0|MagicMir | at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
        /home/pi/.pm2/logs/MagicMirror-out.log last 200 lines:
        0|MagicMir |
        0|MagicMir | > magicmirror@2.10.0 start /home/pi/MagicMirror
        0|MagicMir | > ./run-start.sh
        0|MagicMir |
        0|MagicMir | [16:57:58.071] [LOG] Starting MagicMirror: v2.10.0
        0|MagicMir | [16:57:58.080] [LOG] Loading config …
        0|MagicMir | [16:57:58.086] [LOG] Loading module helpers …
        0|MagicMir | [16:57:58.087] [LOG] No helper found for module: alert.
        0|MagicMir | [16:57:58.134] [LOG] Initializing new module helper …
        0|MagicMir | [16:57:58.135] [LOG] Module helper loaded: updatenotification
        0|MagicMir | [16:57:59.093] [LOG] Initializing new module helper …
        0|MagicMir | [16:57:59.093] [LOG] Module helper loaded: MMM-RTSPStream
        0|MagicMir | [16:57:59.348] [LOG] Initializing new module helper …
        0|MagicMir | [16:57:59.348] [LOG] Module helper loaded: MMM-PublicTransportHafas
        0|MagicMir | [16:57:59.349] [LOG] No helper found for module: currentweather.
        0|MagicMir | [16:57:59.350] [LOG] No helper found for module: weatherforecast.
        0|MagicMir | [16:57:59.417] [LOG] Initializing new module helper …
        0|MagicMir | [16:57:59.417] [LOG] Module helper loaded: calendar
        0|MagicMir | [16:57:59.447] [LOG] Initializing new module helper …
        0|MagicMir | [16:57:59.448] [LOG] Module helper loaded: newsfeed
        0|MagicMir | [16:57:59.448] [LOG] All module helpers loaded.
        0|MagicMir | [16:57:59.449] [LOG] Starting server on port 8080 …
        0|MagicMir | [16:57:59.456] [INFO] You’re using a full whitelist configuration to allow for all IPs
        0|MagicMir | [16:57:59.463] [LOG] Server started …
        0|MagicMir | [16:57:59.464] [LOG] Connecting socket for: updatenotification
        0|MagicMir | [16:57:59.465] [LOG] Connecting socket for: MMM-RTSPStream
        0|MagicMir | [16:57:59.466] [LOG] PM2: Stopping all OMXPlayer Streams…
        0|MagicMir | [16:57:59.468] [LOG] Connecting socket for: MMM-PublicTransportHafas
        0|MagicMir | [16:57:59.469] [LOG] Connecting socket for: calendar
        0|MagicMir | [16:57:59.470] [LOG] Starting node helper for: calendar
        0|MagicMir | [16:57:59.471] [LOG] Connecting socket for: newsfeed
        0|MagicMir | [16:57:59.471] [LOG] Starting module: newsfeed
        0|MagicMir | [16:57:59.472] [LOG] Sockets connected & modules started …
        0|MagicMir | [16:57:59.645] [LOG] Launching application.
        0|MagicMir | [16:57:59.829] [LOG] PM2: Checking if omx_stream1 is running…
        0|MagicMir | [16:58:01.702] [LOG] Transportation fetcher for station with id ‘xxx’ created.
        0|MagicMir | [16:58:01.707] [LOG] Starting WebSocket server on port undefined. Waiting for connections…
        0|MagicMir | [16:58:01.714] [LOG] Whoops! There was an uncaught exception…
        0|MagicMir | [16:58:01.721] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|MagicMir | [16:58:01.722] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        0|MagicMir | [16:58:01.744] [LOG] Transportation fetcher for station with id’xxx’ created.
        0|MagicMir | [16:58:01.747] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxxgroup.calendar.google.com/private-xxxc/basic.ics - Interval: 300000
        0|MagicMir | [16:58:01.759] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
        0|MagicMir | [16:58:03.761] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 643,514,1283,874 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx.xxx@xxx.xxx.2.108:80/cam/realmonitor?channel=2&subtype=0
        0|MagicMir | [16:58:03.793] [LOG] Starting PM2 for omx_stream1
        0|MagicMir | [16:58:03.960] [LOG] PM2 started for omx_stream1
        1|omx_stream1 | have a nice day ;)
        PM2 | App [omx_stream1:1] exited with code [1] via signal [SIGINT]
        PM2 | App [omx_stream1:1] starting in -fork mode-
        PM2 | App [omx_stream1:1] online
        What else can I do ?
        Thanks for your help.
        evroomE 1 Reply Last reply
        • evroomE
          evroom @Number_5
          If I see it correctly, then you have 2 MMM-RTSPStream modules active in your config and 2 stream1 defined, and therefore are trying to start 2 omx_stream1 processes.
          I would concentrate on 1 config with 1 stream1.
          To see if things works, try it with the BucksBunny config first.
          Then give the other one a try (with the bunny removed).
          I also would give the rtsp stream a go without MM, so standalone.
          Somewhere in this thread there should be a description on how to do this; would need to search my notes for it.
          MagicMirror version: 2.37.0
          N 1 Reply Last reply
          • N
            Number_5
            update:
            the test video is now running, thanks. I had left the entry of the IP cam in the config, sorry. Now I see a white frame, unfortunately the camera stream cannot be seen. by clicking on the window you can see the “Play” icon.
            step 7 pm2 flush
            [PM2] Flushing:
            [PM2] Flushing:
            [PM2] /dev/null
            [PM2] Logs flushed
            step 8 restart MM
            [PM2] MagicMirror ✓
            │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 4841 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
            │ 1 │ omx_stream1 │ default │ N/A │ fork │ 4814 │ 3s │ 90 │ online │ 0% │ 2.5mb │ pi │ disabled │
            PM2 | 2020-02-02T19:33:48: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:33:48: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:33:48: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:33:54: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:33:54: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:33:54: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:33:59: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:33:59: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:33:59: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:05: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:11: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:11: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:11: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:16: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:16: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:16: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:22: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:22: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:22: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:27: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:27: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:27: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:33: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:33: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:38: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:38: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:38: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:44: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:44: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:44: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:49: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:49: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:49: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:34:55: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:34:55: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:34:55: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:01: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:01: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:01: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:06: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:06: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:06: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:12: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:12: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:12: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:17: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:17: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:17: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:20: PM2 log: Stopping app:MagicMirror id:0
            PM2 | 2020-02-02T19:35:21: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:21: PM2 log: pid=2360 msg=process killed
            PM2 | 2020-02-02T19:35:21: PM2 log: App [MagicMirror:0] starting in -fork mode-
            PM2 | 2020-02-02T19:35:21: PM2 log: App [MagicMirror:0] online
            PM2 | 2020-02-02T19:35:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:24: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:29: PM2 log: Stopping app:omx_stream1 id:1
            PM2 | 2020-02-02T19:35:29: PM2 log: App [omx_stream1:1] exited with code [0] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:29: PM2 log: pid=4878 msg=process killed
            PM2 | 2020-02-02T19:35:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:33: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:39: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:39: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:39: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:45: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:45: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:45: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:50: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:50: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:50: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:35:56: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:35:56: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:35:56: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:36:01: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:36:01: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:36:01: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:36:07: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:36:07: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:36:07: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:36:12: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:36:12: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:36:12: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:36:18: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:36:18: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:36:18: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:36:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:36:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:36:24: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:36:29: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:36:29: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:36:29: PM2 log: App [omx_stream1:1] online
            PM2 | 2020-02-02T19:36:35: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
            PM2 | 2020-02-02T19:36:35: PM2 log: App [omx_stream1:1] starting in -fork mode-
            PM2 | 2020-02-02T19:36:35: PM2 log: App [omx_stream1:1] online
            0|MagicMir |
            0|MagicMir |
            0|MagicMir | [19:35:27.493] [LOG] Starting MagicMirror: v2.10.0
            0|MagicMir | [19:35:27.503] [LOG] Loading config …
            0|MagicMir | [19:35:27.509] [LOG] Loading module helpers …
            0|MagicMir | [19:35:27.511] [LOG] No helper found for module: alert.
            0|MagicMir | [19:35:27.575] [LOG] Initializing new module helper …
            0|MagicMir | [19:35:27.576] [LOG] Module helper loaded: updatenotification
            0|MagicMir | [19:35:28.715] [LOG] Initializing new module helper …
            0|MagicMir | [19:35:28.716] [LOG] Module helper loaded: MMM-RTSPStream
            0|MagicMir | [19:35:29.021] [LOG] Initializing new module helper …
            0|MagicMir | [19:35:29.022] [LOG] Module helper loaded: MMM-PublicTransportHafas
            0|MagicMir | [19:35:29.023] [LOG] No helper found for module: currentweather.
            0|MagicMir | [19:35:29.023] [LOG] No helper found for module: weatherforecast.
            0|MagicMir | [19:35:29.096] [LOG] Initializing new module helper …
            0|MagicMir | [19:35:29.097] [LOG] Module helper loaded: calendar
            0|MagicMir | [19:35:29.132] [LOG] Initializing new module helper …
            0|MagicMir | [19:35:29.132] [LOG] Module helper loaded: newsfeed
            0|MagicMir | [19:35:29.133] [LOG] All module helpers loaded.
            0|MagicMir | [19:35:29.134] [LOG] Starting server on port 8080 …
            0|MagicMir | [19:35:29.143] [INFO] You’re using a full whitelist configuration to allow for all IPs
            0|MagicMir | [19:35:29.152] [LOG] Server started …
            0|MagicMir | [19:35:29.153] [LOG] Connecting socket for: updatenotification
            0|MagicMir | [19:35:29.155] [LOG] Connecting socket for: MMM-RTSPStream
            0|MagicMir | [19:35:29.156] [LOG] PM2: Stopping all OMXPlayer Streams…
            0|MagicMir | [19:35:29.159] [LOG] Connecting socket for: MMM-PublicTransportHafas
            0|MagicMir | [19:35:29.160] [LOG] Connecting socket for: calendar
            0|MagicMir | [19:35:29.161] [LOG] Starting node helper for: calendar
            0|MagicMir | [19:35:29.162] [LOG] Connecting socket for: newsfeed
            0|MagicMir | [19:35:29.163] [LOG] Starting module: newsfeed
            0|MagicMir | [19:35:29.164] [LOG] Sockets connected & modules started …
            0|MagicMir | [19:35:29.353] [LOG] Launching application.
            0|MagicMir | [19:35:29.596] [LOG] PM2: Checking if omx_stream1 is running…
            0|MagicMir | [19:35:29.597] [LOG] PM2: Stopping omx_stream1…
            0|MagicMir | [19:35:31.438] [LOG] Transportation fetcher for station with id ‘xxx’ created.
            0|MagicMir | [19:35:31.613] [LOG] Transportation fetcher for station with id ‘xxx’ created.
            0|MagicMir | [19:35:31.618] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxgroup.calendar.google.com/private-xxx/basic.ics - Interval: 300000
            0|MagicMir | [19:35:31.639] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
            0|MagicMir | [19:35:33.506] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
            0|MagicMir | [19:35:33.531] [LOG] Starting PM2 for omx_stream1
            0|MagicMir | [19:35:33.676] [LOG] PM2 started for omx_stream1
            Is there still an idea?
            • N
              Number_5 @evroom
              Hello evroom,
              our contribution has overlapped. The stream with BucksBunny works, I deleted it now from the config.
              I would like to follow your suggestion and will look for the description next.
                sdetweil @Number_5
                @Number_5
                Does this work by itself.
                • N
                  Number_5
                  Hello sdetweil,
                  sorry i am new here. Should i copy this line direkt in config.js ? where exactly?
                  evroomE S 2 Replies Last reply
                  • evroomE
                    evroom @Number_5
                    @Number_5
                    Command-line.
                    Better deactivate the module before (this in the config.js):
                    module: "MMM-RTSPStream",
                    disabled: true,
                    etc
                      sdetweil @Number_5
                      @Number_5 that’s the command the module is trying to execute ( from the log)
                      Open a command prompt, cut/paste that and see if it works
                      • N
                        Number_5
                        Hello ,
                        first I deactivated the config module.
                        pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                        -bash: !?1971@192.168.2.108:80/cam/realmonitor?: event not found
                        pi@raspberrypi:~/MagicMirror/config $ pm2 start MagicMirror
                        [PM2] MagicMirror ✓
                        [PM2] Process successfully started
                        │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 30912 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                        │ 1 │ omx_stream1 │ default │ N/A │ fork │ 30880 │ 4s │ 741 │ online │ 0% │ 2.6mb │ pi │ disabled │
                        It does not work, :-(
                        • evroomE
                          evroom @Number_5
                          @Number_5
                          Can you try with quotes (single, double) ?
                          omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0"
                          omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
                          when the command works, but still no video, then add --genlog
                          omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
                          This will creat a log file called omxplayer.log under the directory where you started omxplayer.
                          • N
                            Number_5
                            1. First 1 start magic mirror.
                            2. with 2 qoutes
                            3. with 1 qoute
                            [PM2] MagicMirror ✓
                            │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                            │ 1 │ omx_stream1 │ default │ N/A │ fork │ 8825 │ 2s │ 1000 │ online │ 0% │ 2.5mb │ pi │ disabled │
                            [1]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2
                            pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0”
                            omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0”
                            [2] 9584
                            [3] 9585
                            pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
                            have a nice day ;)
                            [2]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2
                            [3] Fertig subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2
                            S evroomE 2 Replies Last reply
                              sdetweil @Number_5
                              @Number_5 pm2 stop 0, pm2 stop 1
                              just from the commandline…(ctrl-alt-t) . does a video window open on any of these?
                              • evroomE
                                evroom @Number_5
                                @Number_5
                                Better to stop MM temporarily or disable the module with disabled: true, and a restart of MM.
                                Also make sure omx_stream1 process is not running.
                                pm2 status
                                pm2 stop omx_stream1
                                pm2 delete omx_stream1
                                pm2 status
                                Then do the single quoted command, with logging enabled.
                                • N
                                  Number_5
                                  Hello ,
                                  1. I started it from the command line
                                  but no windows opens. or I’m doing something wrong.
                                  pi@raspberrypi:~/MagicMirror/config $ --genlog
                                  -bash: --genlog: Kommando nicht gefunden.
                                  pi@raspberrypi:~/MagicMirror/config $ pm2 status
                                  │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 13m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                  │ 1 │ omx_stream1 │ default │ N/A │ fork │ 14967 │ 0s │ 1152 │ online │ 0% │ 2.6mb │ pi │ disabled │
                                  pi@raspberrypi:~/MagicMirror/config $ pm2 stop omx_stream1
                                  [PM2] Applying action stopProcessId on app [omx_stream1](ids: 1)
                                  [PM2] omx_stream1 ✓
                                  │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 14m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                  │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1156 │ stopped │ 0% │ 0b │ pi │ disabled │
                                  pi@raspberrypi:~/MagicMirror/config $ pm2 delete omx_stream1
                                  [PM2] Applying action deleteProcessId on app [omx_stream1](ids: 1)
                                  [PM2] omx_stream1 ✓
                                  [PM2][WARN] Current process list running is not in sync with saved list. omx_stream1 differs. Type ‘pm2 save’ to synchronize.
                                  pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
                                  have a nice day ;)
                                  • evroomE
                                    evroom @Number_5
                                    @Number_5
                                    Could you please post commands and output using the </> tag ?
                                    So, select the command or output and click on the </> symbol.
                                    Does the log say anything useful ?
                                    more omxplayer.log
                                    Pleas do not post the complete log, unless small.
                                    30 lines tops.
                                    head -30 omxplayer.log
                                    • N
                                      Number_5
                                      ok sorry,
                                      in future output and commands in </>
                                      thats the logfile
                                      pi@raspberrypi:~/MagicMirror/config $ more omxplayer.log
                                      20:14:18 T:1939277143   DEBUG: DllBcm: Using omx system library
                                      20:14:18 T:1939278613   DEBUG: DllOMX: Using omx system library
                                      20:14:18 T:1939279243   DEBUG: DllAvFormat: Using libavformat system library
                                      20:14:18 T:1939280418 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                                      20:14:18 T:1939280521 WARNING: DBus connection failed, trying alternate
                                      20:14:18 T:1939281594   DEBUG: DBus connection succeeded
                                      20:14:18 T:1939282354   DEBUG: Keyboard: DBus connection succeeded
                                      20:14:18 T:1939282502   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                      20:14:18 T:1939282604   DEBUG: DllAvUtilBase: Using libavutil system library
                                      20:14:18 T:1939282636   DEBUG: DllAvCodec: Using libavcodec system library
                                      20:14:18 T:1939282654   DEBUG: DllAvFormat: Using libavformat system library
                                      20:14:18 T:1939282994   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                                      20:14:18 T:1939283372   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                                      20:14:18 T:1939283465   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                      20:14:18 T:1939283726   DEBUG: OMXThread::StopThread - Thread stopped
                                      evroomE 3 Replies Last reply
                                      • evroomE
                                        evroom @Number_5
                                        ok sorry,
                                        Nothing to be sorry for; you are learning as you go :-)
                                        • evroomE
                                          evroom @Number_5
                                          Okay, without getting rid of this error, omxplayer and therefore MMM-RTSPStream using omxplayer will not work for you.
                                          I have an Axis cam and there it did not work because to the resolution I used, had to use one of the resolutions that is supported by the cam.
                                          Where you able to open
                                          http://your-mirror-ip:8080/MMM-RTSPStream/config.html
                                          and see the cam there ?
                                          Could try ffmpeg, but there I have to pass.
                                          What camera are we talking about ?
                                          • evroomE
                                            evroom @Number_5
                                            @Number_5
                                            Can you try with another port number (554 iso 80) ?
                                            omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 30
                                            • 31
                                            • 20 / 31
